Nexus 6P Back Cover Replacement
  1. Nexus 6P Back Cover Replacement, Back Cover: step 1, image 1 of 3 Nexus 6P Back Cover Replacement, Back Cover: step 1, image 2 of 3 Nexus 6P Back Cover Replacement, Back Cover: step 1, image 3 of 3
    • It is possible to remove the back cover with an iOpener as seen in this guide but it's a lengthy and difficult procedure. We recommend a heat gun or something similar. The adhesive in the Nexus 6P is extremely sticky and especially the glass and plastic cover on the backside break or bend most of the time whilst doing this repair.
    • Use a SIM card eject tool, to pop out and remove the SIM card tray.
    • Use an iOpener to loosen the adhesive underneath the small plastic cover at the bottom of the phone.
  2. Nexus 6P Back Cover Replacement: step 2, image 1 of 3 Nexus 6P Back Cover Replacement: step 2, image 2 of 3 Nexus 6P Back Cover Replacement: step 2, image 3 of 3
    • The knife is really sharp. Take care, not to cut yourself or your phone.
    • Insert a knife between the phone and the plastic cover. Pry up the plastic cover until you can insert an opening pick.
    • Slide the opening pick underneath the plastic cover to cut the adhesive.
  3. Nexus 6P Back Cover Replacement: step 3, image 1 of 2 Nexus 6P Back Cover Replacement: step 3, image 2 of 2
    • Use an iOpener to loosen the adhesive underneath the glass cover at the top of the phone.
    • Insert a knife between the phone and the glass cover. Pry up the glass cover until you can insert an opening pick.
  4. Nexus 6P Back Cover Replacement: step 4, image 1 of 3 Nexus 6P Back Cover Replacement: step 4, image 2 of 3 Nexus 6P Back Cover Replacement: step 4, image 3 of 3
    • Glass may break. Wear protective glasses and protective gloves.
    • Slide the opening pick underneath the glass cover and use it to cut the adhesive underneath.
    • Pry off the glass cover.
  5. Nexus 6P Back Cover Replacement: step 5, image 1 of 3 Nexus 6P Back Cover Replacement: step 5, image 2 of 3 Nexus 6P Back Cover Replacement: step 5, image 3 of 3
    • Use tweezers to remove the liquid indicator stickers.
    • Remove the six Philipps #000 screws.
  6. Nexus 6P Back Cover Replacement: step 6, image 1 of 3 Nexus 6P Back Cover Replacement: step 6, image 2 of 3 Nexus 6P Back Cover Replacement: step 6, image 3 of 3
    • Insert a razor knife between the metal back cover and the front glass to create a gap. Insert an opening pick into the gap and slide it to the top right corner.
    • The knife is really sharp, be careful, not to cut yourself or your phone.
    • Insert a second opening pick and slide it to the top left corner.
    • Slide the opening picks along the edges to seperate the plastic clips, holding back cover and midframe together.
    • Remove the rear cover.
Dominik Schnabelrauch
206,467 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,524 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 3,922
