Motorola Moto G4 Battery Replacement
  1. Motorola Moto G4 Battery Replacement, Back Cover: step 1, image 1 of 3 Motorola Moto G4 Battery Replacement, Back Cover: step 1, image 2 of 3 Motorola Moto G4 Battery Replacement, Back Cover: step 1, image 3 of 3
    • Insert a fingernail or a spudger into the notch on the bottom edge of the phone, near the charge port.
    • Gently twist or pry to open a small gap between the back cover and the body of the phone.
    • While keeping your tool (or fingernail) inserted into the gap between the back cover and the body of the phone, slide it around the corner to begin loosening the plastic clips holding the cover in place.
  2. Motorola Moto G4 Battery Replacement: step 2, image 1 of 2 Motorola Moto G4 Battery Replacement: step 2, image 2 of 2
    • Slide your tool all along the side of the phone to separate more of the clips securing the back cover.
  3. Motorola Moto G4 Battery Replacement: step 3, image 1 of 3 Motorola Moto G4 Battery Replacement: step 3, image 2 of 3 Motorola Moto G4 Battery Replacement: step 3, image 3 of 3
    • Keep your tool inserted slightly under the back cover, and slide it around the top corner.
    • If necessary, continue prying around the remaining edges of the phone until the back cover comes free.
  4. Motorola Moto G4 Battery Replacement: step 4, image 1 of 2 Motorola Moto G4 Battery Replacement: step 4, image 2 of 2
    • Remove the back cover.
    • To install the back cover, carefully position it over the phone and then press gently all around the edges until you feel the clips snap into place.
  5. Motorola Moto G4 Battery Replacement, Midframe: step 5, image 1 of 3 Motorola Moto G4 Battery Replacement, Midframe: step 5, image 2 of 3 Motorola Moto G4 Battery Replacement, Midframe: step 5, image 3 of 3
    • Push to eject and remove the MicroSD and SIM cards (if installed).
  6. Motorola Moto G4 Battery Replacement: step 6, image 1 of 2 Motorola Moto G4 Battery Replacement: step 6, image 2 of 2
    • Use a spudger to pry up the rubber cover for the camera flash connector.
  7. Motorola Moto G4 Battery Replacement: step 7, image 1 of 1
    • Remove the rubber cover.
  8. Motorola Moto G4 Battery Replacement: step 8, image 1 of 2 Motorola Moto G4 Battery Replacement: step 8, image 2 of 2
    • Use a spudger to disconnect the camera flash connector by prying it straight up.
  9. Motorola Moto G4 Battery Replacement: step 9, image 1 of 1
    • Use a T3 Torx driver to remove the nineteen identical 3.1 mm screws securing the midframe.
  10. Motorola Moto G4 Battery Replacement: step 10, image 1 of 1
    • Insert a spudger under the midframe at the top left corner, and gently twist to separate it from the body of the phone.
  11. Motorola Moto G4 Battery Replacement: step 11, image 1 of 1
    • Remove the midframe.
  12. Motorola Moto G4 Battery Replacement, Battery: step 12, image 1 of 2 Motorola Moto G4 Battery Replacement, Battery: step 12, image 2 of 2
    • Peel up and remove any tape connecting the battery to the main board.
    • Be very careful not to puncture the battery with any sharp tools. A damaged lithium-ion battery can catch fire and/or explode.
  13. Motorola Moto G4 Battery Replacement: step 13, image 1 of 2 Motorola Moto G4 Battery Replacement: step 13, image 2 of 2
    • Insert a thin tool (such as one of your tweezer tips) under the red and black battery wires, and slide it underneath the battery connector.
    • Gently pry straight up to disconnect the battery.
    • Pry only from the side where the wires attach to the connector—if you pry anywhere else, you may break the socket.
    • During reassembly, align the connector in its socket with the exposed copper wire facing up, and then press straight down to reconnect it, wiggling slightly as you press to help it seat correctly.
  14. Motorola Moto G4 Battery Replacement: step 14, image 1 of 2 Motorola Moto G4 Battery Replacement: step 14, image 2 of 2
    • Push the battery wires towards the battery to de-route them from the black bracket on the motherboard.
  15. Motorola Moto G4 Battery Replacement: step 15, image 1 of 3 Motorola Moto G4 Battery Replacement: step 15, image 2 of 3 Motorola Moto G4 Battery Replacement: step 15, image 3 of 3
    • Peel up the black pull tab at the top of the battery, and pull slowly but firmly to separate the battery from the adhesive holding it in place.
    • The battery separates more easily if you add a few drops of isopropyl alcohol along each side, to soften the adhesive beneath. High concentration (90% or greater) alcohol will not harm your phone's components.
    • Heating the area behind the battery can also help soften the adhesive, but be very careful not to overheat the battery.
    • If the pull tab breaks, use a spudger or an old credit card to pry up carefully on the edges of the battery until it comes loose.
    • Don't deform or puncture the battery—it can catch fire and/or explode if damaged.
    • Never reinstall a damaged or deformed battery. Replace the battery.
  16. Motorola Moto G4 Battery Replacement: step 16, image 1 of 1
    Tool used on this step:
    Tesa 61395 Tape
    $5.99
    Buy
    • Remove the battery.
    • During installation, note the orientation of the battery—if the connector is on the same side as the motherboard, and the text is upside-down relative to the rest of the phone, you've done it correctly.
    • Use a few strips of thin double-sided adhesive tape or a pre-cut adhesive card to secure the battery. (Or, if you are replacing the display, it may come with adhesive for the battery pre-installed.)
Kierra Schau
1,511 Reputation
4 Guides authored
USF Tampa, Team S11-G2, Passmore Fall 2017 Member of USF Tampa, Team S11-G2, Passmore Fall 2017
USFT-PASSMORE-F17S11G2
3 Members
13 Guides authored
Past 24 Hours: 18
Past 7 Days: 93
Past 30 Days: 366
All Time: 63,661
