Replacing Coffee Spout Manifold on Nivona Caferomatica 770
  1. Replacing Coffee Spout Manifold on Nivona Caferomatica 770, Coffee Spout Manifold: step 1, image 1 of 2 Replacing Coffee Spout Manifold on Nivona Caferomatica 770, Coffee Spout Manifold: step 1, image 2 of 2
    • Remove the plastic plate with the 'Nivona' label carefully with a plastic opening tool.
  2. Replacing Coffee Spout Manifold on Nivona Caferomatica 770: step 2, image 1 of 1
    • Behind it, you'll find a chrome bezel. It is mounted at the marked spots.
    • Push the mounting points with a plastic opening tool to the side and remove the bezel carefully.
  3. Replacing Coffee Spout Manifold on Nivona Caferomatica 770: step 3, image 1 of 3 Replacing Coffee Spout Manifold on Nivona Caferomatica 770: step 3, image 2 of 3 Replacing Coffee Spout Manifold on Nivona Caferomatica 770: step 3, image 3 of 3
    • Remove the LEDs of the cup lighting from their holding clips and bend them aside.
    • Leverage the holder of the lighting element off and remove it.
  4. Replacing Coffee Spout Manifold on Nivona Caferomatica 770: step 4, image 1 of 3 Replacing Coffee Spout Manifold on Nivona Caferomatica 770: step 4, image 2 of 3 Replacing Coffee Spout Manifold on Nivona Caferomatica 770: step 4, image 3 of 3
    • Now it is possible to remove the keypad with the display, it is only held by clips. Remove it carefully by hand.
    • The keypad is connected by a large wire harness to the machine. The wire harness won't be removed, the keypad will only be pushed out of the way.
  5. Replacing Coffee Spout Manifold on Nivona Caferomatica 770: step 5, image 1 of 3 Replacing Coffee Spout Manifold on Nivona Caferomatica 770: step 5, image 2 of 3 Replacing Coffee Spout Manifold on Nivona Caferomatica 770: step 5, image 3 of 3
    • Now the spout is easily accessible. It is only fixed in place by clips and can be removed via a flat screwdriver or spatula.
    • The spout is now only connected to the coffee hose made of silicone.
  6. Replacing Coffee Spout Manifold on Nivona Caferomatica 770: step 6, image 1 of 1
    • Pull the silicone hose off the coffee spout.
    • The coffee spout is disconnected.
Repeat the steps in reverse order to reassemble the device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
204,177 Reputation
246 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
25 Members
1,132 Guides authored
3 Comments
Toll beschrieben mit super Fotos.
Einfach sich Gedanken gemacht wie man es Schritt für Schritt es einem mitteilen kann wie es gemacht wird.
Super!
Gruß
Thomas
t.ohl - Reply
Super genaue Schritt für Schritt Anleitung und Fotos.
Einfach! toll
Gruß
Thomas
t.ohl - Reply
Freut mich, wenn es nützt.
VauWeh -
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 100
All Time: 7,593
