Rotor Riot Direction Pad Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
57
All Time:
716
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the direction pad on your Rotor Riot controller.
Tools
    1. Rotor Riot Direction Pad Replacement, Remove the iPhone mount: step 1, image 1 of 3 Rotor Riot Direction Pad Replacement, Remove the iPhone mount: step 1, image 2 of 3 Rotor Riot Direction Pad Replacement, Remove the iPhone mount: step 1, image 3 of 3
      • Use your fingers to remove the screw on the back side of the controller securing the iPhone mount.
      • Remove the iPhone mount.
      Ask FixBot
    2. Rotor Riot Direction Pad Replacement, Unscrew the back cover: step 2, image 1 of 1
      • Use a T6 Torx screwdriver to remove the eight 9.2 mm-long screws securing the back cover.
      • Don't try to remove the back cover all the way yet! It's still connected to the mainboard.
      Ask FixBot
    3. Rotor Riot Direction Pad Replacement, Swing open the back cover: step 3, image 1 of 3 Rotor Riot Direction Pad Replacement, Swing open the back cover: step 3, image 2 of 3 Rotor Riot Direction Pad Replacement, Swing open the back cover: step 3, image 3 of 3
      • Lift up the back cover of the controller.
      • Lift the back cover to a 45 degree angle and place it next to the controller.
      • Don't strain the interconnect cable during this procedure.
      Ask FixBot
    4. Rotor Riot Direction Pad Replacement, Disconnect the phone connector cable: step 4, image 1 of 3 Rotor Riot Direction Pad Replacement, Disconnect the phone connector cable: step 4, image 2 of 3 Rotor Riot Direction Pad Replacement, Disconnect the phone connector cable: step 4, image 3 of 3
      • Use a spudger to disconnect the phone connector cable from the mainboard.
      Ask FixBot
    5. Rotor Riot Direction Pad Replacement, Remove the back cover: step 5, image 1 of 1
      • Remove the back cover.
      Ask FixBot
    1. Rotor Riot Direction Pad Replacement, Remove the shoulder buttons: step 6, image 1 of 2 Rotor Riot Direction Pad Replacement, Remove the shoulder buttons: step 6, image 2 of 2
      • Remove the shoulder buttons by lifting them out of the case.
      Ask FixBot
    2. Rotor Riot Direction Pad Replacement, Unscrew the mainboard: step 7, image 1 of 1
      • Use a Phillips screwdriver to remove the four 7.0 mm-long screws securing the mainboard.
      Ask FixBot
    3. Rotor Riot Direction Pad Replacement, Flip over the mainboard: step 8, image 1 of 3 Rotor Riot Direction Pad Replacement, Flip over the mainboard: step 8, image 2 of 3 Rotor Riot Direction Pad Replacement, Flip over the mainboard: step 8, image 3 of 3
      • Flip over the mainboard and place it above the controller housing.
      • Avoid tensioning the trigger button cables during this procedure and don't try to remove the mainboard all the way yet! It is still connected to the controller housing.
      Ask FixBot
    4. Rotor Riot Direction Pad Replacement, Disconnect the trigger buttons: step 9, image 1 of 3 Rotor Riot Direction Pad Replacement, Disconnect the trigger buttons: step 9, image 2 of 3 Rotor Riot Direction Pad Replacement, Disconnect the trigger buttons: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of blunt nose tweezers to remove the left trigger button from the controller housing by lifting it straight out of its recess.
      • Repeat this procedure for the right trigger button.
      Ask FixBot
    5. Rotor Riot Direction Pad Replacement, Remove the mainboard: step 10, image 1 of 1
      • Remove the mainboard from the housing.
      Ask FixBot
    1. Rotor Riot Direction Pad Replacement, Unscrew the direction pad: step 11, image 1 of 1
      • Use a Phillips screwdriver to remove the 7.25 mm-long screw on the mainboard securing the direction pad.
      Ask FixBot
    2. Rotor Riot Direction Pad Replacement, Remove the direction pad: step 12, image 1 of 2 Rotor Riot Direction Pad Replacement, Remove the direction pad: step 12, image 2 of 2
      Buy
      • Use a pair of blunt nose tweezers to remove the direction pad.
      Ask FixBot
Adriana Zwink
69,432 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
120 Members
72,955 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 57
All Time: 716
