Motorola Slvr L7 Camera Assembly Replacement
    • To ensure safety, discharge your phone battery below 25% before starting. A fully charged lithium-ion battery may cause a fire and/or explosion due to defects or damage.
    • Turn off your phone before beginning disassembly.
  1. Motorola Slvr L7 Camera Assembly Replacement: step 2, image 1 of 1
    • Push down on the black tab located at the top center of the Motorola phone.
  2. Motorola Slvr L7 Camera Assembly Replacement: step 3, image 1 of 1
    • Remove the battery by pulling the battery from the top center.
  3. Motorola Slvr L7 Camera Assembly Replacement: step 4, image 1 of 1
    • Remove the four (4) T6 Torx screws from the back of the metal back plate.
  4. Motorola Slvr L7 Camera Assembly Replacement: step 5, image 1 of 2 Motorola Slvr L7 Camera Assembly Replacement: step 5, image 2 of 2
    • Insert the flat end of a spudger and pry the metal cover up off the phone.
  5. Motorola Slvr L7 Camera Assembly Replacement: step 6, image 1 of 2 Motorola Slvr L7 Camera Assembly Replacement: step 6, image 2 of 2
    • Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger.
  6. Motorola Slvr L7 Camera Assembly Replacement: step 7, image 1 of 2 Motorola Slvr L7 Camera Assembly Replacement: step 7, image 2 of 2
    • Use a spudger to pry the antenna cable connectors from its respective socket on the motherboard.
    • De-route the antenna cable by pulling it out.
Jorge Trujillo
520 Reputation
4 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 3,015
