Shop the Holiday Gift Guide
OnePlus 8T Battery Disconnect
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
16
All Time:
299
Comments: 5
5 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Tools
    1. OnePlus 8T Battery Disconnect, Heat the rear glass: step 1, image 1 of 1
      • Switch off your phone.
      • Heat an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the rear glass removal.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. OnePlus 8T Battery Disconnect, Create a gap: step 2, image 1 of 3 OnePlus 8T Battery Disconnect, Create a gap: step 2, image 2 of 3 OnePlus 8T Battery Disconnect, Create a gap: step 2, image 3 of 3
      • Apply a suction cup to the back of the phone, as close as possible to the center of the bottom edge.
      • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Pull on the suction cup to create a gap between the rear glass and the frame.
      • Insert the tip of an opening pick into the gap and slide it to the bottom left corner.
      • Leave the opening pick in its place to prevent the adhesive from resealing.
      Ask FixBot
    3. OnePlus 8T Battery Disconnect, Slice the adhesive: step 3, image 1 of 2 OnePlus 8T Battery Disconnect, Slice the adhesive: step 3, image 2 of 2
      • Insert a second opening under the bottom left corner.
      • Slide the opening pick along the bottom edge to the bottom right corner.
      • Leave the pick in its place to prevent the adhesive from resealing.
      Ask FixBot
    4. OnePlus 8T Battery Disconnect, Slice the adhesive: step 4, image 1 of 3 OnePlus 8T Battery Disconnect, Slice the adhesive: step 4, image 2 of 3 OnePlus 8T Battery Disconnect, Slice the adhesive: step 4, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
      • Insert a third opening pick under the bottom right corner.
      • Slide the opening pick along the right edge to the top right corner.
      • Leave the opening picks in their place to prevent the adhesive from resealing.
      Ask FixBot
    5. OnePlus 8T Battery Disconnect, Slice the adhesive: step 5, image 1 of 2 OnePlus 8T Battery Disconnect, Slice the adhesive: step 5, image 2 of 2
      • Insert a fourth opening pick under the top right corner.
      • Slide it along the top edge to the top left corner to cut the adhesive.
      Ask FixBot
    6. OnePlus 8T Battery Disconnect, Slice the remaining adhesive: step 6, image 1 of 3 OnePlus 8T Battery Disconnect, Slice the remaining adhesive: step 6, image 2 of 3 OnePlus 8T Battery Disconnect, Slice the remaining adhesive: step 6, image 3 of 3
      • Insert a fifth opening pick under the top left corner.
      • Slide the opening pick along the left edge to the bottom left corner to cut the remaining adhesive.
      Ask FixBot
    7. OnePlus 8T Battery Disconnect, Remove the rear glass: step 7, image 1 of 1
      • Remove the rear glass.
      • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      Ask FixBot
    1. OnePlus 8T Battery Disconnect, Unscrew the motherboard cover: step 8, image 1 of 1
      • Use a Phillips screwdriver to remove the nine 3.8 mm-long screws securing the motherboard cover.
      Ask FixBot
    2. OnePlus 8T Battery Disconnect, Unclip the motherboard cover: step 9, image 1 of 3 OnePlus 8T Battery Disconnect, Unclip the motherboard cover: step 9, image 2 of 3 OnePlus 8T Battery Disconnect, Unclip the motherboard cover: step 9, image 3 of 3
      • Insert the tip of an opening pick under the bottom left corner of the motherboard cover.
      • Use the opening pick to lift the motherboard cover up and release the plastic clips that hold it in place.
      Ask FixBot
    3. OnePlus 8T Battery Disconnect, Remove the motherboard cover: step 10, image 1 of 1
      • Remove the motherboard cover.
      Ask FixBot
    4. OnePlus 8T Battery Disconnect, Disconnect the battery: step 11, image 1 of 2 OnePlus 8T Battery Disconnect, Disconnect the battery: step 11, image 2 of 2
      • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
      Ask FixBot
Adriana Zwink
69,845 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,954 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 299
