Introduction
Go to step 1 ↓Is your screen on your OnePlus 9 Pro cracked or shattered? If so, then use this guide to replace it.
When removing a cracked screen, it is important to tape the screen first to avoid the glass going everywhere.
When using a heat gun, always use caution since there is a chance to burn skin or surrounding areas of the workplace.
Use one of the opening picks to remove the adhesive on the lower part of the wireless charging cable
Unplug the press connector ribbon cable attached to the flash module by inserting a spudger under the bottom edge and prying straight up.
Use an opening pick to remove the flash module by the camera.
Use a Phillips #000 screwdriver to remove the eleven 4.9 mm-long screws holding the motherboard cover to the phone.
Use an opening pick to pry off the motherboard cover.
Use an opening pick or tweezers to carefully peel back the adhesive on the bottom of the wireless charging module.
Use the spudger to unplug the ribbon cable that connects the screen to the rest of the phone.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
