Nokia Lumia 635 Display Assembly Replacement
Video Overview
  1. Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: step 1, image 1 of 3 Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: step 1, image 2 of 3 Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: step 1, image 3 of 3
    • Switch off the phone.
    • Remove the battery and any installed SIM and memory cards.
    • Remove the black tape near to the loudspeaker.
  2. Nokia Lumia 635 Display Assembly Replacement, SCREWS: step 2, image 1 of 3 Nokia Lumia 635 Display Assembly Replacement, SCREWS: step 2, image 2 of 3 Nokia Lumia 635 Display Assembly Replacement, SCREWS: step 2, image 3 of 3
    • Remove the 9x Torx T4 screws.
    • Two of them are with the same head size but with a different length.
  3. Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: step 3, image 1 of 3 Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: step 3, image 2 of 3 Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: step 3, image 3 of 3
    • Use a plastic opening tool to remove the back cover.
    • Careful unhook the display assembly flex cable.
  4. Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 1: step 5, image 1 of 2 Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 1: step 5, image 2 of 2
    • Put some scotch tape to prevent the glass from scattering.
    • Use a hot gun or hair dryer and warm the glass to soften the adhesive.
  5. Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: step 6, image 1 of 3 Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: step 6, image 2 of 3 Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: step 6, image 3 of 3
    • Start the separating from the upper right corner, where you have an hole in the middle frame.
    • Use plastic tool to prevent the middle frame from scratches.
    • Work slowly, you can cut your fingers.
  6. Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: step 7, image 1 of 3 Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: step 7, image 2 of 3 Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: step 7, image 3 of 3
    • Clean the middle farme.
    • Put adhesive tape 3MM.
    • Be careful, don't cover the technological openings on the middle frame (for the light sensor, earpiece, etc.).
    • It's easier if you order the spare part together with an adhesive tape.
    • Install the display assembly.
  7. Nokia Lumia 635 Display Assembly Replacement: step 8, image 1 of 2 Nokia Lumia 635 Display Assembly Replacement: step 8, image 2 of 2
    • That's all.
    • Did you do it successfully?
ZFix
191,308 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,539 Guides authored
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 25
All Time: 9,828
