Shop the Holiday Gift Guide
Right Hinge Removal
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
43
All Time:
125
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Right Hinge Removal
Tools
    1. Right Hinge Removal, Remove the right earpad: step 1, image 1 of 2 Right Hinge Removal, Remove the right earpad: step 1, image 2 of 2
      • The earpads are secured with magnets
      • Lift the right earpad (labeled R) straight up and remove it.
      Ask FixBot
    1. Right Hinge Removal, Remove the right ear cup: step 2, image 1 of 3 Right Hinge Removal, Remove the right ear cup: step 2, image 2 of 3 Right Hinge Removal, Remove the right ear cup: step 2, image 3 of 3
      • Removing the ear cup isn’t required, but can make the repair easier. You can leave the cup attached and remove it later if needed.
      • Insert a SIM eject tool, bit, or a small, straightened paperclip into the hole on the top edge of the right ear cup (labeled R).
      • Push down with your tool and pull the headband connector straight out of its socket.
      • The headband connector should slide out easily. If you're having trouble, reposition the tool and try again—you may need to angle the bit slightly.
      Ask FixBot
    1. Right Hinge Removal, Set the right ear cup down: step 3, image 1 of 1
      • Set the right ear cup down on a soft, clean cloth to prevent scratches and help stabilize the cup during your repair.
      Ask FixBot
    2. Right Hinge Removal, Turn the housing screws to the open position: step 4, image 1 of 2 Right Hinge Removal, Turn the housing screws to the open position: step 4, image 2 of 2
      • Turn these screws slowly and gently, stopping when you feel resistance—about 1/4 turn. If turned too far, the locking mechanism will break.
      • Use a P5 pentalobe screwdriver to turn (not remove) the four speaker housing screws to the unlocked position:
      • Turn the top left and bottom right screws counterclockwise.
      • Turn the top right and bottom left screws clockwise.
      Ask FixBot
    3. Right Hinge Removal, Soften the speaker housing adhesive: step 5, image 1 of 3 Right Hinge Removal, Soften the speaker housing adhesive: step 5, image 2 of 3 Right Hinge Removal, Soften the speaker housing adhesive: step 5, image 3 of 3
      Tool used on this step:
      iOpener
      $14.95
      Buy
      • The perimeter of the speaker housing is secured to the cup with adhesive. This step shows a few methods to soften the adhesive so you can pry up the housing. If one isn't working, try a different method.
      • Option 1: Apply a few drops of high-concentration isopropyl alcohol (>90%) in the gap around the perimeter of the speaker housing. Wait one minute to allow the alcohol to soften the adhesive.
      • Option 2: Heat the speaker housing with an iOpener or hair dryer. Focus the heat around the perimeter, applying small amounts for short periods of time.
      • Don't heat the center of the speaker housing, or you'll damage the fragile mesh under the speaker cutouts and possibly the speaker.
      • For a detailed look at best practices for using a hair dryer, check out this guide.
      Ask FixBot
    4. Right Hinge Removal, Pry up the speaker housing: step 6, image 1 of 3 Right Hinge Removal, Pry up the speaker housing: step 6, image 2 of 3 Right Hinge Removal, Pry up the speaker housing: step 6, image 3 of 3
      iSesamo Opening Tool
      $10.99
      Buy
      • The gap between the speaker housing and ear cup is extremely small. You'll need a thin tool such as a metal opening pick, iSesamo, or iFlex to pry up the housing.
      • Don't grip the iFlex or similar metal tools by the edges—they're sharp and may cut you. Consider wearing gloves to protect yourself.
      • Insert the flat side of your opening tool into the gap between the left side of the speaker housing and the lip of the ear cup (opposite the R marking).
      • Pry up the speaker housing until you can grip it with your fingers, applying constant pressure to allow the adhesive to separate.
      • If the housing isn't coming up, repeat the previous step and try again. Don't try and force the housing out or you may damage it.
      Ask FixBot
    5. Right Hinge Removal: step 7, image 1 of 3 Right Hinge Removal: step 7, image 2 of 3 Right Hinge Removal: step 7, image 3 of 3
      • Don't try to fully remove the speaker housing yet—a delicate ribbon cable still connects it to the ear cup.
      • Lift the speaker housing out of the ear cup to fully separate the remaining adhesive.
      • Flip the housing over the side of the cup and prop it up so you can access the cable.
      Ask FixBot
    6. Right Hinge Removal, Remove the speaker housing cable cover: step 8, image 1 of 2 Right Hinge Removal, Remove the speaker housing cable cover: step 8, image 2 of 2
      FixMat
      $36.95
      Buy
      • Don’t let any screws snap onto the speaker driver diaphragm or they'll damage it. The screws will be drawn towards the center by the speaker's magnet.
      • Use a Torx Plus 1IP screwdriver to remove the 1.7 mm‑long screw securing the speaker housing cable cover.
      Ask FixBot
    7. Right Hinge Removal: step 9, image 1 of 2 Right Hinge Removal: step 9, image 2 of 2
      • Use tweezers to remove the cover.
      Ask FixBot
    8. Right Hinge Removal, Disconnect the speaker housing: step 10, image 1 of 2 Right Hinge Removal, Disconnect the speaker housing: step 10, image 2 of 2
      • Use a spudger to pry up and disconnect the speaker housing press connector.
      Ask FixBot
    9. Right Hinge Removal, Remove the speaker housing: step 11, image 1 of 1
      • Remove the speaker housing.
      Ask FixBot
    1. Right Hinge Removal, Remove the speaker driver screws: step 12, image 1 of 3 Right Hinge Removal, Remove the speaker driver screws: step 12, image 2 of 3 Right Hinge Removal, Remove the speaker driver screws: step 12, image 3 of 3
      • Grip the screws with tweezers while loosening and removing them. Don’t let the screws snap onto the diaphragm.
      • Use a Torx Plus 3IP screwdriver to remove three speaker driver screws:
      • Two 6.0 mm‑long screws
      • One 6.0 mm‑long screw that's slightly thicker than the other two
      • Remove the 5.1 mm‑long standoff screw using one of the two methods below:
      • Apply constant downward force to avoid damaging the screw.
      • Option 1: Stick a small flathead screwdriver into one of the four notches on top of the screw and use it to slowly turn the screw.
      • Option 2: Use a Torq-Set 6 screwdriver to remove the screw, applying constant downward force to avoid damaging the screw.
      Ask FixBot
    2. Right Hinge Removal, Remove the speaker driver: step 13, image 1 of 3 Right Hinge Removal, Remove the speaker driver: step 13, image 2 of 3 Right Hinge Removal, Remove the speaker driver: step 13, image 3 of 3
      • Lift the top edge of the speaker and remove it, being careful not to touch the diaphragm.
      • If you're having trouble, use the point of a spudger to start lifting the speaker.
      • Set the speaker aside in a place where it won't attract small metal objects.
      Ask FixBot
    1. Right Hinge Removal, Remove the battery connector cover: step 14, image 1 of 2 Right Hinge Removal, Remove the battery connector cover: step 14, image 2 of 2
      • Remove the two connector cover screws:
      • One 7.0 mm‑long Torx Plus 3IP screw
      • You may need tweezers to remove this screw.
      • One 1.7 mm‑long Torx Plus 1IP screw
      Ask FixBot
    2. Right Hinge Removal: step 15, image 1 of 3 Right Hinge Removal: step 15, image 2 of 3 Right Hinge Removal: step 15, image 3 of 3
      • Two tabs slot into place and secure the cover.
      • Slide the cover out of the slots and remove it.
      Ask FixBot
    3. Right Hinge Removal, Disconnect the battery: step 16, image 1 of 2 Right Hinge Removal, Disconnect the battery: step 16, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the battery press connector (the smaller one, not the one that folds under the board).
      Ask FixBot
    4. Right Hinge Removal, Remove the battery screws: step 17, image 1 of 3 Right Hinge Removal, Remove the battery screws: step 17, image 2 of 3 Right Hinge Removal, Remove the battery screws: step 17, image 3 of 3
      Flexible Extension
      $6.99
      Buy
      • Use a Torx Plus 5IP screwdriver to remove the two screws securing the sides of the battery cells.
      • Depending on your screwdriver, you may need to use a flexible extension to get a proper fit in the screw.
      • If the screw isn't coming out once fully loosened, use tweezers to pull it out.
      Ask FixBot
    5. Right Hinge Removal: step 18, image 1 of 3 Right Hinge Removal: step 18, image 2 of 3 Right Hinge Removal: step 18, image 3 of 3
      • Use a Torx Plus 3IP screwdriver to remove the three screws securing the battery cells:
      • Two 4.0 mm‑long screws
      • One 7.0 mm‑long screw
      • Make sure you remove the correct screw (which goes through the board), and not the one just to the left of it.
      • You may need to use tweezers to remove this screw.
      Ask FixBot
    6. Right Hinge Removal, Remove the battery: step 19, image 1 of 3 Right Hinge Removal, Remove the battery: step 19, image 2 of 3 Right Hinge Removal, Remove the battery: step 19, image 3 of 3
      • Slide the battery cells out of their recesses one at a time and remove them.
      • If either of the battery cells are swollen, take appropriate precautions.
      Ask FixBot
    1. Right Hinge Removal, Remove the power board connector cover: step 20, image 1 of 2 Right Hinge Removal, Remove the power board connector cover: step 20, image 2 of 2
      • Use a Torx Plus 1IP screwdriver to remove the two 1.7 mm‑long screws securing the power board connectors cover.
      Ask FixBot
    2. Right Hinge Removal: step 21, image 1 of 2 Right Hinge Removal: step 21, image 2 of 2
      • The cover may be lightly secured with adhesive.
      Ask FixBot
    3. Right Hinge Removal, Disconnect the power board: step 22, image 1 of 3 Right Hinge Removal, Disconnect the power board: step 22, image 2 of 3 Right Hinge Removal, Disconnect the power board: step 22, image 3 of 3
      • Use a spudger to pry up and disconnect the three press connectors on the power board.
      Ask FixBot
    4. Right Hinge Removal, Remove the power board screws: step 23, image 1 of 3 Right Hinge Removal, Remove the power board screws: step 23, image 2 of 3 Right Hinge Removal, Remove the power board screws: step 23, image 3 of 3
      • Use a Torx Plus 3IP screwdriver to remove the two 5.7 mm‑long screws securing the power board.
      • Make sure not to lose the small rubber gasket on the screws.
      Ask FixBot
    5. Right Hinge Removal, Reposition the power board: step 24, image 1 of 3 Right Hinge Removal, Reposition the power board: step 24, image 2 of 3 Right Hinge Removal, Reposition the power board: step 24, image 3 of 3
      • Be careful not to grip any of the small, surface-mounted components on the power board.
      • Slowly pull the power board out of its recess and flip it over the side of the ear cup, giving you access to the connector on the underside.
      • Make sure the cables that connect to the board don't get snagged.
      Ask FixBot
    6. Right Hinge Removal, Disconnect the power board: step 25, image 1 of 3 Right Hinge Removal, Disconnect the power board: step 25, image 2 of 3 Right Hinge Removal, Disconnect the power board: step 25, image 3 of 3
      • Disconnecting the power board cable is tricky and may take a few tries. Don't try to disconnect it by pulling on the cable, or you may cause damage.
      • Use the point of a spudger to press on alternating sides of the sliding connector tabs to "walk" it out of the socket.
      Ask FixBot
    7. Right Hinge Removal, Remove the power board: step 26, image 1 of 1
      • Remove the power board.
      Ask FixBot
    1. Right Hinge Removal, Remove the connector cover screws: step 27, image 1 of 2 Right Hinge Removal, Remove the connector cover screws: step 27, image 2 of 2
      • Use a Torx Plus 1IP screwdriver to remove the two 1.7 mm‑long screws securing the connector cover.
      Ask FixBot
    2. Right Hinge Removal, Lift the connector cover: step 28, image 1 of 2 Right Hinge Removal, Lift the connector cover: step 28, image 2 of 2
      • The other end of the cover is plastic-riveted into place. Unless you're comfortable soldering off the rivets, this requires you to bend the cover.
      • Use your finger to lift and bend the cover enough that you can access the smaller connector near the back of the cover.
      • Only bend the cover enough to reach the connector. The more you bend it, the harder it will be to push back into place during reassembly.
      Ask FixBot
    3. Right Hinge Removal, Disconnect the hinge: step 29, image 1 of 2 Right Hinge Removal, Disconnect the hinge: step 29, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the hinge press connector (the smaller one, whose cable runs back towards the hinge).
      Ask FixBot
    4. Right Hinge Removal, Unclip the hinge cable: step 30, image 1 of 2 Right Hinge Removal, Unclip the hinge cable: step 30, image 2 of 2
      • Use your fingers to gently pull the copper hinge cable (in plastic tubing) out of its clip.
      Ask FixBot
    5. Right Hinge Removal, Remove the hinge screws: step 31, image 1 of 2 Right Hinge Removal, Remove the hinge screws: step 31, image 2 of 2
      • Use a Torx Plus 5IP screwdriver to remove the four 5.3 mm‑long screws securing the hinge.
      • You may need to use a flexible extension for these screws.
      Ask FixBot
    6. Right Hinge Removal, Remove the hinge: step 32, image 1 of 3 Right Hinge Removal, Remove the hinge: step 32, image 2 of 3 Right Hinge Removal, Remove the hinge: step 32, image 3 of 3
      • Slide the point of a spudger into one of the hinge's lower screw holes.
      • Use the spudger to rotate the bottom edge of the hinge upwards to free the hinge.
      • This is tricky, as the hinge fits tightly in its recess. If you're having trouble, gently wiggle the hinge while rotating it.
      • Remove the hinge.
      Ask FixBot
Finish Line
Spencer Day
210,392 Reputation
1,265 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 43
All Time: 125
