Shop the Holiday Gift Guide
Power Board Removal
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
41
All Time:
113
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Power Board Removal
Tools
    1. Power Board Removal, Remove the right earpad: step 1, image 1 of 2 Power Board Removal, Remove the right earpad: step 1, image 2 of 2
      • The earpads are secured with magnets
      • Lift the right earpad (labeled R) straight up and remove it.
      Ask FixBot
    1. Power Board Removal, Remove the right ear cup: step 2, image 1 of 3 Power Board Removal, Remove the right ear cup: step 2, image 2 of 3 Power Board Removal, Remove the right ear cup: step 2, image 3 of 3
      • Removing the ear cup isn’t required, but can make the repair easier. You can leave the cup attached and remove it later if needed.
      • Insert a SIM eject tool, bit, or a small, straightened paperclip into the hole on the top edge of the right ear cup (labeled R).
      • Push down with your tool and pull the headband connector straight out of its socket.
      • The headband connector should slide out easily. If you're having trouble, reposition the tool and try again—you may need to angle the bit slightly.
      Ask FixBot
    1. Power Board Removal, Set the right ear cup down: step 3, image 1 of 1
      • Set the right ear cup down on a soft, clean cloth to prevent scratches and help stabilize the cup during your repair.
      Ask FixBot
    2. Power Board Removal, Turn the housing screws to the open position: step 4, image 1 of 2 Power Board Removal, Turn the housing screws to the open position: step 4, image 2 of 2
      • Turn these screws slowly and gently, stopping when you feel resistance—about 1/4 turn. If turned too far, the locking mechanism will break.
      • Use a P5 pentalobe screwdriver to turn (not remove) the four speaker housing screws to the unlocked position:
      • Turn the top left and bottom right screws counterclockwise.
      • Turn the top right and bottom left screws clockwise.
      Ask FixBot
    3. Power Board Removal, Soften the speaker housing adhesive: step 5, image 1 of 3 Power Board Removal, Soften the speaker housing adhesive: step 5, image 2 of 3 Power Board Removal, Soften the speaker housing adhesive: step 5, image 3 of 3
      Tool used on this step:
      iOpener
      $14.95
      Buy
      • The perimeter of the speaker housing is secured to the cup with adhesive. This step shows a few methods to soften the adhesive so you can pry up the housing. If one isn't working, try a different method.
      • Option 1: Apply a few drops of high-concentration isopropyl alcohol (>90%) in the gap around the perimeter of the speaker housing. Wait one minute to allow the alcohol to soften the adhesive.
      • Option 2: Heat the speaker housing with an iOpener or hair dryer. Focus the heat around the perimeter, applying small amounts for short periods of time.
      • Don't heat the center of the speaker housing, or you'll damage the fragile mesh under the speaker cutouts and possibly the speaker.
      • For a detailed look at best practices for using a hair dryer, check out this guide.
      Ask FixBot
    4. Power Board Removal, Pry up the speaker housing: step 6, image 1 of 3 Power Board Removal, Pry up the speaker housing: step 6, image 2 of 3 Power Board Removal, Pry up the speaker housing: step 6, image 3 of 3
      iSesamo Opening Tool
      $10.99
      Buy
      • The gap between the speaker housing and ear cup is extremely small. You'll need a thin tool such as a metal opening pick, iSesamo, or iFlex to pry up the housing.
      • Don't grip the iFlex or similar metal tools by the edges—they're sharp and may cut you. Consider wearing gloves to protect yourself.
      • Insert the flat side of your opening tool into the gap between the left side of the speaker housing and the lip of the ear cup (opposite the R marking).
      • Pry up the speaker housing until you can grip it with your fingers, applying constant pressure to allow the adhesive to separate.
      • If the housing isn't coming up, repeat the previous step and try again. Don't try and force the housing out or you may damage it.
      Ask FixBot
    5. Power Board Removal: step 7, image 1 of 3 Power Board Removal: step 7, image 2 of 3 Power Board Removal: step 7, image 3 of 3
      • Don't try to fully remove the speaker housing yet—a delicate ribbon cable still connects it to the ear cup.
      • Lift the speaker housing out of the ear cup to fully separate the remaining adhesive.
      • Flip the housing over the side of the cup and prop it up so you can access the cable.
      Ask FixBot
    6. Power Board Removal, Remove the speaker housing cable cover: step 8, image 1 of 2 Power Board Removal, Remove the speaker housing cable cover: step 8, image 2 of 2
      FixMat
      $36.95
      Buy
      • Don’t let any screws snap onto the speaker driver diaphragm or they'll damage it. The screws will be drawn towards the center by the speaker's magnet.
      • Use a Torx Plus 1IP screwdriver to remove the 1.7 mm‑long screw securing the speaker housing cable cover.
      Ask FixBot
    7. Power Board Removal: step 9, image 1 of 2 Power Board Removal: step 9, image 2 of 2
      • Use tweezers to remove the cover.
      Ask FixBot
    8. Power Board Removal, Disconnect the speaker housing: step 10, image 1 of 2 Power Board Removal, Disconnect the speaker housing: step 10, image 2 of 2
      • Use a spudger to pry up and disconnect the speaker housing press connector.
      Ask FixBot
    9. Power Board Removal, Remove the speaker housing: step 11, image 1 of 1
      • Remove the speaker housing.
      Ask FixBot
    1. Power Board Removal, Remove the speaker driver screws: step 12, image 1 of 3 Power Board Removal, Remove the speaker driver screws: step 12, image 2 of 3 Power Board Removal, Remove the speaker driver screws: step 12, image 3 of 3
      • Grip the screws with tweezers while loosening and removing them. Don’t let the screws snap onto the diaphragm.
      • Use a Torx Plus 3IP screwdriver to remove three speaker driver screws:
      • Two 6.0 mm‑long screws
      • One 6.0 mm‑long screw that's slightly thicker than the other two
      • Remove the 5.1 mm‑long standoff screw using one of the two methods below:
      • Apply constant downward force to avoid damaging the screw.
      • Option 1: Stick a small flathead screwdriver into one of the four notches on top of the screw and use it to slowly turn the screw.
      • Option 2: Use a Torq-Set 6 screwdriver to remove the screw, applying constant downward force to avoid damaging the screw.
      Ask FixBot
    2. Power Board Removal, Remove the speaker driver: step 13, image 1 of 3 Power Board Removal, Remove the speaker driver: step 13, image 2 of 3 Power Board Removal, Remove the speaker driver: step 13, image 3 of 3
      • Lift the top edge of the speaker and remove it, being careful not to touch the diaphragm.
      • If you're having trouble, use the point of a spudger to start lifting the speaker.
      • Set the speaker aside in a place where it won't attract small metal objects.
      Ask FixBot
    1. Power Board Removal, Remove the battery connector cover: step 14, image 1 of 2 Power Board Removal, Remove the battery connector cover: step 14, image 2 of 2
      • Remove the two connector cover screws:
      • One 7.0 mm‑long Torx Plus 3IP screw
      • You may need tweezers to remove this screw.
      • One 1.7 mm‑long Torx Plus 1IP screw
      Ask FixBot
    2. Power Board Removal: step 15, image 1 of 3 Power Board Removal: step 15, image 2 of 3 Power Board Removal: step 15, image 3 of 3
      • Two tabs slot into place and secure the cover.
      • Slide the cover out of the slots and remove it.
      Ask FixBot
    3. Power Board Removal, Disconnect the battery: step 16, image 1 of 2 Power Board Removal, Disconnect the battery: step 16, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the battery press connector (the smaller one, not the one that folds under the board).
      Ask FixBot
    4. Power Board Removal, Remove the battery screws: step 17, image 1 of 3 Power Board Removal, Remove the battery screws: step 17, image 2 of 3 Power Board Removal, Remove the battery screws: step 17, image 3 of 3
      Flexible Extension
      $6.99
      Buy
      • Use a Torx Plus 5IP screwdriver to remove the two screws securing the sides of the battery cells.
      • Depending on your screwdriver, you may need to use a flexible extension to get a proper fit in the screw.
      • If the screw isn't coming out once fully loosened, use tweezers to pull it out.
      Ask FixBot
    5. Power Board Removal: step 18, image 1 of 3 Power Board Removal: step 18, image 2 of 3 Power Board Removal: step 18, image 3 of 3
      • Use a Torx Plus 3IP screwdriver to remove the three screws securing the battery cells:
      • Two 4.0 mm‑long screws
      • One 7.0 mm‑long screw
      • Make sure you remove the correct screw (which goes through the board), and not the one just to the left of it.
      • You may need to use tweezers to remove this screw.
      Ask FixBot
    6. Power Board Removal, Remove the battery: step 19, image 1 of 3 Power Board Removal, Remove the battery: step 19, image 2 of 3 Power Board Removal, Remove the battery: step 19, image 3 of 3
      • Slide the battery cells out of their recesses one at a time and remove them.
      • If either of the battery cells are swollen, take appropriate precautions.
      Ask FixBot
    1. Power Board Removal, Remove the power board connector cover: step 20, image 1 of 2 Power Board Removal, Remove the power board connector cover: step 20, image 2 of 2
      • Use a Torx Plus 1IP screwdriver to remove the two 1.7 mm‑long screws securing the power board connectors cover.
      Ask FixBot
    2. Power Board Removal: step 21, image 1 of 2 Power Board Removal: step 21, image 2 of 2
      • The cover may be lightly secured with adhesive.
      Ask FixBot
    3. Power Board Removal, Disconnect the power board: step 22, image 1 of 3 Power Board Removal, Disconnect the power board: step 22, image 2 of 3 Power Board Removal, Disconnect the power board: step 22, image 3 of 3
      • Use a spudger to pry up and disconnect the three press connectors on the power board.
      Ask FixBot
    4. Power Board Removal, Remove the power board screws: step 23, image 1 of 3 Power Board Removal, Remove the power board screws: step 23, image 2 of 3 Power Board Removal, Remove the power board screws: step 23, image 3 of 3
      • Use a Torx Plus 3IP screwdriver to remove the two 5.7 mm‑long screws securing the power board.
      • Make sure not to lose the small rubber gasket on the screws.
      Ask FixBot
    5. Power Board Removal, Reposition the power board: step 24, image 1 of 3 Power Board Removal, Reposition the power board: step 24, image 2 of 3 Power Board Removal, Reposition the power board: step 24, image 3 of 3
      • Be careful not to grip any of the small, surface-mounted components on the power board.
      • Slowly pull the power board out of its recess and flip it over the side of the ear cup, giving you access to the connector on the underside.
      • Make sure the cables that connect to the board don't get snagged.
      Ask FixBot
    6. Power Board Removal, Disconnect the power board: step 25, image 1 of 3 Power Board Removal, Disconnect the power board: step 25, image 2 of 3 Power Board Removal, Disconnect the power board: step 25, image 3 of 3
      • Disconnecting the power board cable is tricky and may take a few tries. Don't try to disconnect it by pulling on the cable, or you may cause damage.
      • Use the point of a spudger to press on alternating sides of the sliding connector tabs to "walk" it out of the socket.
      Ask FixBot
    7. Power Board Removal, Remove the power board: step 26, image 1 of 1
      • Remove the power board.
      Ask FixBot
Spencer Day
210,389 Reputation
1,265 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 41
All Time: 113
