Replace Bosch MFQ1308 spur gear
  1. Replace Bosch MFQ1308 spur gear, Spur gear: step 1, image 1 of 1
    • Here are the new spur gears. The spare part number at BSH is Bosch 00027660
  2. Replace Bosch MFQ1308 spur gear: step 2, image 1 of 2 Replace Bosch MFQ1308 spur gear: step 2, image 2 of 2
    • Place the hand mixer so the bottom is facing you.
    • There are three long #2 Phillips screws in recessed holes. remove those.
    • Keep the screws safe.
  3. Replace Bosch MFQ1308 spur gear: step 3, image 1 of 1
    • With a little force pull the upper part of the housing upwards
  4. Replace Bosch MFQ1308 spur gear: step 4, image 1 of 1
    • Lay the device on the table with the underside.
    • The two spur gears are clearly visible, probably also the worn areas in the helical gearing.
  5. Replace Bosch MFQ1308 spur gear: step 5, image 1 of 3 Replace Bosch MFQ1308 spur gear: step 5, image 2 of 3 Replace Bosch MFQ1308 spur gear: step 5, image 3 of 3
    • The spur gears are fixed from above by a metal plate. This metal plate is inserted into a large plastic tab on both sides.
    • Gently push one of the two tabs outwards a little until the metal plate comes out of the slot.
    • Lift the metal plate complete with the controller and tensioner up and away and set it aside.
    • The two clamps for the stirring inserts are on top of the spur gears. Just lift them out
  6. Replace Bosch MFQ1308 spur gear: step 6, image 1 of 2 Replace Bosch MFQ1308 spur gear: step 6, image 2 of 2
    • Lift out the two spur gears.
    • There is a plastic washer on the axle of the spur gears. Transfer that to the two spare parts.
    • Before you put everything back together, you should clean the inside of the device well.
    • Grease the parts with a little food-grade silicone grease.
Work the steps in reverse order to reassemble your device.
2 other people completed this guide.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
203,741 Reputation
246 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
25 Members
1,127 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 39
All Time: 1,063
