Introduction
The Motor Housing with Handle Assembly on a circular saw is one of the only pastic items on the saw which inside the saw. If Motor Housing or Handle Assembly breaks or gets damaged this guide will help replace them. Replacing the Motor Housing with Handle Assembly is very moderatly easy and doesn’t require any methods that are complicated.
Use a T20 Torx screwdriver to remove the (1/4-20 x 0.66 in.) screw.
After removing the (1/4-20 x 0.66 in.) screw the lever assembly can be unscrewed from the (1/4-20 x 0.66 in.) screw.
