Nintendo Switch 2 Fan Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
9
Past 7 Days:
68
Past 30 Days:
269
All Time:
2,703
Comments: 3
3 comments on steps.
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Introduction
Go to step 1 ↓
Follow this guide to replace the fan in a Nintendo Switch 2 game console.
The Switch 2 uses JIS screws. If you use a non-iFixit Phillips driver in JIS screws, you'll risk stripping them. iFixit's Phillips bits are designed to be compatible with JIS screws.
You’ll need new thermal putty and regular thermal paste to complete this repair.
Parts
Tools
    1. Nintendo Switch 2 Fan Replacement, Power off the console: step 1, image 1 of 3 Nintendo Switch 2 Fan Replacement, Power off the console: step 1, image 2 of 3 Nintendo Switch 2 Fan Replacement, Power off the console: step 1, image 3 of 3
      • For your safety, discharge the battery below 25% before disassembling the console. This reduces the risk of a fire if the battery is damaged during the repair. If the battery is swollen, take appropriate precautions.
      • Remove any game cards and disconnect any cables, controllers, or other accessories from the console.
      • Power off the console by holding down the power button, selecting Power Options, then pressing Power Off.
      Ask FixBot
    2. Nintendo Switch 2 Fan Replacement, Remove the bottom screws: step 2, image 1 of 2 Nintendo Switch 2 Fan Replacement, Remove the bottom screws: step 2, image 2 of 2
      • Use a JIS 00 driver to remove the two 3.1 mm‑long screws on either side of the bottom USB-C port.
      • You can try a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the driver and twist slowly.
      Ask FixBot
    3. Nintendo Switch 2 Fan Replacement, Remove the top screw: step 3, image 1 of 2 Nintendo Switch 2 Fan Replacement, Remove the top screw: step 3, image 2 of 2
      • Use a JIS 00 driver to remove the 3.1 mm‑long screw on the top edge of the console (next to the ventilation cutouts).
      Ask FixBot
    4. Nintendo Switch 2 Fan Replacement, Heat the right side sticker: step 4, image 1 of 1
      • The Switch 2 has stickers on either side that need to be removed to access the screws securing the back cover. It's easy to damage the stickers during removal, but you can mitigate this by regularly reheating the stickers and working carefully.
      • Use a hair dryer or heat gun to heat the sticker on the right side of the console, labeled with a "+" symbol, until it's hot to the touch.
      • You can use the kickstand to prop the console up vertically for easier access.
      • If you're using a heat gun, set it to low to avoid melting the plastic edge of the console.
      Ask FixBot
    5. Nintendo Switch 2 Fan Replacement, Pry up the right side sticker: step 5, image 1 of 3 Nintendo Switch 2 Fan Replacement, Pry up the right side sticker: step 5, image 2 of 3 Nintendo Switch 2 Fan Replacement, Pry up the right side sticker: step 5, image 3 of 3
      • The pointed end of the tweezers can damage the sticker from the underside, leaving a noticeable mark. If it's difficult to lift, apply more heat instead of using more force.
      • Slide one arm of angled tweezers underneath the sticker from its cutout around the right Joy‑Con 2 connector.
      • Gently pry up on the sticker until it starts to lift from the console.
      • Leave the tweezers in place to keep the sticker lifted.
      Ask FixBot
    6. Nintendo Switch 2 Fan Replacement: step 6, image 1 of 3 Nintendo Switch 2 Fan Replacement: step 6, image 2 of 3 Nintendo Switch 2 Fan Replacement: step 6, image 3 of 3
      Tool used on this step:
      Jimmy
      $7.95
      Buy
      • Insert the tip of a Jimmy into the gap formed between the long edge of the console and the sticker.
      • Gently pry up the sticker, working your way up the long edge until the top of the sticker is separated from the console.
      • Remove the tweezers once the sticker is lifted.
      • You can leave the Jimmy in place to hold the top of the sticker off the frame—if it falls back into its recess, repeat this procedure to lift it back up.
      Ask FixBot
    7. Nintendo Switch 2 Fan Replacement, Heat the right side sticker: step 7, image 1 of 1
      • Reheat the bottom of the right side until it's hot to the touch.
      Ask FixBot
    8. Nintendo Switch 2 Fan Replacement, Remove the right side sticker: step 8, image 1 of 3 Nintendo Switch 2 Fan Replacement, Remove the right side sticker: step 8, image 2 of 3 Nintendo Switch 2 Fan Replacement, Remove the right side sticker: step 8, image 3 of 3
      • Carefully lift the sticker over the Joy‑Con 2 connector, then peel it up fully to remove it.
      Ask FixBot
    9. Nintendo Switch 2 Fan Replacement, Remove the left side sticker: step 9, image 1 of 3 Nintendo Switch 2 Fan Replacement, Remove the left side sticker: step 9, image 2 of 3 Nintendo Switch 2 Fan Replacement, Remove the left side sticker: step 9, image 3 of 3
      • Repeat this procedure to remove the sticker along the left side of the console, labeled with a "-" symbol.
      Ask FixBot
    10. Nintendo Switch 2 Fan Replacement, Remove the side screws: step 10, image 1 of 2 Nintendo Switch 2 Fan Replacement, Remove the side screws: step 10, image 2 of 2
      • Use a JIS 00 driver to remove the two 3.6 mm‑long gold screws on each side of the console (four in total).
      Ask FixBot
    11. Nintendo Switch 2 Fan Replacement, Open the kickstand: step 11, image 1 of 3 Nintendo Switch 2 Fan Replacement, Open the kickstand: step 11, image 2 of 3 Nintendo Switch 2 Fan Replacement, Open the kickstand: step 11, image 3 of 3
      • Use your fingers to flip up the kickstand on the back of the console.
      • If there's a microSD Express card installed, remove it now before you continue to the next step.
      Ask FixBot
    12. Nintendo Switch 2 Fan Replacement, Remove the back-side screws: step 12, image 1 of 2 Nintendo Switch 2 Fan Replacement, Remove the back-side screws: step 12, image 2 of 2
      • Use a Y00 driver to remove the two 4.4 mm‑long screws in the kickstand cutout.
      Ask FixBot
    13. Nintendo Switch 2 Fan Replacement, Insert an opening pick: step 13, image 1 of 2 Nintendo Switch 2 Fan Replacement, Insert an opening pick: step 13, image 2 of 2
      • Insert an opening pick into the gap between the back cover and speaker cutout on the bottom edge of the console.
      Ask FixBot
    14. Nintendo Switch 2 Fan Replacement: step 14, image 1 of 2 Nintendo Switch 2 Fan Replacement: step 14, image 2 of 2
      • Slide the opening pick towards the USB-C port until it's underneath the screw hole next to the port.
      Ask FixBot
    15. Nintendo Switch 2 Fan Replacement, Insert a second opening pick: step 15, image 1 of 3 Nintendo Switch 2 Fan Replacement, Insert a second opening pick: step 15, image 2 of 3 Nintendo Switch 2 Fan Replacement, Insert a second opening pick: step 15, image 3 of 3
      • Insert a second opening pick underneath the screw hole on the opposite side of the USB-C port, and slide it to the corner of the console.
      Ask FixBot
    16. Nintendo Switch 2 Fan Replacement: step 16, image 1 of 2 Nintendo Switch 2 Fan Replacement: step 16, image 2 of 2
      • Slide the first opening pick back to where it was first inserted.
      Ask FixBot
    17. Nintendo Switch 2 Fan Replacement, Remove the back cover: step 17, image 1 of 3 Nintendo Switch 2 Fan Replacement, Remove the back cover: step 17, image 2 of 3 Nintendo Switch 2 Fan Replacement, Remove the back cover: step 17, image 3 of 3
      • Be careful not to drop your console. Once the back cover pops up, the opening picks will fall out of place.
      • Hold the console with two hands. Rest your thumbs on the opening picks.
      • Push up on the opening picks to lift the back cover until it pops up above the USB-C port.
      Ask FixBot
    18. Nintendo Switch 2 Fan Replacement: step 18, image 1 of 3 Nintendo Switch 2 Fan Replacement: step 18, image 2 of 3 Nintendo Switch 2 Fan Replacement: step 18, image 3 of 3
      • Lift the back cover up from the bottom edge and remove it.
      Ask FixBot
    1. Nintendo Switch 2 Fan Replacement, Remove the lower antenna screws: step 19, image 1 of 2 Nintendo Switch 2 Fan Replacement, Remove the lower antenna screws: step 19, image 2 of 2
      • Use a JIS 00 driver to remove the three 4.4 mm‑long silver screws securing the lower antenna.
      Ask FixBot
    2. Nintendo Switch 2 Fan Replacement, Remove the lower antenna: step 20, image 1 of 2 Nintendo Switch 2 Fan Replacement, Remove the lower antenna: step 20, image 2 of 2
      • Use tweezers or your fingers to remove the lower antenna.
      Ask FixBot
    3. Nintendo Switch 2 Fan Replacement, Remove the upper antenna screws: step 21, image 1 of 2 Nintendo Switch 2 Fan Replacement, Remove the upper antenna screws: step 21, image 2 of 2
      • Use a JIS 00 driver to remove the two screws securing the upper antenna:
      • One 4.4 mm‑long silver screw
      • One 4.6 mm‑long green screw
      Ask FixBot
    4. Nintendo Switch 2 Fan Replacement, Remove the upper antenna: step 22, image 1 of 2 Nintendo Switch 2 Fan Replacement, Remove the upper antenna: step 22, image 2 of 2
      • Use tweezers or your fingers to remove the upper antenna.
      Ask FixBot
    5. Nintendo Switch 2 Fan Replacement, Disconnect the lower antenna cable: step 23, image 1 of 3 Nintendo Switch 2 Fan Replacement, Disconnect the lower antenna cable: step 23, image 2 of 3 Nintendo Switch 2 Fan Replacement, Disconnect the lower antenna cable: step 23, image 3 of 3
      • Insert an arm of angled tweezers under the metal neck of the white interconnect cable coaxial connector (located beneath the lower antenna) and lift straight up to disconnect it.
      Ask FixBot
    6. Nintendo Switch 2 Fan Replacement, Disconnect the remaining antenna cables: step 24, image 1 of 3 Nintendo Switch 2 Fan Replacement, Disconnect the remaining antenna cables: step 24, image 2 of 3 Nintendo Switch 2 Fan Replacement, Disconnect the remaining antenna cables: step 24, image 3 of 3
      • Repeat this procedure to disconnect the three central coaxial connectors from the board.
      Ask FixBot
    7. Nintendo Switch 2 Fan Replacement, Disconnect the MicroSD connector: step 25, image 1 of 3 Nintendo Switch 2 Fan Replacement, Disconnect the MicroSD connector: step 25, image 2 of 3 Nintendo Switch 2 Fan Replacement, Disconnect the MicroSD connector: step 25, image 3 of 3
      • Use the flat end of a spudger to pry up and disconnect the MicroSD card reader press connector, located next to the bottom USB‑C port.
      Ask FixBot
    8. Nintendo Switch 2 Fan Replacement, Remove the shield plate screws: step 26, image 1 of 2 Nintendo Switch 2 Fan Replacement, Remove the shield plate screws: step 26, image 2 of 2
      • Use a JIS 00 driver to remove the seven screws securing the shield plate:
      • Two 6.2 mm‑long silver screws
      • Five 4.4 mm‑long silver screws
      Ask FixBot
    9. Nintendo Switch 2 Fan Replacement, Lift the shield plate: step 27, image 1 of 3 Nintendo Switch 2 Fan Replacement, Lift the shield plate: step 27, image 2 of 3 Nintendo Switch 2 Fan Replacement, Lift the shield plate: step 27, image 3 of 3
      • Insert the flat end of a spudger between the shield plate and the processor's heat sink, next to the square (⛶) marking on the shield plate.
      • Twist the spudger to lift the shield plate and separate the thermal putty bonded to it. Keep lifting the shield plate until you don't feel resistance.
      Ask FixBot
    10. Nintendo Switch 2 Fan Replacement: step 28, image 1 of 3 Nintendo Switch 2 Fan Replacement: step 28, image 2 of 3 Nintendo Switch 2 Fan Replacement: step 28, image 3 of 3
      • Lift the left edge of the shield plate to ensure it's fully separated from the thermal putty.
      • Gently set the shield plate back down.
      Ask FixBot
    11. Nintendo Switch 2 Fan Replacement, Unroute the gray antenna cable: step 29, image 1 of 3 Nintendo Switch 2 Fan Replacement, Unroute the gray antenna cable: step 29, image 2 of 3 Nintendo Switch 2 Fan Replacement, Unroute the gray antenna cable: step 29, image 3 of 3
      • Insert one arm of angled tweezers underneath the gray antenna cable at the bottom-right corner of the console.
      • Lift the cable out of the black clip securing it to the frame.
      Ask FixBot
    12. Nintendo Switch 2 Fan Replacement: step 30, image 1 of 3 Nintendo Switch 2 Fan Replacement: step 30, image 2 of 3 Nintendo Switch 2 Fan Replacement: step 30, image 3 of 3
      • Unroute the gray antenna cable from its channel along the right edge of the console.
      Ask FixBot
    13. Nintendo Switch 2 Fan Replacement: step 31, image 1 of 2 Nintendo Switch 2 Fan Replacement: step 31, image 2 of 2
      • Lift and slide the shield plate away from the right edge of the console until the gray antenna cable is completely free.
      Ask FixBot
    14. Nintendo Switch 2 Fan Replacement, Remove the shield plate: step 32, image 1 of 2 Nintendo Switch 2 Fan Replacement, Remove the shield plate: step 32, image 2 of 2
      • Pick up and remove the shield plate.
      Ask FixBot
    1. Nintendo Switch 2 Fan Replacement, Disconnect the battery: step 33, image 1 of 2 Nintendo Switch 2 Fan Replacement, Disconnect the battery: step 33, image 2 of 2
      • Insert the flat end of a spudger underneath the flat-topped battery connector, located next to the battery, and pry up to disconnect it.
      Ask FixBot
    1. Nintendo Switch 2 Fan Replacement, Clean the heat pipe: step 34, image 1 of 3 Nintendo Switch 2 Fan Replacement, Clean the heat pipe: step 34, image 2 of 3 Nintendo Switch 2 Fan Replacement, Clean the heat pipe: step 34, image 3 of 3
      Arctic Silver ArctiClean
      $11.99
      Buy
      • If you don't have replacement thermal putty, use the flat end of a spudger to distribute the old putty evenly across the heat pipe, as thick as possible to ensure proper contact. Repeat this process on the shield plate, then skip this step.
      • Use the flat end of a spudger to scrape off the thermal putty on top of the copper heat pipe.
      • Apply high-concentration (90% or higher) isopropyl alcohol or thermal material remover to a cotton swab or lint-free cloth and wipe away any remaining thermal putty on both the heat pipe and shield plate.
      • Don't use a paper towel or rag, as they may scratch the shield plate.
      Ask FixBot
    1. Nintendo Switch 2 Fan Replacement, Remove the heat sink screws: step 35, image 1 of 2 Nintendo Switch 2 Fan Replacement, Remove the heat sink screws: step 35, image 2 of 2
      • Use a JIS 00 driver to remove the four 3.4 mm‑long silver screws securing the heat sink.
      Ask FixBot
    2. Nintendo Switch 2 Fan Replacement, Free the heat sink: step 36, image 1 of 3 Nintendo Switch 2 Fan Replacement, Free the heat sink: step 36, image 2 of 3 Nintendo Switch 2 Fan Replacement, Free the heat sink: step 36, image 3 of 3
      • Insert the flat end of a spudger between the heat sink and the processor's heat spreader.
      • Twist the spudger to lift the heat sink and separate the thermal paste bonded to it.
      Ask FixBot
    3. Nintendo Switch 2 Fan Replacement, Remove the heat sink: step 37, image 1 of 3 Nintendo Switch 2 Fan Replacement, Remove the heat sink: step 37, image 2 of 3 Nintendo Switch 2 Fan Replacement, Remove the heat sink: step 37, image 3 of 3
      • Lift the heat sink slowly to avoid bending its thin copper heat pipe.
      • Slowly lift the heat sink from the front, until the aluminum fin stack at the back is detached from the adhesive beneath it.
      • Remove the heat sink.
      Ask FixBot
    4. Nintendo Switch 2 Fan Replacement, Clean the thermal paste: step 38, image 1 of 3 Nintendo Switch 2 Fan Replacement, Clean the thermal paste: step 38, image 2 of 3 Nintendo Switch 2 Fan Replacement, Clean the thermal paste: step 38, image 3 of 3
      $11.99
      Buy
      • Use high-concentration (90% or higher) isopropyl alcohol or thermal material remover to soak the thermal paste on the processor's heat spreader for one minute.
      • Use a lint-free cloth or cotton swabs to wipe away the thermal paste.
      • Repeat this process until the processor's heat spreader is clean.
      Ask FixBot
    5. Nintendo Switch 2 Fan Replacement: step 39, image 1 of 2 Nintendo Switch 2 Fan Replacement: step 39, image 2 of 2
      • If you're replacing your heat sink, skip this step.
      • Repeat this process to clean the thermal paste off the bottom of the heat sink.
      Ask FixBot
    1. Nintendo Switch 2 Fan Replacement, Disconnect the fan: step 40, image 1 of 2 Nintendo Switch 2 Fan Replacement, Disconnect the fan: step 40, image 2 of 2
      • Use the point of a spudger to flip up the locking flap on the fan cable ZIF connector, located next to the fan on the console's board.
      Ask FixBot
    2. Nintendo Switch 2 Fan Replacement: step 41, image 1 of 3 Nintendo Switch 2 Fan Replacement: step 41, image 2 of 3 Nintendo Switch 2 Fan Replacement: step 41, image 3 of 3
      • Use tweezers or your fingers to gently pull the cable out of its socket.
      • If you're using tweezers, pull the cable out by its "wings" instead of gripping the cable itself.
      Ask FixBot
    3. Nintendo Switch 2 Fan Replacement, Remove the fan screws: step 42, image 1 of 2 Nintendo Switch 2 Fan Replacement, Remove the fan screws: step 42, image 2 of 2
      • Use a JIS 00 driver to remove the three 5.2 mm‑long silver screws securing the fan.
      Ask FixBot
    4. Nintendo Switch 2 Fan Replacement, Remove the fan: step 43, image 1 of 3 Nintendo Switch 2 Fan Replacement, Remove the fan: step 43, image 2 of 3 Nintendo Switch 2 Fan Replacement, Remove the fan: step 43, image 3 of 3
      • Slide the fan out of its recess to free its cable, then pick it up to remove it.
      Ask FixBot
    1. Nintendo Switch 2 Fan Replacement, Disassembly complete: step 44, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your console.
      Ask FixBot
    1. Nintendo Switch 2 Fan Replacement, Install the fan: step 45, image 1 of 3 Nintendo Switch 2 Fan Replacement, Install the fan: step 45, image 2 of 3 Nintendo Switch 2 Fan Replacement, Install the fan: step 45, image 3 of 3
      • Slide the fan into its recess. Ensure its cable slides underneath the edge of the board.
      • Align the fan with its screw posts on the frame.
      Ask FixBot
    2. Nintendo Switch 2 Fan Replacement: step 46, image 1 of 2 Nintendo Switch 2 Fan Replacement: step 46, image 2 of 2
      • Use a JIS 00 driver to install the three 5.2 mm‑long silver screws securing the fan.
      Ask FixBot
    3. Nintendo Switch 2 Fan Replacement, Connect the fan: step 47, image 1 of 3 Nintendo Switch 2 Fan Replacement, Connect the fan: step 47, image 2 of 3 Nintendo Switch 2 Fan Replacement, Connect the fan: step 47, image 3 of 3
      • Use tweezers or your fingers to slide the fan cable into its ZIF connector until it's fully seated.
      • If you're using tweezers, you can use a spudger to help guide the cable into its connector.
      • Flip the hinged locking flap down to secure the cable.
      Ask FixBot
    1. Nintendo Switch 2 Fan Replacement, Install thermal paste: step 48, image 1 of 3 Nintendo Switch 2 Fan Replacement, Install thermal paste: step 48, image 2 of 3 Nintendo Switch 2 Fan Replacement, Install thermal paste: step 48, image 3 of 3
      iFixit Thermal Paste
      $9.95
      Buy
      • Apply a bead of new thermal paste to the center of the processor's copper heat spreader, roughly the size of a pea.
      Ask FixBot
    2. Nintendo Switch 2 Fan Replacement, Install the heat sink: step 49, image 1 of 3 Nintendo Switch 2 Fan Replacement, Install the heat sink: step 49, image 2 of 3 Nintendo Switch 2 Fan Replacement, Install the heat sink: step 49, image 3 of 3
      • Set the heat sink's aluminum fins into its recess behind the fan, then lower the heat sink onto the board.
      Ask FixBot
    3. Nintendo Switch 2 Fan Replacement: step 50, image 1 of 2 Nintendo Switch 2 Fan Replacement: step 50, image 2 of 2
      • Use a JIS 00 driver to partially install the four 3.4 mm‑long silver screws securing the heat sink.
      • Tighten the screws in an X pattern. For example: bottom left, top right, bottom right, then top left.
      Ask FixBot
    1. Nintendo Switch 2 Fan Replacement, Connect the battery: step 51, image 1 of 2 Nintendo Switch 2 Fan Replacement, Connect the battery: step 51, image 2 of 2
      • Align the battery connector over its socket on the board.
      • Use your finger or the flat end of a spudger to press the battery connector onto its socket until it's fully seated.
      Ask FixBot
    1. Nintendo Switch 2 Fan Replacement, Apply thermal putty: step 52, image 1 of 3 Nintendo Switch 2 Fan Replacement, Apply thermal putty: step 52, image 2 of 3 Nintendo Switch 2 Fan Replacement, Apply thermal putty: step 52, image 3 of 3
      iFixit Thermal Putty
      $9.95
      Buy
      • Apply a line of new thermal putty down the center of the heat pipe, roughly the thickness of a pea.
      Ask FixBot
    2. Nintendo Switch 2 Fan Replacement, Route the gray antenna cable: step 53, image 1 of 3 Nintendo Switch 2 Fan Replacement, Route the gray antenna cable: step 53, image 2 of 3 Nintendo Switch 2 Fan Replacement, Route the gray antenna cable: step 53, image 3 of 3
      • Hold the top‑right corner of the shield plate above the top‑right corner of the console.
      • Route the gray antenna cable underneath the black hook near the top corner of the frame.
      Ask FixBot
    3. Nintendo Switch 2 Fan Replacement, Lower the shield plate: step 54, image 1 of 2 Nintendo Switch 2 Fan Replacement, Lower the shield plate: step 54, image 2 of 2
      • Lower the shield plate into place and align it with its screw holes.
      Ask FixBot
    4. Nintendo Switch 2 Fan Replacement, Finish routing the gray antenna cable: step 55, image 1 of 3 Nintendo Switch 2 Fan Replacement, Finish routing the gray antenna cable: step 55, image 2 of 3 Nintendo Switch 2 Fan Replacement, Finish routing the gray antenna cable: step 55, image 3 of 3
      • Route the gray antenna cable down its channel on the right edge of the frame.
      Ask FixBot
    5. Nintendo Switch 2 Fan Replacement: step 56, image 1 of 3 Nintendo Switch 2 Fan Replacement: step 56, image 2 of 3 Nintendo Switch 2 Fan Replacement: step 56, image 3 of 3
      • Press the gray antenna cable into its groove at the bottom of its channel, and continue routing until it's secured to the clip at the bottom of the frame.
      Ask FixBot
    6. Nintendo Switch 2 Fan Replacement, Install the shield plate screws: step 57, image 1 of 2 Nintendo Switch 2 Fan Replacement, Install the shield plate screws: step 57, image 2 of 2
      • Use a JIS 00 driver to install the seven screws securing the shield plate:
      Ask FixBot
    7. Nintendo Switch 2 Fan Replacement, Connect the MicroSD connector: step 58, image 1 of 2 Nintendo Switch 2 Fan Replacement, Connect the MicroSD connector: step 58, image 2 of 2
      • Use your finger or the flat end of a spudger to press the MicroSD card reader press connector onto its socket on the board.
      • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    8. Nintendo Switch 2 Fan Replacement, Connect the antenna cables: step 59, image 1 of 3 Nintendo Switch 2 Fan Replacement, Connect the antenna cables: step 59, image 2 of 3 Nintendo Switch 2 Fan Replacement, Connect the antenna cables: step 59, image 3 of 3
      • Use tweezers to hold the lower antenna coaxial connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head instead of using more force.
      • Repeat this process to connect the three central coaxial connectors to their respective sockets.
      • The black cable connects to the socket closest to the fan, the white to the middle, and the gray the furthest away.
      Ask FixBot
    9. Nintendo Switch 2 Fan Replacement, Install the upper antenna: step 60, image 1 of 3 Nintendo Switch 2 Fan Replacement, Install the upper antenna: step 60, image 2 of 3 Nintendo Switch 2 Fan Replacement, Install the upper antenna: step 60, image 3 of 3
      • Use tweezers or your fingers to align the upper antenna with its screw holes and black alignment pegs and set it into place.
      • Use a JIS 00 driver to install the two screws securing the upper antenna:
      Ask FixBot
    10. Nintendo Switch 2 Fan Replacement, Install the lower antenna: step 61, image 1 of 3 Nintendo Switch 2 Fan Replacement, Install the lower antenna: step 61, image 2 of 3 Nintendo Switch 2 Fan Replacement, Install the lower antenna: step 61, image 3 of 3
      • Use tweezers or your fingers to align the lower antenna with its screw holes and gray alignment pegs and set it into place.
      • Use a JIS 00 driver to install the three 4.4 mm‑long screws securing the lower antenna.
      Ask FixBot
    1. Nintendo Switch 2 Fan Replacement, Prepare the back cover: step 62, image 1 of 3 Nintendo Switch 2 Fan Replacement, Prepare the back cover: step 62, image 2 of 3 Nintendo Switch 2 Fan Replacement, Prepare the back cover: step 62, image 3 of 3
      • Fully pull out the game card tray.
      • Double-check the power and volume buttons to ensure they're seated correctly. If the rubber membrane beneath the buttons is out of place, ensure it's aligned with its pegs.
      • Check the microphone to ensure it's fully seated in its slot in the frame.
      Ask FixBot
    2. Nintendo Switch 2 Fan Replacement, Install the back cover: step 63, image 1 of 3 Nintendo Switch 2 Fan Replacement, Install the back cover: step 63, image 2 of 3 Nintendo Switch 2 Fan Replacement, Install the back cover: step 63, image 3 of 3
      • Align the top of the back cover with the top of the console.
      • Set the top edge of the back cover into place, checking the buttons and ports to ensure they're aligned properly. If they aren't, lift the back cover and try again.
      • Press along the top edge to fasten the clips securing the back cover to the console.
      Ask FixBot
    3. Nintendo Switch 2 Fan Replacement: step 64, image 1 of 2 Nintendo Switch 2 Fan Replacement: step 64, image 2 of 2
      • Squeeze the rest of the back cover and console together to fasten the clips.
      Ask FixBot
    4. Nintendo Switch 2 Fan Replacement, Install the back-side screws: step 65, image 1 of 3 Nintendo Switch 2 Fan Replacement, Install the back-side screws: step 65, image 2 of 3 Nintendo Switch 2 Fan Replacement, Install the back-side screws: step 65, image 3 of 3
      • Use a JIS 00 driver to install the three 3.1 mm‑long screws securing the back cover: one on the top edge of the console, and two on either side of the bottom USB-C port.
      • Use a Y00 driver to install the two 4.4 mm‑long screws in the kickstand cutout.
      Ask FixBot
    5. Nintendo Switch 2 Fan Replacement, Install the side screws: step 66, image 1 of 2 Nintendo Switch 2 Fan Replacement, Install the side screws: step 66, image 2 of 2
      • Use a JIS 00 driver to install the two 3.6 mm‑long gold screws on each side of the console (four in total).
      Ask FixBot
    6. Nintendo Switch 2 Fan Replacement, Test the console: step 67, image 1 of 2 Nintendo Switch 2 Fan Replacement, Test the console: step 67, image 2 of 2
      • Power on the console and test functionality to ensure it's working as expected.
      Ask FixBot
    7. Nintendo Switch 2 Fan Replacement, Install the stickers: step 68, image 1 of 3 Nintendo Switch 2 Fan Replacement, Install the stickers: step 68, image 2 of 3 Nintendo Switch 2 Fan Replacement, Install the stickers: step 68, image 3 of 3
      • Align the right side sticker with its recess. Ensure the cutout in the sticker is aligned with the Joy-Con connector.
      • Set the sticker into its recess, first on one side, then the other.
      • Use your finger or the flat end of a spudger to press the sticker into place.
      • If the sticker isn't sticking well, apply heat after you press it into place.
      Ask FixBot
    8. Nintendo Switch 2 Fan Replacement: step 69, image 1 of 3 Nintendo Switch 2 Fan Replacement: step 69, image 2 of 3 Nintendo Switch 2 Fan Replacement: step 69, image 3 of 3
      • Repeat this procedure to install the left side sticker.
      Ask FixBot
You finished fixing your Switch 2!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch 2 Answers Community for help.
Nick Schultz
69,819 Reputation
363 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 68
Past 30 Days: 269
All Time: 2,703
