Shop the Holiday Gift Guide
Punkt MP02 Battery Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
27
Past 30 Days:
154
All Time:
879
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
If your phone's battery seems to drain very quickly and it can no longer hold a charge, you may consider replacing your phone's battery. This guide will help you quickly and easily change the battery in your Punkt MP02. Check our battery troubleshooting page to ensure that your phone requires a new battery first. Before you begin, backup important data, and power off the device to ensure no data loss throughout the process.
If the battery is puffy or swollen, the battery is a fire hazard. Carefully remove and handle it according to iFixit's guide on handling swollen batteries.
Tools
    1. Punkt MP02 Battery Replacement, Battery: step 1, image 1 of 2 Punkt MP02 Battery Replacement, Battery: step 1, image 2 of 2
      • Use a SIM card eject tool to to eject and remove the SIM card tray on the side of the phone.
      Ask FixBot
    2. Punkt MP02 Battery Replacement: step 2, image 1 of 2 Punkt MP02 Battery Replacement: step 2, image 2 of 2
      • The back panel is held on by glue and multiple tabs.
      • Slide a Jimmy into the seam between the back panel and the chassis.
      • Slide the Jimmy around the perimeter to release the back panel, with care not to damage the retaining clips.
      • Clean any old adhesive with a spudger and isopropyl alcohol, then apply new adhesive to the back panel before reinstalling it.
      Ask FixBot
    3. Punkt MP02 Battery Replacement: step 3, image 1 of 3 Punkt MP02 Battery Replacement: step 3, image 2 of 3 Punkt MP02 Battery Replacement: step 3, image 3 of 3
      • Use a Phillips screwdriver to remove the two adjacent 3 mm Phillips screws.
      Ask FixBot
    4. Punkt MP02 Battery Replacement: step 4, image 1 of 3 Punkt MP02 Battery Replacement: step 4, image 2 of 3 Punkt MP02 Battery Replacement: step 4, image 3 of 3
      • Insert a Jimmy into the seam between the front and back case.
      • Slide the Jimmy around the perimeter while prying to separate the front and back case.
      Ask FixBot
    5. Punkt MP02 Battery Replacement: step 5, image 1 of 2 Punkt MP02 Battery Replacement: step 5, image 2 of 2
      • Use a spudger to pry up and disconnect the battery press connector.
      • Make sure to pry under the connector itself and not on the board.
      Ask FixBot
    6. Punkt MP02 Battery Replacement: step 6, image 1 of 2 Punkt MP02 Battery Replacement: step 6, image 2 of 2
      • Gently pry the battery off with the spudger tool.
      • Take care not to bend, warp, or puncture the battery during removal.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
Elias Fischer
425 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 154
All Time: 879
