Introduction
Go to step 1 ↓Is your charging port broken/malfunctioning, is the wireless charging not functioning correctly, then this guide is for you. This guide helps you step by step take your OnePlus 9 Pro apart and change out your charging port/wireless charging cable.
Tools
Spudger4.9
Use one of the opening picks to remove the adhesive on the lower part of the wireless charging cable
Unplug the press connector ribbon cable attached to the flash module by inserting a spudger under the bottom edge and prying straight up.
Use an opening pick to remove the flash module by the camera.
Use a Phillips #000 screwdriver to remove the eleven 4.9 mm-long screws holding the motherboard cover to the phone.
Use an opening pick to pry off the motherboard cover.
Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
Press firmly to eject the tray.
Remove the SIM card tray.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
