Panasonic Camera DMC FX37 Battery Door Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
111
All Time:
1,186
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 3 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you how to replace the door covering the battery compartment. Overall this guide does not take much knowledge regarding disassembly, however you should take care to remember how the parts are situated before removing them.
Tools
    1. Panasonic Camera DMC FX37 Battery Door Replacement, Battery Door: step 1, image 1 of 2 Panasonic Camera DMC FX37 Battery Door Replacement, Battery Door: step 1, image 2 of 2
      • Set the switch on the battery door to "open," and open the door.
      Ask FixBot
    2. Panasonic Camera DMC FX37 Battery Door Replacement: step 2, image 1 of 1
      • At the left hand side, locate the head of the metal bar that holds the spring in place.
      Ask FixBot
    3. Panasonic Camera DMC FX37 Battery Door Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Push the metal bar down using the metal tweezers.
      Ask FixBot
    4. Panasonic Camera DMC FX37 Battery Door Replacement: step 4, image 1 of 1
      • Pull the metal bar that holds the spring in place out.
      • You can also use tweezers for this step, although we found it easier to just use our fingers.
      Ask FixBot
    5. Panasonic Camera DMC FX37 Battery Door Replacement: step 5, image 1 of 1
      • Remove the battery access door from the device.
      • In order to keep the "springiness" of the door, be sure that the long arm of the spring is not over the hole for the battery.
      Ask FixBot
Zhentao
247 Reputation
2 Guides authored
Baylor, Team S2-G3, Johnson Spring 2018 Member of Baylor, Team S2-G3, Johnson Spring 2018
BU-JOHNSON-S18S2G3
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 111
All Time: 1,186
