Panasonic Camera DMC FX37 Battery Door Replacement
  1. Panasonic Camera DMC FX37 Battery Door Replacement, Battery Door: step 1, image 1 of 2 Panasonic Camera DMC FX37 Battery Door Replacement, Battery Door: step 1, image 2 of 2
    • Set the switch on the battery door to "open," and open the door.
  2. Panasonic Camera DMC FX37 Battery Door Replacement: step 2, image 1 of 1
    • At the left hand side, locate the head of the metal bar that holds the spring in place.
  3. Panasonic Camera DMC FX37 Battery Door Replacement: step 3, image 1 of 1
    • Push the metal bar down using the metal tweezers.
  4. Panasonic Camera DMC FX37 Battery Door Replacement: step 4, image 1 of 1
    • Pull the metal bar that holds the spring in place out.
    • You can also use tweezers for this step, although we found it easier to just use our fingers.
  5. Panasonic Camera DMC FX37 Battery Door Replacement: step 5, image 1 of 1
    • Remove the battery access door from the device.
    • In order to keep the "springiness" of the door, be sure that the long arm of the spring is not over the hole for the battery.
Zhentao
247 Reputation
2 Guides authored
Baylor, Team S2-G3, Johnson Spring 2018 Member of Baylor, Team S2-G3, Johnson Spring 2018
BU-JOHNSON-S18S2G3
3 Members
6 Guides authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 14
All Time: 264
