Rotor Riot Mainboard Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Rotor Riot Mainboard Replacement, Remove the iPhone mount: step 1, image 1 of 3 Rotor Riot Mainboard Replacement, Remove the iPhone mount: step 1, image 2 of 3 Rotor Riot Mainboard Replacement, Remove the iPhone mount: step 1, image 3 of 3
      • Use your fingers to remove the screw on the back side of the controller securing the iPhone mount.
      • Remove the iPhone mount.
      Ask FixBot
    2. Rotor Riot Mainboard Replacement, Unscrew the back cover: step 2, image 1 of 1
      • Use a T6 Torx screwdriver to remove the eight 9.2 mm-long screws securing the back cover.
      • Don't try to remove the back cover all the way yet! It's still connected to the mainboard.
      Ask FixBot
    3. Rotor Riot Mainboard Replacement, Swing open the back cover: step 3, image 1 of 3 Rotor Riot Mainboard Replacement, Swing open the back cover: step 3, image 2 of 3 Rotor Riot Mainboard Replacement, Swing open the back cover: step 3, image 3 of 3
      • Lift up the back cover of the controller.
      • Lift the back cover to a 45 degree angle and place it next to the controller.
      • Don't strain the interconnect cable during this procedure.
      Ask FixBot
    4. Rotor Riot Mainboard Replacement, Disconnect the phone connector cable: step 4, image 1 of 3 Rotor Riot Mainboard Replacement, Disconnect the phone connector cable: step 4, image 2 of 3 Rotor Riot Mainboard Replacement, Disconnect the phone connector cable: step 4, image 3 of 3
      • Use a spudger to disconnect the phone connector cable from the mainboard.
      Ask FixBot
    5. Rotor Riot Mainboard Replacement, Remove the back cover: step 5, image 1 of 1
      • Remove the back cover.
      Ask FixBot
    1. Rotor Riot Mainboard Replacement, Remove the shoulder buttons: step 6, image 1 of 2 Rotor Riot Mainboard Replacement, Remove the shoulder buttons: step 6, image 2 of 2
      • Remove the shoulder buttons by lifting them out of the case.
      Ask FixBot
    2. Rotor Riot Mainboard Replacement, Unscrew the mainboard: step 7, image 1 of 1
      • Use a Phillips screwdriver to remove the four 7.0 mm-long screws securing the mainboard.
      Ask FixBot
    3. Rotor Riot Mainboard Replacement, Flip over the mainboard: step 8, image 1 of 3 Rotor Riot Mainboard Replacement, Flip over the mainboard: step 8, image 2 of 3 Rotor Riot Mainboard Replacement, Flip over the mainboard: step 8, image 3 of 3
      • Flip over the mainboard and place it above the controller housing.
      • Avoid tensioning the trigger button cables during this procedure and don't try to remove the mainboard all the way yet! It is still connected to the controller housing.
      Ask FixBot
    4. Rotor Riot Mainboard Replacement, Disconnect the trigger buttons: step 9, image 1 of 3 Rotor Riot Mainboard Replacement, Disconnect the trigger buttons: step 9, image 2 of 3 Rotor Riot Mainboard Replacement, Disconnect the trigger buttons: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of blunt nose tweezers to remove the left trigger button from the controller housing by lifting it straight out of its recess.
      • Repeat this procedure for the right trigger button.
      Ask FixBot
    5. Rotor Riot Mainboard Replacement, Remove the mainboard: step 10, image 1 of 1
      • Remove the mainboard from the housing.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
Adriana Zwink
69,026 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 106
