Nintendo Switch 2 Hinges Replacement
    1. Nintendo Switch 2 Hinges Replacement, Power off the console: step 1, image 1 of 3 Nintendo Switch 2 Hinges Replacement, Power off the console: step 1, image 2 of 3 Nintendo Switch 2 Hinges Replacement, Power off the console: step 1, image 3 of 3
      • For your safety, discharge the battery below 25% before disassembling the console. This reduces the risk of a fire if the battery is damaged during the repair. If the battery is swollen, take appropriate precautions.
      • Remove any game cards and disconnect any cables, controllers, or other accessories from the console.
      • Power off the console by holding down the power button, selecting Power Options, then pressing Power Off.
      Ask FixBot
    2. Nintendo Switch 2 Hinges Replacement, Remove the bottom screws: step 2, image 1 of 2 Nintendo Switch 2 Hinges Replacement, Remove the bottom screws: step 2, image 2 of 2
      • Use a JIS 00 driver to remove the two 3.1 mm‑long screws on either side of the bottom USB-C port.
      • You can try a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the driver and twist slowly.
      Ask FixBot
    3. Nintendo Switch 2 Hinges Replacement, Remove the top screw: step 3, image 1 of 2 Nintendo Switch 2 Hinges Replacement, Remove the top screw: step 3, image 2 of 2
      • Use a JIS 00 driver to remove the 3.1 mm‑long screw on the top edge of the console (next to the ventilation cutouts).
      Ask FixBot
    4. Nintendo Switch 2 Hinges Replacement, Heat the right side sticker: step 4, image 1 of 1
      • The Switch 2 has stickers on either side that need to be removed to access the screws securing the back cover. It's easy to damage the stickers during removal, but you can mitigate this by regularly reheating the stickers and working carefully.
      • Use a hair dryer or heat gun to heat the sticker on the right side of the console, labeled with a "+" symbol, until it's hot to the touch.
      • You can use the kickstand to prop the console up vertically for easier access.
      • If you're using a heat gun, set it to low to avoid melting the plastic edge of the console.
      Ask FixBot
    5. Nintendo Switch 2 Hinges Replacement, Pry up the right side sticker: step 5, image 1 of 3 Nintendo Switch 2 Hinges Replacement, Pry up the right side sticker: step 5, image 2 of 3 Nintendo Switch 2 Hinges Replacement, Pry up the right side sticker: step 5, image 3 of 3
      • The pointed end of the tweezers can damage the sticker from the underside, leaving a noticeable mark. If it's difficult to lift, apply more heat instead of using more force.
      • Slide one arm of angled tweezers underneath the sticker from its cutout around the right Joy‑Con 2 connector.
      • Gently pry up on the sticker until it starts to lift from the console.
      • Leave the tweezers in place to keep the sticker lifted.
      Ask FixBot
    6. Nintendo Switch 2 Hinges Replacement: step 6, image 1 of 3 Nintendo Switch 2 Hinges Replacement: step 6, image 2 of 3 Nintendo Switch 2 Hinges Replacement: step 6, image 3 of 3
      Tool used on this step:
      Jimmy
      $7.95
      Buy
      • Insert the tip of a Jimmy into the gap formed between the long edge of the console and the sticker.
      • Gently pry up the sticker, working your way up the long edge until the top of the sticker is separated from the console.
      • Remove the tweezers once the sticker is lifted.
      • You can leave the Jimmy in place to hold the top of the sticker off the frame—if it falls back into its recess, repeat this procedure to lift it back up.
      Ask FixBot
    7. Nintendo Switch 2 Hinges Replacement, Heat the right side sticker: step 7, image 1 of 1
      • Reheat the bottom of the right side until it's hot to the touch.
      Ask FixBot
    8. Nintendo Switch 2 Hinges Replacement, Remove the right side sticker: step 8, image 1 of 3 Nintendo Switch 2 Hinges Replacement, Remove the right side sticker: step 8, image 2 of 3 Nintendo Switch 2 Hinges Replacement, Remove the right side sticker: step 8, image 3 of 3
      • Carefully lift the sticker over the Joy‑Con 2 connector, then peel it up fully to remove it.
      Ask FixBot
    9. Nintendo Switch 2 Hinges Replacement, Remove the left side sticker: step 9, image 1 of 3 Nintendo Switch 2 Hinges Replacement, Remove the left side sticker: step 9, image 2 of 3 Nintendo Switch 2 Hinges Replacement, Remove the left side sticker: step 9, image 3 of 3
      • Repeat this procedure to remove the sticker along the left side of the console, labeled with a "-" symbol.
      Ask FixBot
    10. Nintendo Switch 2 Hinges Replacement, Remove the side screws: step 10, image 1 of 2 Nintendo Switch 2 Hinges Replacement, Remove the side screws: step 10, image 2 of 2
      • Use a JIS 00 driver to remove the two 3.6 mm‑long gold screws on each side of the console (four in total).
      Ask FixBot
    11. Nintendo Switch 2 Hinges Replacement, Open the kickstand: step 11, image 1 of 3 Nintendo Switch 2 Hinges Replacement, Open the kickstand: step 11, image 2 of 3 Nintendo Switch 2 Hinges Replacement, Open the kickstand: step 11, image 3 of 3
      • Use your fingers to flip up the kickstand on the back of the console.
      • If there's a microSD Express card installed, remove it now before you continue to the next step.
      Ask FixBot
    12. Nintendo Switch 2 Hinges Replacement, Remove the back-side screws: step 12, image 1 of 2 Nintendo Switch 2 Hinges Replacement, Remove the back-side screws: step 12, image 2 of 2
      • Use a Y00 driver to remove the two 4.4 mm‑long screws in the kickstand cutout.
      Ask FixBot
    13. Nintendo Switch 2 Hinges Replacement, Insert an opening pick: step 13, image 1 of 2 Nintendo Switch 2 Hinges Replacement, Insert an opening pick: step 13, image 2 of 2
      • Insert an opening pick into the gap between the back cover and speaker cutout on the bottom edge of the console.
      Ask FixBot
    14. Nintendo Switch 2 Hinges Replacement: step 14, image 1 of 2 Nintendo Switch 2 Hinges Replacement: step 14, image 2 of 2
      • Slide the opening pick towards the USB-C port until it's underneath the screw hole next to the port.
      Ask FixBot
    15. Nintendo Switch 2 Hinges Replacement, Insert a second opening pick: step 15, image 1 of 3 Nintendo Switch 2 Hinges Replacement, Insert a second opening pick: step 15, image 2 of 3 Nintendo Switch 2 Hinges Replacement, Insert a second opening pick: step 15, image 3 of 3
      • Insert a second opening pick underneath the screw hole on the opposite side of the USB-C port, and slide it to the corner of the console.
      Ask FixBot
    16. Nintendo Switch 2 Hinges Replacement: step 16, image 1 of 2 Nintendo Switch 2 Hinges Replacement: step 16, image 2 of 2
      • Slide the first opening pick back to where it was first inserted.
      Ask FixBot
    17. Nintendo Switch 2 Hinges Replacement, Remove the back cover: step 17, image 1 of 3 Nintendo Switch 2 Hinges Replacement, Remove the back cover: step 17, image 2 of 3 Nintendo Switch 2 Hinges Replacement, Remove the back cover: step 17, image 3 of 3
      • Be careful not to drop your console. Once the back cover pops up, the opening picks will fall out of place.
      • Hold the console with two hands. Rest your thumbs on the opening picks.
      • Push up on the opening picks to lift the back cover until it pops up above the USB-C port.
      Ask FixBot
    18. Nintendo Switch 2 Hinges Replacement: step 18, image 1 of 3 Nintendo Switch 2 Hinges Replacement: step 18, image 2 of 3 Nintendo Switch 2 Hinges Replacement: step 18, image 3 of 3
      • Lift the back cover up from the bottom edge and remove it.
      Ask FixBot
    1. Nintendo Switch 2 Hinges Replacement, Remove the upper hinge covers: step 19, image 1 of 2 Nintendo Switch 2 Hinges Replacement, Remove the upper hinge covers: step 19, image 2 of 2
      • Use the flat end of a spudger to pry up one of the hinge's plastic upper hinge covers until it "pops" up.
      Ask FixBot
    2. Nintendo Switch 2 Hinges Replacement: step 20, image 1 of 2 Nintendo Switch 2 Hinges Replacement: step 20, image 2 of 2
      • Pull the upper hinge cover out from underneath the lower hinge cover to remove it.
      • The cover is clipped in place and requires a little bit of force to remove.
      Ask FixBot
    3. Nintendo Switch 2 Hinges Replacement: step 21, image 1 of 3 Nintendo Switch 2 Hinges Replacement: step 21, image 2 of 3 Nintendo Switch 2 Hinges Replacement: step 21, image 3 of 3
      • Repeat this process to remove the upper hinge cover on the other hinge.
      Ask FixBot
    4. Nintendo Switch 2 Hinges Replacement, Remove the kickstand screws: step 22, image 1 of 2 Nintendo Switch 2 Hinges Replacement, Remove the kickstand screws: step 22, image 2 of 2
      • Use a JIS 00 driver to remove the two 2.3 mm‑long silver screws securing each hinge to the inside of the back cover (four total).
      Ask FixBot
    5. Nintendo Switch 2 Hinges Replacement, Remove the kickstand: step 23, image 1 of 3 Nintendo Switch 2 Hinges Replacement, Remove the kickstand: step 23, image 2 of 3 Nintendo Switch 2 Hinges Replacement, Remove the kickstand: step 23, image 3 of 3
      • Open the kickstand to a 45‑degree angle and pull it out of the back cover to remove it.
      Ask FixBot
    1. Nintendo Switch 2 Hinges Replacement, Remove the hinge covers: step 24, image 1 of 2 Nintendo Switch 2 Hinges Replacement, Remove the hinge covers: step 24, image 2 of 2
      • Use a JIS 00 driver to remove the 1.7 mm‑long black screw securing each hinge cover to the kickstand (two screws total).
      Ask FixBot
    2. Nintendo Switch 2 Hinges Replacement: step 25, image 1 of 3 Nintendo Switch 2 Hinges Replacement: step 25, image 2 of 3 Nintendo Switch 2 Hinges Replacement: step 25, image 3 of 3
      • Use your fingers to pull one of the hinge covers at a downward angle away from its hinge to remove it.
      Ask FixBot
    3. Nintendo Switch 2 Hinges Replacement: step 26, image 1 of 3 Nintendo Switch 2 Hinges Replacement: step 26, image 2 of 3 Nintendo Switch 2 Hinges Replacement: step 26, image 3 of 3
      • Repeat this process to pull the hinge cover off the other hinge.
      Ask FixBot
    4. Nintendo Switch 2 Hinges Replacement, Fold the hinges: step 27, image 1 of 3 Nintendo Switch 2 Hinges Replacement, Fold the hinges: step 27, image 2 of 3 Nintendo Switch 2 Hinges Replacement, Fold the hinges: step 27, image 3 of 3
      • Use your fingers to fold both hinges as far back as they'll go.
      Ask FixBot
    5. Nintendo Switch 2 Hinges Replacement, Remove the hinge screws: step 28, image 1 of 2 Nintendo Switch 2 Hinges Replacement, Remove the hinge screws: step 28, image 2 of 2
      • Use a JIS 00 driver to remove the two 2.3 mm‑long silver screws securing each hinge to the kickstand (four screws in total).
      Ask FixBot
    6. Nintendo Switch 2 Hinges Replacement, Remove the hinges: step 29, image 1 of 3 Nintendo Switch 2 Hinges Replacement, Remove the hinges: step 29, image 2 of 3 Nintendo Switch 2 Hinges Replacement, Remove the hinges: step 29, image 3 of 3
      • Lift one of the hinges off its alignment peg on the kickstand to remove it.
      Ask FixBot
    7. Nintendo Switch 2 Hinges Replacement: step 30, image 1 of 3 Nintendo Switch 2 Hinges Replacement: step 30, image 2 of 3 Nintendo Switch 2 Hinges Replacement: step 30, image 3 of 3
      • Repeat this process to remove the other hinge.
      Ask FixBot
    1. Nintendo Switch 2 Hinges Replacement, Disassembly complete: step 31, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your console.
      Ask FixBot
    1. Nintendo Switch 2 Hinges Replacement, Install the hinges: step 32, image 1 of 3 Nintendo Switch 2 Hinges Replacement, Install the hinges: step 32, image 2 of 3 Nintendo Switch 2 Hinges Replacement, Install the hinges: step 32, image 3 of 3
      • Align one of the hinges with its alignment peg on the kickstand and set it into place.
      • Use a JIS 00 driver to install the two 2.3 mm‑long silver screws securing the hinge.
      Ask FixBot
    2. Nintendo Switch 2 Hinges Replacement: step 33, image 1 of 3 Nintendo Switch 2 Hinges Replacement: step 33, image 2 of 3 Nintendo Switch 2 Hinges Replacement: step 33, image 3 of 3
      • Align the other hinge with its alignment peg on the kickstand and set it into place.
      Ask FixBot
    3. Nintendo Switch 2 Hinges Replacement, Open the hinges: step 34, image 1 of 2 Nintendo Switch 2 Hinges Replacement, Open the hinges: step 34, image 2 of 2
      • Use your fingers to pull the hinges open until they're fully straight.
      Ask FixBot
    4. Nintendo Switch 2 Hinges Replacement, Install the hinge covers: step 35, image 1 of 3 Nintendo Switch 2 Hinges Replacement, Install the hinge covers: step 35, image 2 of 3 Nintendo Switch 2 Hinges Replacement, Install the hinge covers: step 35, image 3 of 3
      • Align one of the hinge covers with its respective hinge and press it into place.
      Ask FixBot
    5. Nintendo Switch 2 Hinges Replacement: step 36, image 1 of 3 Nintendo Switch 2 Hinges Replacement: step 36, image 2 of 3 Nintendo Switch 2 Hinges Replacement: step 36, image 3 of 3
      • Repeat this process for the other hinge cover.
      Ask FixBot
    6. Nintendo Switch 2 Hinges Replacement: step 37, image 1 of 2 Nintendo Switch 2 Hinges Replacement: step 37, image 2 of 2
      • Use a JIS 00 driver to install the 1.7 mm‑long black screw securing each hinge cover to the kickstand (two screws total).
      Ask FixBot
    1. Nintendo Switch 2 Hinges Replacement, Install the kickstand: step 38, image 1 of 3 Nintendo Switch 2 Hinges Replacement, Install the kickstand: step 38, image 2 of 3 Nintendo Switch 2 Hinges Replacement, Install the kickstand: step 38, image 3 of 3
      • Align the kickstand so its hinge covers are facing the back cover.
      • Insert the hinges through their slots in the back cover and set the kickstand into its cutout.
      Ask FixBot
    2. Nintendo Switch 2 Hinges Replacement, Install the kickstand screws: step 39, image 1 of 2 Nintendo Switch 2 Hinges Replacement, Install the kickstand screws: step 39, image 2 of 2
      • Use a JIS 00 driver to install the two 2.3 mm‑long silver screws securing each hinge to the inside of the back cover (four total).
      Ask FixBot
    3. Nintendo Switch 2 Hinges Replacement, Install the upper hinge covers: step 40, image 1 of 3 Nintendo Switch 2 Hinges Replacement, Install the upper hinge covers: step 40, image 2 of 3 Nintendo Switch 2 Hinges Replacement, Install the upper hinge covers: step 40, image 3 of 3
      • Align one of the upper hinge covers with its respective hinge, and slide it underneath the lower hinge cover.
      • Use your finger to press the upper hinge cover down until it clicks into place.
      Ask FixBot
    4. Nintendo Switch 2 Hinges Replacement: step 41, image 1 of 3 Nintendo Switch 2 Hinges Replacement: step 41, image 2 of 3 Nintendo Switch 2 Hinges Replacement: step 41, image 3 of 3
      • Repeat this process to install the other upper hinge cover.
      Ask FixBot
    1. Nintendo Switch 2 Hinges Replacement, Prepare the back cover: step 42, image 1 of 3 Nintendo Switch 2 Hinges Replacement, Prepare the back cover: step 42, image 2 of 3 Nintendo Switch 2 Hinges Replacement, Prepare the back cover: step 42, image 3 of 3
      • Fully pull out the game card tray.
      • Double-check the power and volume buttons to ensure they're seated correctly. If the rubber membrane beneath the buttons is out of place, ensure it's aligned with its pegs.
      • Check the microphone to ensure it's fully seated in its slot in the frame.
      Ask FixBot
    2. Nintendo Switch 2 Hinges Replacement, Install the back cover: step 43, image 1 of 3 Nintendo Switch 2 Hinges Replacement, Install the back cover: step 43, image 2 of 3 Nintendo Switch 2 Hinges Replacement, Install the back cover: step 43, image 3 of 3
      • Align the top of the back cover with the top of the console.
      • Set the top edge of the back cover into place, checking the buttons and ports to ensure they're aligned properly. If they aren't, lift the back cover and try again.
      • Press along the top edge to fasten the clips securing the back cover to the console.
      Ask FixBot
    3. Nintendo Switch 2 Hinges Replacement: step 44, image 1 of 2 Nintendo Switch 2 Hinges Replacement: step 44, image 2 of 2
      • Squeeze the rest of the back cover and console together to fasten the clips.
      Ask FixBot
    4. Nintendo Switch 2 Hinges Replacement, Install the back-side screws: step 45, image 1 of 3 Nintendo Switch 2 Hinges Replacement, Install the back-side screws: step 45, image 2 of 3 Nintendo Switch 2 Hinges Replacement, Install the back-side screws: step 45, image 3 of 3
      • Use a JIS 00 driver to install the three 3.1 mm‑long screws securing the back cover: one on the top edge of the console, and two on either side of the bottom USB-C port.
      • Use a Y00 driver to install the two 4.4 mm‑long screws in the kickstand cutout.
      Ask FixBot
    5. Nintendo Switch 2 Hinges Replacement, Install the side screws: step 46, image 1 of 2 Nintendo Switch 2 Hinges Replacement, Install the side screws: step 46, image 2 of 2
      • Use a JIS 00 driver to install the two 3.6 mm‑long gold screws on each side of the console (four in total).
      Ask FixBot
    6. Nintendo Switch 2 Hinges Replacement, Test the console: step 47, image 1 of 2 Nintendo Switch 2 Hinges Replacement, Test the console: step 47, image 2 of 2
      • Power on the console and test functionality to ensure it's working as expected.
      Ask FixBot
    7. Nintendo Switch 2 Hinges Replacement, Install the stickers: step 48, image 1 of 3 Nintendo Switch 2 Hinges Replacement, Install the stickers: step 48, image 2 of 3 Nintendo Switch 2 Hinges Replacement, Install the stickers: step 48, image 3 of 3
      • Align the right side sticker with its recess. Ensure the cutout in the sticker is aligned with the Joy-Con connector.
      • Set the sticker into its recess, first on one side, then the other.
      • Use your finger or the flat end of a spudger to press the sticker into place.
      • If the sticker isn't sticking well, apply heat after you press it into place.
      Ask FixBot
    8. Nintendo Switch 2 Hinges Replacement: step 49, image 1 of 3 Nintendo Switch 2 Hinges Replacement: step 49, image 2 of 3 Nintendo Switch 2 Hinges Replacement: step 49, image 3 of 3
      • Repeat this procedure to install the left side sticker.
      Ask FixBot
You finished fixing your Switch 2!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch 2 Answers Community for help.
Nick Schultz
63,637 Reputation
334 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 35
Past 30 Days: 111
All Time: 1,035
