Up to 20% off select tools
OnePlus 9 Pro Bottom Loudspeaker Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
19
Past 30 Days:
101
All Time:
861
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Does your OnePlus 9 Pro have no sound playing? Is the audio distorted, crackling, or popping? Are your favorite songs missing that awesome bass line or high violin trills? The issue might be your bottom loudspeaker. Be sure to check if there is debris or dust in the speaker. If not, use this guide to replace the bottom loudspeaker of your OnePlus 9 Pro.
In step 3, you will use a heat gun. Use caution when handling high heat and follow the instructions on the packaging carefully.
    1. OnePlus 9 Pro Bottom Loudspeaker Replacement, Rear Glass: step 1, image 1 of 1
      • For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
      • Unplug any chargers/peripheries and power off your phone.
      Ask FixBot
    2. OnePlus 9 Pro Bottom Loudspeaker Replacement: step 2, image 1 of 1
      Ask FixBot
    3. OnePlus 9 Pro Bottom Loudspeaker Replacement: step 3, image 1 of 2 OnePlus 9 Pro Bottom Loudspeaker Replacement: step 3, image 2 of 2
      • Use a hair dryer to lightly heat the perimeter of the rear glass.
      • Additionally, heat the top-right corner, as there is adhesive further inside of phone in that one spot.
      • Do not hold the hair dryer in one spot on the phone for too long to prevent damage to internal parts of the phone.
      Ask FixBot
    4. OnePlus 9 Pro Bottom Loudspeaker Replacement: step 4, image 1 of 1
      • Apply a suction handle as close to the bottom edge as possible.
      • Pull up on the suction handle with strong, steady force to create a gap between the glass and the frame.
      • If you have trouble creating a gap, apply more heat to further soften the adhesive.
      • Insert an opening pick into the gap.
      Ask FixBot
    5. OnePlus 9 Pro Bottom Loudspeaker Replacement: step 5, image 1 of 1
      • Slide the opening pick around the perimeter of the rear glass to slice the adhesive.
      • Insert additional opening picks as you slice the adhesive to prevent the adhesive from resealing.
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your hair dryer to reheat it.
      Ask FixBot
    6. OnePlus 9 Pro Bottom Loudspeaker Replacement: step 6, image 1 of 2 OnePlus 9 Pro Bottom Loudspeaker Replacement: step 6, image 2 of 2
      • Carefully lift the rear glass up and off of the phone.
      • During reassembly secure the rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      Ask FixBot
    1. OnePlus 9 Pro Bottom Loudspeaker Replacement, Bottom Loudspeaker: step 7, image 1 of 2 OnePlus 9 Pro Bottom Loudspeaker Replacement, Bottom Loudspeaker: step 7, image 2 of 2
      • Use one of the opening picks to remove the adhesive on the lower part of the wireless charging cable
      Ask FixBot
    2. OnePlus 9 Pro Bottom Loudspeaker Replacement: step 8, image 1 of 3 OnePlus 9 Pro Bottom Loudspeaker Replacement: step 8, image 2 of 3 OnePlus 9 Pro Bottom Loudspeaker Replacement: step 8, image 3 of 3
      • Unplug the press connector ribbon cable attached to the flash module by inserting a spudger under the bottom edge and prying straight up.
      • Use an opening pick to remove the flash module by the camera.
      • Use a Phillips #000 screwdriver to remove the eleven 4.9 mm-long screws holding the motherboard cover to the phone.
      • Use an opening pick to pry off the motherboard cover.
      Ask FixBot
    3. OnePlus 9 Pro Bottom Loudspeaker Replacement: step 9, image 1 of 1
      • Use a Phillips #000 screwdriver to remove five screws that secure the lower daughterboard cover.
      • Two of the screws have a white head and are 4.8 mm-long. They go in the bottom right corner of the daughter and mother board.
      • The other three screws are black and are also 4.8 mm-long.
      Ask FixBot
    4. OnePlus 9 Pro Bottom Loudspeaker Replacement: step 10, image 1 of 2 OnePlus 9 Pro Bottom Loudspeaker Replacement: step 10, image 2 of 2
      • Disconnect the two interconnect cables by inserting a spudger under each lip and prying straight up.
      Ask FixBot
    5. OnePlus 9 Pro Bottom Loudspeaker Replacement: step 11, image 1 of 1
      • Remove the three screws from the loudspeaker using a Phillips #000 screwdriver.
      Ask FixBot
    6. OnePlus 9 Pro Bottom Loudspeaker Replacement: step 12, image 1 of 1
      • Use the spudger to pry up and remove the loudspeaker.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
Brayan Santana
873 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 101
All Time: 861
