Opening Procedure
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Opening Procedure, Remove the pentalobe screws: step 1, image 1 of 2 Opening Procedure, Remove the pentalobe screws: step 1, image 2 of 2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. Opening Procedure, Heat the lower edge of the phone: step 2, image 1 of 1
    • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  3. Opening Procedure, Apply suction cup(s): step 3, image 1 of 2 Opening Procedure, Apply suction cup(s): step 3, image 2 of 2
    • The next two steps demonstrate the iSclack, a handy tool that we recommend for anyone doing frequent repairs. If you aren't using the iSclack, skip down two steps for an alternate method.
    • If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger iPhones like the iPhone 11 Pro Max.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Press both suction cups firmly into place.
    • If your display or back glass is badly cracked, covering it with a layer of clear packing tape may help the suction cups adhere. The iSclack also includes two pieces of tape for this purpose.
  4. Opening Procedure: step 4, image 1 of 3 Opening Procedure: step 4, image 2 of 3 Opening Procedure: step 4, image 3 of 3
    • Hold onto your iPhone securely and close the handle of the iSclack to slightly separate the screen from the rear case of the phone.
    • Don't try to completely separate the screen; a small opening along the bottom edge is all you need.
    • Insert an opening pick into the gap under the display on the lower edge of the iPhone.
    • Skip the next two steps.
  5. Opening Procedure: step 5, image 1 of 2 Opening Procedure: step 5, image 2 of 2
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  6. Opening Procedure, Lift the display slightly: step 6, image 1 of 3 Opening Procedure, Lift the display slightly: step 6, image 2 of 3 Opening Procedure, Lift the display slightly: step 6, image 3 of 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  7. Opening Procedure, Separate the screen adhesive: step 7, image 1 of 3 Opening Procedure, Separate the screen adhesive: step 7, image 2 of 3 Opening Procedure, Separate the screen adhesive: step 7, image 3 of 3
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert the opening pick too far into the iPhone, or you may cause damage to internal components.
  8. Opening Procedure: step 8, image 1 of 3 Opening Procedure: step 8, image 2 of 3 Opening Procedure: step 8, image 3 of 3
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert the pick very far, or you may damage the display cables along this side of the iPhone. Insert it only a few millimeters, or about the width of the display bezel.
  9. Opening Procedure: step 9, image 1 of 3 Opening Procedure: step 9, image 2 of 3 Opening Procedure: step 9, image 3 of 3
    • The top edge of the display is secured with both glue and clips.
    • Gently pull the right edge of the display down slightly (in the direction of the Lightning port).
    • Insert your pick into the top-right corner of the phone.
  10. Opening Procedure: step 10, image 1 of 2 Opening Procedure: step 10, image 2 of 2
    • Continue pulling the display down (toward the Lightning port) as needed in order to make a gap large enough for the pick.
    • Slide the pick to the top left corner and cut any remaining adhesive securing the display.
    • Again, don't insert the pick more than a few millimeters—about the width of the display bezel—or you may damage the front panel sensor array.
  11. Opening Procedure, Remove the suction cup(s): step 11, image 1 of 1
    • Pull on the small nub on the suction cup to remove it from the front panel.
    • If you used an iSclack and it's still affixed to the iPhone, remove it now.
  12. Opening Procedure, Open the iPhone: step 12, image 1 of 3 Opening Procedure, Open the iPhone: step 12, image 2 of 3 Opening Procedure, Open the iPhone: step 12, image 3 of 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
Jeff Suovanen
428,933 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,410 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 203
