RCA RCT6203W46 Rear Speaker Replacement
  1. RCA RCT6203W46 Rear Speaker Replacement, Rear Speaker: step 1, image 1 of 2 RCA RCT6203W46 Rear Speaker Replacement, Rear Speaker: step 1, image 2 of 2
    • Remove these four 4 mm Phillips #00 screws.
  2. RCA RCT6203W46 Rear Speaker Replacement: step 2, image 1 of 2 RCA RCT6203W46 Rear Speaker Replacement: step 2, image 2 of 2
    • Run a spudger tool around the edge of the screen to loosen it and begin to pry upward.
    • The screen will be able to be removed once you see it pop up like it has in the photo.
    • There are wires attached to the back cover and screen so be careful not to pull them apart.
  3. RCA RCT6203W46 Rear Speaker Replacement: step 3, image 1 of 3 RCA RCT6203W46 Rear Speaker Replacement: step 3, image 2 of 3 RCA RCT6203W46 Rear Speaker Replacement: step 3, image 3 of 3
    • With a soldering iron, remove the wires from the circuit board.
    • Due to the size of the wires, tweezers may be necessary.
  4. RCA RCT6203W46 Rear Speaker Replacement: step 4, image 1 of 1
    • Use a metal spudger to pry out the speakers from its housing.
Nicholas Alexander
318 Reputation
2 Guides authored
UC Davis, Team 1-2, Oliver Fall 2016 Member of UC Davis, Team 1-2, Oliver Fall 2016
UCD-OLIVER-F16S1G2
5 Members
4 Guides authored
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 4
All Time: 355
