Rotor Riot Phone Connector Cable Replacement
    1. Rotor Riot Phone Connector Cable Replacement, Remove the iPhone mount: step 1, image 1 of 3 Rotor Riot Phone Connector Cable Replacement, Remove the iPhone mount: step 1, image 2 of 3 Rotor Riot Phone Connector Cable Replacement, Remove the iPhone mount: step 1, image 3 of 3
      • Use your fingers to remove the screw on the back side of the controller securing the iPhone mount.
      • Remove the iPhone mount.
      Ask FixBot
    2. Rotor Riot Phone Connector Cable Replacement, Unscrew the back cover: step 2, image 1 of 1
      • Use a T6 Torx screwdriver to remove the eight 9.2 mm-long screws securing the back cover.
      • Don't try to remove the back cover all the way yet! It's still connected to the mainboard.
      Ask FixBot
    3. Rotor Riot Phone Connector Cable Replacement, Swing open the back cover: step 3, image 1 of 3 Rotor Riot Phone Connector Cable Replacement, Swing open the back cover: step 3, image 2 of 3 Rotor Riot Phone Connector Cable Replacement, Swing open the back cover: step 3, image 3 of 3
      • Lift up the back cover of the controller.
      • Lift the back cover to a 45 degree angle and place it next to the controller.
      • Don't strain the interconnect cable during this procedure.
      Ask FixBot
    4. Rotor Riot Phone Connector Cable Replacement, Disconnect the phone connector cable: step 4, image 1 of 3 Rotor Riot Phone Connector Cable Replacement, Disconnect the phone connector cable: step 4, image 2 of 3 Rotor Riot Phone Connector Cable Replacement, Disconnect the phone connector cable: step 4, image 3 of 3
      • Use a spudger to disconnect the phone connector cable from the mainboard.
      Ask FixBot
    5. Rotor Riot Phone Connector Cable Replacement, Remove the back cover: step 5, image 1 of 1
      • Remove the back cover.
      Ask FixBot
    1. Rotor Riot Phone Connector Cable Replacement, Remove the screw thread: step 6, image 1 of 3 Rotor Riot Phone Connector Cable Replacement, Remove the screw thread: step 6, image 2 of 3 Rotor Riot Phone Connector Cable Replacement, Remove the screw thread: step 6, image 3 of 3
      • Pull the screw thread bracket straight up to slide it off of the rails securing it to the back cover.
      Ask FixBot
    2. Rotor Riot Phone Connector Cable Replacement, Remove the phone connector cable: step 7, image 1 of 3 Rotor Riot Phone Connector Cable Replacement, Remove the phone connector cable: step 7, image 2 of 3 Rotor Riot Phone Connector Cable Replacement, Remove the phone connector cable: step 7, image 3 of 3
      • Remove the phone connector cable.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
Adriana Zwink
68,045 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
123 Members
52,858 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 45
All Time: 708
