Moto G4 Midframe Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
8
Past 30 Days:
23
All Time:
387
Comments: 9
9 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prerequisite-only guide for removing the midframe from the Moto G4, in order to access internal components for servicing.
Tools
  • T3 Torx Screwdriver
    4.8
  • Spudger
    4.9
    1. Moto G4 Midframe Replacement, Back Cover: step 1, image 1 of 3 Moto G4 Midframe Replacement, Back Cover: step 1, image 2 of 3 Moto G4 Midframe Replacement, Back Cover: step 1, image 3 of 3
      • Insert a fingernail or a spudger into the notch on the bottom edge of the phone, near the charge port.
      • Gently twist or pry to open a small gap between the back cover and the body of the phone.
      • While keeping your tool (or fingernail) inserted into the gap between the back cover and the body of the phone, slide it around the corner to begin loosening the plastic clips holding the cover in place.
      Ask FixBot
    2. Moto G4 Midframe Replacement: step 2, image 1 of 2 Moto G4 Midframe Replacement: step 2, image 2 of 2
      • Slide your tool all along the side of the phone to separate more of the clips securing the back cover.
      Ask FixBot
    3. Moto G4 Midframe Replacement: step 3, image 1 of 3 Moto G4 Midframe Replacement: step 3, image 2 of 3 Moto G4 Midframe Replacement: step 3, image 3 of 3
      • Keep your tool inserted slightly under the back cover, and slide it around the top corner.
      • If necessary, continue prying around the remaining edges of the phone until the back cover comes free.
      Ask FixBot
    4. Moto G4 Midframe Replacement: step 4, image 1 of 2 Moto G4 Midframe Replacement: step 4, image 2 of 2
      • Remove the back cover.
      • To install the back cover, carefully position it over the phone and then press gently all around the edges until you feel the clips snap into place.
      Ask FixBot
    1. Moto G4 Midframe Replacement, Midframe: step 5, image 1 of 3 Moto G4 Midframe Replacement, Midframe: step 5, image 2 of 3 Moto G4 Midframe Replacement, Midframe: step 5, image 3 of 3
      • Push to eject and remove the MicroSD and SIM cards (if installed).
      Ask FixBot
    2. Moto G4 Midframe Replacement: step 6, image 1 of 2 Moto G4 Midframe Replacement: step 6, image 2 of 2
      • Use a spudger to pry up the rubber cover for the camera flash connector.
      Ask FixBot
    3. Moto G4 Midframe Replacement: step 7, image 1 of 1
      • Remove the rubber cover.
      Ask FixBot
    4. Moto G4 Midframe Replacement: step 8, image 1 of 2 Moto G4 Midframe Replacement: step 8, image 2 of 2
      • Use a spudger to disconnect the camera flash connector by prying it straight up.
      Ask FixBot
    5. Moto G4 Midframe Replacement: step 9, image 1 of 1
      • Use a T3 Torx driver to remove the nineteen identical 3.1 mm screws securing the midframe.
      Ask FixBot
    6. Moto G4 Midframe Replacement: step 10, image 1 of 1
      • Insert a spudger under the midframe at the top left corner, and gently twist to separate it from the body of the phone.
      Ask FixBot
    7. Moto G4 Midframe Replacement: step 11, image 1 of 1
      • Remove the midframe.
      Ask FixBot
Jeff Suovanen
455,165 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 23
All Time: 387
