You're viewing a previously published version of this guide. View latest version
You will need a clean, well-lit area, an iFixit repair kit including the specialized screw driver, along with the Phillips #000 bit. We also recommend you have an organization tray in order to keep track of all the screws you will be taking out.
Remove nine 4.45mm Phillips #000 screws from the outside of the case.
There are four screws to take out on the bottom of the camera.
There are three screws to take out on this side.
There is one screw to take out on this side.
There is one hidden screw inside the HDMI port.
Using the blue plastic opening tool, wedge open and remove the case.
with 1 other contributor
515 Reputation
4 Guides authored
Badges: 9
+6 more badges
CNU-SOBIECH-S17S1G1
4 Members
8 Guides authored
Choose a size and copy the code below to embed this guide as a small widget on your site / forum.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 486
