Moto G4 Midframe Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Moto G4 Midframe Replacement, Back Cover: step 1, image 1 of 3 Moto G4 Midframe Replacement, Back Cover: step 1, image 2 of 3 Moto G4 Midframe Replacement, Back Cover: step 1, image 3 of 3
    • Insert a fingernail or a spudger into the notch on the bottom edge of the phone, near the charge port.
    • Gently twist or pry to open a small gap between the back cover and the body of the phone.
    • While keeping your tool (or fingernail) inserted into the gap between the back cover and the body of the phone, slide it around the corner to begin loosening the plastic clips holding the cover in place.
  2. Moto G4 Midframe Replacement: step 2, image 1 of 2 Moto G4 Midframe Replacement: step 2, image 2 of 2
    • Slide your tool all along the side of the phone to separate more of the clips securing the back cover.
  3. Moto G4 Midframe Replacement: step 3, image 1 of 3 Moto G4 Midframe Replacement: step 3, image 2 of 3 Moto G4 Midframe Replacement: step 3, image 3 of 3
    • Keep your tool inserted slightly under the back cover, and slide it around the top corner.
    • If necessary, continue prying around the remaining edges of the phone until the back cover comes free.
  4. Moto G4 Midframe Replacement: step 4, image 1 of 2 Moto G4 Midframe Replacement: step 4, image 2 of 2
    • Remove the back cover.
    • To install the back cover, carefully position it over the phone and then press gently all around the edges until you feel the clips snap into place.
  5. Moto G4 Midframe Replacement, Midframe: step 5, image 1 of 2 Moto G4 Midframe Replacement, Midframe: step 5, image 2 of 2
    • Slide out and remove the MicroSD and SIM card trays (if installed).
  6. Moto G4 Midframe Replacement: step 6, image 1 of 2 Moto G4 Midframe Replacement: step 6, image 2 of 2
    • Use a spudger to pry up the rubber cover for the camera flash connector.
  7. Moto G4 Midframe Replacement: step 7, image 1 of 1
    • Remove the rubber cover.
  8. Moto G4 Midframe Replacement: step 8, image 1 of 2 Moto G4 Midframe Replacement: step 8, image 2 of 2
    • Use a spudger to disconnect the camera flash connector by prying it straight up.
  9. Moto G4 Midframe Replacement: step 9, image 1 of 1
    • Remove the nineteen identical T3 Torx screws securing the midframe.
  10. Moto G4 Midframe Replacement: step 10, image 1 of 1
    • Insert a spudger under the midframe at the top left corner, and gently twist to separate it from the body of the phone.
  11. Moto G4 Midframe Replacement: step 11, image 1 of 1
    • Remove the midframe.
Jeff Suovanen
429,019 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 77
