Motorola Moto 360 Battery Replacement
  1. Motorola Moto 360 Battery Replacement, Rear Cover: step 1, image 1 of 1
    • Set the watch face down on a flat surface.
    • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
  2. Motorola Moto 360 Battery Replacement: step 3, image 1 of 2 Motorola Moto 360 Battery Replacement: step 3, image 2 of 2
    • Gently slide the blue opening pick between the rear cover and the metal casing.
    • The rear cover is extremely fragile. Be very delicate when using the opening pick.
    • Work your way entirely around the rear cover.
    • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
  3. Motorola Moto 360 Battery Replacement: step 4, image 1 of 1
    • Once the adhesive has been successfully loosened, gently pull the rear cover off.
  4. Motorola Moto 360 Battery Replacement, O-Ring: step 5, image 1 of 2 Motorola Moto 360 Battery Replacement, O-Ring: step 5, image 2 of 2
    • To get to the O-Ring, use the Jimmy to gently pry off the rear housing.
  5. Motorola Moto 360 Battery Replacement: step 6, image 1 of 1
    • Pinch the green rubber O-Ring and slide it off of the watch.
    • The O-Ring is delicate and is easily severed. Use care around sharp objects.
  6. Motorola Moto 360 Battery Replacement, Battery: step 7, image 1 of 2 Motorola Moto 360 Battery Replacement, Battery: step 7, image 2 of 2
    • Using a thin pick it is possible to remove 4 very small clips that hold the top case, and screen to the glass base. If these clips are removed the watch can be taken apart without the use of heat.
    • Detach the copper ribbon connecting the motherboard and the display.
    • For reassembly, attach copper ribbon where it is marked.
    • The copper ribbon is fragile and easily disconnects. Remember where it goes so as to reconnect it properly.
  7. Motorola Moto 360 Battery Replacement: step 8, image 1 of 3 Motorola Moto 360 Battery Replacement: step 8, image 2 of 3 Motorola Moto 360 Battery Replacement: step 8, image 3 of 3
    • Use the spudger to separate the battery casing from the rear housing.
    • For leverage, place the spudger in either groove in the rear housing.
  8. Motorola Moto 360 Battery Replacement: step 9, image 1 of 1
    • Lift the black plastic pull-tab and pull back on the battery until it's removed from the battery casing. The battery is very firmly secured, so you may have to use a great deal of force.
    • There are two strips of adhesive securing the battery. You may have to use the spudger to loosen the adhesive. Use care not to damage electronics.
  9. Motorola Moto 360 Battery Replacement: step 10, image 1 of 1
    • Once the battery is separate from the back of the battery casing, disconnect the red and black wire by prying or pulling it straight up from the board (perpendicular to the board surface).
Keslyn Huntington
1,661 Reputation
1 Guide authored
Cal Poly, Team 17-32, Amido Winter 2015 Member of Cal Poly, Team 17-32, Amido Winter 2015
CPSU-AMIDO-W15S17G32
4 Members
18 Guides authored
Past 24 Hours: 11
Past 7 Days: 36
Past 30 Days: 157
All Time: 112,574
