Nokia 2780 Flip Screen Replacement
    1. Nokia 2780 Flip Screen Replacement, Battery: step 1, image 1 of 1
      • Insert an iFixit opening tool into the seam between the back case and the bottom edge of the phone.
      • If possible, use a plastic prying tool instead of a metal one to reduce the risk of damaging delicate internal components like the battery or motherboard.
      Ask FixBot
    2. Nokia 2780 Flip Screen Replacement: step 2, image 1 of 1
      • Slide the opening tool or spudger around the edge of the phone to release the clips securing the bottom case.
      • Gently pry the bottom case from the phone to remove it.
      Ask FixBot
    3. Nokia 2780 Flip Screen Replacement: step 3, image 1 of 2 Nokia 2780 Flip Screen Replacement: step 3, image 2 of 2
      • Lift the battery up and out of the compartment.
      • Ensure the replacement battery is a “HE402 1450mAh 3.85V 5.58WH” Li-ion battery.
      Ask FixBot
    1. Nokia 2780 Flip Screen Replacement, Motherboard: step 4, image 1 of 2 Nokia 2780 Flip Screen Replacement, Motherboard: step 4, image 2 of 2
      • Use a Torx T5 screwdriver to remove the six visible 1.4 mm screws that secure the internal rear housing.
      Ask FixBot
    2. Nokia 2780 Flip Screen Replacement: step 5, image 1 of 2 Nokia 2780 Flip Screen Replacement: step 5, image 2 of 2
      • Insert a plastic opening tool in the seam between the top case and midframe and slide it around the perimeter to release the clips holding them together.
      • Remove the midframe from the phone.
      Ask FixBot
    3. Nokia 2780 Flip Screen Replacement: step 6, image 1 of 2 Nokia 2780 Flip Screen Replacement: step 6, image 2 of 2
      • Place a spudger or an opening tool under the edge of the press connector and pry straight up to disconnect it.
      • Make sure to pry under the edge of the connector itself, and not under the socket on the board. Otherwise, you risk permanently damaging the socket.
      • To reconnect, align the connector carefully over its socket and press down with your fingertip—first on one of the short sides, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    4. Nokia 2780 Flip Screen Replacement: step 7, image 1 of 2 Nokia 2780 Flip Screen Replacement: step 7, image 2 of 2
      • Remove the plastic cover on top of the hinge.
      Ask FixBot
    5. Nokia 2780 Flip Screen Replacement: step 8, image 1 of 3 Nokia 2780 Flip Screen Replacement: step 8, image 2 of 3 Nokia 2780 Flip Screen Replacement: step 8, image 3 of 3
      • Pull back the frame surrounding the motherboard from both sides and gently remove the motherboard.
      Ask FixBot
    1. Nokia 2780 Flip Screen Replacement, Screen: step 9, image 1 of 1
      • Use a plastic spudger and opening picks to pry the back cover from the display.
      Ask FixBot
    2. Nokia 2780 Flip Screen Replacement: step 10, image 1 of 1
      • Before removing the screen, apply heat to the edges to soften the adhesive securing it in place. This will make the screen easier to remove.
      • Use a suction handle to remove the old screen.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 121
All Time: 448
