Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement
  1. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement, Motor Housing with Handle Assembly: step 1, image 1 of 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement, Motor Housing with Handle Assembly: step 1, image 2 of 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement, Motor Housing with Handle Assembly: step 1, image 3 of 3
    • Remove the brush assembly with a flat head screwdriver.
  2. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: step 2, image 1 of 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: step 2, image 2 of 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: step 2, image 3 of 3
    • Use a T25 Torx screwdriver to remove 3 (M5 x 58 mm) screws.
  3. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: step 3, image 1 of 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: step 3, image 2 of 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: step 3, image 3 of 3
    • Use a T20 Torx screwdriver to remove the (1/4-20 x 0.66 in.) screw.
    • After removing the (1/4-20 x 0.66 in.) screw the lever assembly can be unscrewed from the (1/4-20 x 0.66 in.) screw.
  4. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: step 4, image 1 of 2 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: step 4, image 2 of 2
    • The motor housing assembly can now be removed from the rest of the saw.
Joshua Caron
792 Reputation
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 6
All Time: 359
