Introduction
The O-Ring is fragile. Take care not to let it break when dealing with it.
Set the watch face down on a flat surface.
Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
Follow the instructions here to remove the back cover without force by using some needles in the right places:
Then continue with step 5. Or don't use needles and just continue with the next steps.
Gently slide the blue opening pick between the rear cover and the metal casing.
Work your way entirely around the rear cover.
