Olympus Pen E-PL7 Back Case Replacement
  1. Olympus Pen E-PL7 Back Case Replacement, Back Case: step 1, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the six 2 mm screws on the bottom of the camera.
  2. Olympus Pen E-PL7 Back Case Replacement: step 2, image 1 of 1
    • Remove the two 4 mm reverse threaded Phillips screws from the bottom of the camera.
    • Reverse threaded screws tighten counter clockwise and loosen clockwise.
  3. Olympus Pen E-PL7 Back Case Replacement: step 3, image 1 of 1
    • Remove the two 4 mm Phillips screws under the HDMI port cover.
  4. Olympus Pen E-PL7 Back Case Replacement: step 4, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the 5 mm screw near the left hand grip.
  5. Olympus Pen E-PL7 Back Case Replacement: step 5, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the 5 mm screw near the right hand grip.
  6. Olympus Pen E-PL7 Back Case Replacement: step 6, image 1 of 1
    • Flip open the LCD.
    • Use a Phillips #00 screwdriver to remove the 2 mm screw beneath the LCD assembly.
  7. Olympus Pen E-PL7 Back Case Replacement: step 7, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the four 6.3 mm screws from the lens mount.
  8. Olympus Pen E-PL7 Back Case Replacement: step 8, image 1 of 1
    • Remove the lens mount with tweezers.
  9. Olympus Pen E-PL7 Back Case Replacement: step 9, image 1 of 1
    • Use tweezers to remove the inner metal ring.
  10. Olympus Pen E-PL7 Back Case Replacement: step 10, image 1 of 2 Olympus Pen E-PL7 Back Case Replacement: step 10, image 2 of 2
    • Use tweezers to remove the two springs lying beneath the inner metal ring.
  11. Olympus Pen E-PL7 Back Case Replacement: step 11, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the three 5 mm screws.
  12. Olympus Pen E-PL7 Back Case Replacement: step 12, image 1 of 1
    • Remove the two 4 mm Phillips screws.
  13. Olympus Pen E-PL7 Back Case Replacement: step 13, image 1 of 3 Olympus Pen E-PL7 Back Case Replacement: step 13, image 2 of 3 Olympus Pen E-PL7 Back Case Replacement: step 13, image 3 of 3
    • Press and hold the lens release button while using tweezers to remove the lens hook.
    • Use tweezers to remove the spring underneath the lens hook.
  14. Olympus Pen E-PL7 Back Case Replacement: step 14, image 1 of 3 Olympus Pen E-PL7 Back Case Replacement: step 14, image 2 of 3 Olympus Pen E-PL7 Back Case Replacement: step 14, image 3 of 3
    • Use tweezers to remove the metal clip from the external flash mount.
  15. Olympus Pen E-PL7 Back Case Replacement: step 15, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the four 4 mm screws from the external flash port.
  16. Olympus Pen E-PL7 Back Case Replacement: step 16, image 1 of 2 Olympus Pen E-PL7 Back Case Replacement: step 16, image 2 of 2
    • Remove the second external flash clip with tweezers.
  17. Olympus Pen E-PL7 Back Case Replacement: step 17, image 1 of 2 Olympus Pen E-PL7 Back Case Replacement: step 17, image 2 of 2
    • Remove the external flash port casing to expose five more screws.
  18. Olympus Pen E-PL7 Back Case Replacement: step 18, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the two 6.4 mm screws.
    • Remove the 2 mm Phillips screw.
  19. Olympus Pen E-PL7 Back Case Replacement: step 19, image 1 of 1
    • Remove the two 3.8 mm Phillips screws from the sides of the external flash connector.
  20. Olympus Pen E-PL7 Back Case Replacement: step 20, image 1 of 1
    • Gently pull the back case away from the camera.
    • Do not attempt to remove the back case, as it is attached to the camera by a ribbon cable.
  21. Olympus Pen E-PL7 Back Case Replacement: step 21, image 1 of 3 Olympus Pen E-PL7 Back Case Replacement: step 21, image 2 of 3 Olympus Pen E-PL7 Back Case Replacement: step 21, image 3 of 3
    • To remove the ribbon holding the back case to the camera, use the pointed end of a spudger to flip back the top bar on top of the ZIF connector.
  22. Olympus Pen E-PL7 Back Case Replacement: step 22, image 1 of 3 Olympus Pen E-PL7 Back Case Replacement: step 22, image 2 of 3 Olympus Pen E-PL7 Back Case Replacement: step 22, image 3 of 3
    • Use tweezers to pull the ribbon out of the connector.
    • Remove the back case.
Kelsea Weber
19,877 Reputation
32 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,198 Guides authored
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 44
All Time: 3,249
