Nintendo Switch Micro SD Card Reader Replacement
  1. Nintendo Switch Micro SD Card Reader Replacement, Release the Joy Con controller locking tabs: step 1, image 1 of 3 Nintendo Switch Micro SD Card Reader Replacement, Release the Joy Con controller locking tabs: step 1, image 2 of 3 Nintendo Switch Micro SD Card Reader Replacement, Release the Joy Con controller locking tabs: step 1, image 3 of 3
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
    Ask FixBot
  2. Nintendo Switch Micro SD Card Reader Replacement, Remove the Joy Con controllers: step 2, image 1 of 3 Nintendo Switch Micro SD Card Reader Replacement, Remove the Joy Con controllers: step 2, image 2 of 3 Nintendo Switch Micro SD Card Reader Replacement, Remove the Joy Con controllers: step 2, image 3 of 3
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
    Ask FixBot
  3. Nintendo Switch Micro SD Card Reader Replacement, Remove the back-side screws: step 3, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
    • If you do happen to strip one of the four 6.3 mm-long Y00 screws, If you are lucky and careful, you may be able to use a Y0 bit to remove the screw(s). Please note that if you do attempt this, a bit of extra pressure will need to be applied to the screwdriver so that the screwdriver bit catches the screw.
    • If you do end up removing the stripped screw with this method, PLEASE do not reuse the screw again and instead replace the screw.
    Ask FixBot
  4. Nintendo Switch Micro SD Card Reader Replacement, Remove the top and bottom screws: step 4, image 1 of 2 Nintendo Switch Micro SD Card Reader Replacement, Remove the top and bottom screws: step 4, image 2 of 2
    • Use a JIS 00 driver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS 00 driver if the screws won't come out. Make sure the driver is fully inserted.
    • You can use a Phillips #000 screwdriver in a pinch, but you risk damaging or stripping the screws. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they are the same size.
    Ask FixBot
  5. Nintendo Switch Micro SD Card Reader Replacement, Remove the center side screws: step 5, image 1 of 2 Nintendo Switch Micro SD Card Reader Replacement, Remove the center side screws: step 5, image 2 of 2
    • Use a JIS 00 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
    Ask FixBot
  6. Nintendo Switch Micro SD Card Reader Replacement: step 6, image 1 of 2 Nintendo Switch Micro SD Card Reader Replacement: step 6, image 2 of 2
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
    Ask FixBot
  7. Nintendo Switch Micro SD Card Reader Replacement, Remove the kickstand well screw: step 7, image 1 of 1
    • Use a JIS 00 driver to remove the 1.6 mm screw in the kickstand well.
    • Close the kickstand.
    Ask FixBot
  8. Nintendo Switch Micro SD Card Reader Replacement, Remove the rear panel: step 8, image 1 of 3 Nintendo Switch Micro SD Card Reader Replacement, Remove the rear panel: step 8, image 2 of 3 Nintendo Switch Micro SD Card Reader Replacement, Remove the rear panel: step 8, image 3 of 3
    • Open the game card cartridge flap.
    • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
    • Lift the rear panel straight up from the bottom of the device and remove it.
    • Don't tilt it upwards while opening or else you risk breaking the plastic tabs on the top edge of the panel.
    Ask FixBot
  9. Nintendo Switch Micro SD Card Reader Replacement, Remove the microSD card reader: step 9, image 1 of 1
    • Use a JIS 00 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
    Ask FixBot
  10. Nintendo Switch Micro SD Card Reader Replacement: step 10, image 1 of 2 Nintendo Switch Micro SD Card Reader Replacement: step 10, image 2 of 2
    Buy
    • Use your fingers or a pair of tweezers to lift the microSD card reader straight up from the device to disconnect and remove it.
    • During reassembly, remove the foam pad before connecting the press connector to the motherboard. Set the foam pad back in place after you verify it's connected.
    Ask FixBot
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
178 other people completed this guide.
Craig Lloyd
42,948 Reputation
82 Guides authored
65 Guide Comments
My SD reader never worked.
Used this guide to find that it was never seated correctly. Reseated and now works perfectly. THANK YOU!
Finx O'Mally - Reply Share
My console won’t boot if I have an SD card inserted after reseating it. What should I do?
Ewan MacInnis - Reply Share
Dont. Just dont
Martin Vincent (i forgo) - Reply Share
Easy guide, fixed my problem. Changed the SD card reader cause I was abusing of it by putting SD in and out constantly.
Nicola Bonardi - Reply Share
Great guide! My 11-year-old son was able to fix his Switch himself with no difficulty.
Matt - Reply Share
Past 24 Hours: 83
Past 7 Days: 441
Past 30 Days: 2,202
All Time: 279,260
