Remove Siemens EQ Series side panel (tank side).
  1. Remove Siemens EQ Series side panel (tank side)., Remove Siemens EQ Series side panel (tank side).: step 1, image 1 of 1
    • Never forget: pull out the mains plug!
    • Remove all attachments such as water tank, pulp drawer, brew group.
    • Remove the coffee container lid and take out all the coffee beans.
  2. Remove Siemens EQ Series side panel (tank side).: step 2, image 1 of 1
    • Unscrew the two Torx T10 screws at the top of the right side panel.
    • Some models do not have these screws. Then the side parts are only held by catches, some of which clamp very strongly. You may have to detach the back part first.
  3. Remove Siemens EQ Series side panel (tank side).: step 3, image 1 of 3 Remove Siemens EQ Series side panel (tank side).: step 3, image 2 of 3 Remove Siemens EQ Series side panel (tank side).: step 3, image 3 of 3
    • Lay the machine on its side with the water tank side facing up.
    • The side panel is essentially held on the ground by five strong catches. Pry up the pegs with a strong prying tool. It's pretty difficult and you need a lot of strength.
    • If the catches are loose, you can pull the side panel away from below. But it's still stuck in other places.
    • Use a plastic tool to pry the top cover up a few millimeters and lift off the side panel. Most of the time it's still stuck, especially at the front edge, you have to pull hard.
  4. Remove Siemens EQ Series side panel (tank side).: step 4, image 1 of 1
    • You may need to pry the front edge with a plastic tool.
    • Lift the side panel off, but don't remove it completely yet. It is still connected with a silicone tube.
    • The water tank lid is located at the top of the side panel. Lift it up off the hinges.
  5. Remove Siemens EQ Series side panel (tank side).: step 5, image 1 of 1
    • Pull off the silicone hose that leads to the water connection of the tank from the inside.
  6. Remove Siemens EQ Series side panel (tank side).: step 6, image 1 of 2 Remove Siemens EQ Series side panel (tank side).: step 6, image 2 of 2
    • Remove the cover over the electronics.
    • The second picture shows the most important components:
    • heater
    • Ceramic valve/Brew valve (depending on model)
    • electronics
    • pump
    • mute
    • flow meter
Follow the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
203,187 Reputation
246 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
25 Members
1,120 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 24
All Time: 590
