Community-Contributed Guide
Introduction
Go to step 1 ↓If no more coffee comes out, one of the solenoid valves may not be working. To check, you can use the test mode, which will allow you to hear the valves clicking quietly. If you don't hear a click, it is probably defective.
Note: The opening is shown on a different model; there are slight visual differences.
Tools
Remove all attachments such as water tank, pulp drawer, brew group.
Turn the machine with the back facing you.
Remove five Torx T20 security screws.
Push the side panel back about 1.5 cm.
Lift off the panel.
The following compononents are exposed:
Heater
Expansion chamber
Gear drive
Steam valve
Pull out the clip between the solenoid valve and the pressure relief valve.
Lift the pressure relief valve upwards.
There is a seal between them. It will probably get stuck in the pressure relief valve. Remove it and replace it with a new one.
Pull the valve together with the rubber sleeve away from the machine toward you.
Note how the cables are connected and remove all the blade terminals.
Remove the clamps and take out the hoses.
There is a seal ring between them. It will probably remain stuck in the solenoid valve. Remove it and replace it with a new one.
Follow the steps in reverse order to reassemble your device.
3 other people completed this guide.
Special thanks to these translators:
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
