Princess Digital Aerofryer XXL Thermal Fuse Replacement
  1. Princess Digital Aerofryer XXL Thermal Fuse Replacement, Getting in: step 1, image 1 of 3 Princess Digital Aerofryer XXL Thermal Fuse Replacement, Getting in: step 1, image 2 of 3 Princess Digital Aerofryer XXL Thermal Fuse Replacement, Getting in: step 1, image 3 of 3
    • Don't forget to unplug it!
    • Remove the drawer and any remaining fries.
    • On the top side of the product there is a panel held in place by 6 very snappy snap fingers. I am not kidding, these are strong!
    • When you work on one corner the others can snap back in place. To prevent this insert an opening tool or other objects in the gaps you created after lifting a corner.
    • My metal spudger was actually bending under the force, this is normal.
  2. Princess Digital Aerofryer XXL Thermal Fuse Replacement, Removing the top: step 2, image 1 of 2 Princess Digital Aerofryer XXL Thermal Fuse Replacement, Removing the top: step 2, image 2 of 2
    • Remove 4 screws on top.
    • Than just lift the top half of the casing. This doesn't take much force, as there are no more snap fingers.
    • Be careful, there are still 2 connectors attached!
    • Remove these two connectors
  3. Princess Digital Aerofryer XXL Thermal Fuse Replacement, Unscrew the next layer: step 3, image 1 of 1
    • Unscrew these 6 screws on the edge of the product.
  4. Princess Digital Aerofryer XXL Thermal Fuse Replacement, More screws: step 4, image 1 of 1
    • After unscrewing the middle layer of the product, turn it upside down on top of the bottom part of the product.
    • Be careful, there are still some cables connected to the bottom part.
    • Unscrew some more screws (10x).
  5. Princess Digital Aerofryer XXL Thermal Fuse Replacement, Righty Loosy: step 5, image 1 of 1
    • With one hand hold down the fan blade to stop it from turning.
    • With the other unscrew the nut that keeps the fan blade in. You can use pliers or an #10 hex driver to do this
    • TURN CLOCKWISE to unscrew
  6. Princess Digital Aerofryer XXL Thermal Fuse Replacement, Almost there: step 6, image 1 of 1
    • Unscrew three more screws. These are located underneath the heater coil
  7. Princess Digital Aerofryer XXL Thermal Fuse Replacement, Open the middle part: step 7, image 1 of 1
    • Now you can open the middle part of the housing, this requires little to no force.
  8. Princess Digital Aerofryer XXL Thermal Fuse Replacement: step 8, image 1 of 1
    • Unscrew the screw keeping the thermal fuse in.
    • A thermal fuse should work like a piece of copper wire (electronically speaking) when not broken. It will have a very very small resistance between 0 and 1 OHM.
    • A broken fuse will give an open loop (O.L. on most multimeters).
    • Do NOT solder the fuse!
    • I used the clips attached to a donor fuse to reattach to the cables. I did this by bending the clips out using cutting pliers and than bending them back using regular pliers.
Guido Schoots
181 Reputation
1 Guide authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 40
All Time: 2,323
