Screen Assembly Replacement
  1. Screen Assembly Replacement, Back Cover: step 1, image 1 of 3 Screen Assembly Replacement, Back Cover: step 1, image 2 of 3 Screen Assembly Replacement, Back Cover: step 1, image 3 of 3
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or spudger, into the notch on the bottom right to start separating the phone unit from the back cover.
    • Move to the bottom left corner and pry the phone unit out of the back cover until you can get a good grip.
  2. Screen Assembly Replacement: step 2, image 1 of 2 Screen Assembly Replacement: step 2, image 2 of 2
    • Lift the phone out of the back cover.
  3. Screen Assembly Replacement, Battery: step 3, image 1 of 3 Screen Assembly Replacement, Battery: step 3, image 2 of 3 Screen Assembly Replacement, Battery: step 3, image 3 of 3
    • Use a spudger or fingernail to lift the battery starting at the notch on the bottom left.
    • Lever the battery out of its recess and remove it.
  4. Screen Assembly Replacement, Daughterboard Cover: step 4, image 1 of 1
    • Remove the six 3.1 mm Phillips #00 screws securing the daughterboard cover.
  5. Screen Assembly Replacement: step 5, image 1 of 3 Screen Assembly Replacement: step 5, image 2 of 3 Screen Assembly Replacement: step 5, image 3 of 3
    • Apply a spudger to the right side of the daughterboard cover.
    • Twist the spudger sideways to pry up the daughterboard cover until you get a good grip.
    • Remove the daughterboard cover.
  6. Screen Assembly Replacement, Motherboard Cover: step 6, image 1 of 1
    • Remove the five 3.1 mm long Phillips #00 screws.
  7. Screen Assembly Replacement: step 7, image 1 of 3 Screen Assembly Replacement: step 7, image 2 of 3 Screen Assembly Replacement: step 7, image 3 of 3
    • Apply an opening pick to the bottom right corner of the motherboard cover.
    • Twist the opening pick to free the motherboard cover out of the plastic clamps on the right side of the phone.
  8. Screen Assembly Replacement: step 8, image 1 of 2 Screen Assembly Replacement: step 8, image 2 of 2
    • Repeat the previous step on the left side of the motherboard cover to free it out of the plastic clamps.
    • Pry up the motherboard cover until you can get a good grip.
    • Remove the motherboard cover.
  9. Screen Assembly Replacement, Motherboard Assembly: step 9, image 1 of 1
    • Remove the two 3.2 mm Phillips #00 screws securing the motherboard.
  10. Screen Assembly Replacement: step 10, image 1 of 2 Screen Assembly Replacement: step 10, image 2 of 2
    • Use the tip of a spudger to lift the latch on the power and volume button ZIF connector.
  11. Screen Assembly Replacement: step 11, image 1 of 2 Screen Assembly Replacement: step 11, image 2 of 2
    • Use a pair of tweezers to pull the power and volume button flex cable out of the ZIF connector.
    • Fold the power and volume button flex cable out of the way.
  12. Screen Assembly Replacement: step 12, image 1 of 2 Screen Assembly Replacement: step 12, image 2 of 2
    • Pry up and disconnect the antenna cable.
    • Fold the antenna cable out of the way.
  13. Screen Assembly Replacement: step 13, image 1 of 2 Screen Assembly Replacement: step 13, image 2 of 2
    • Use the tip of a spudger to open the interconnect cable ZIF connector by lifting the brown flap.
    • When reassembling make sure the white line on the cable aligns with the closed flap.
  14. Screen Assembly Replacement: step 14, image 1 of 2 Screen Assembly Replacement: step 14, image 2 of 2
    • Use a pair of tweezers to pull the interconnect flex cable out of the ZIF connector.
  15. Screen Assembly Replacement: step 15, image 1 of 2 Screen Assembly Replacement: step 15, image 2 of 2
    • Use the tip of a spudger to open the flap of the ZIF connector next to the headphone jack.
  16. Screen Assembly Replacement: step 16, image 1 of 2 Screen Assembly Replacement: step 16, image 2 of 2
    • Use a pair of tweezers to pull the flex cable out of the ZIF connector.
  17. Screen Assembly Replacement: step 17, image 1 of 2 Screen Assembly Replacement: step 17, image 2 of 2
    • Don't try to remove the motherboard all the way yet. The display flex cable is still connected to its rear side.
    • Use a spudger to carefully lift the motherboard until you can get a good grip. Avoid to damage the cables next to the motherboard.
    • Lift the motherboard and fold it back until you have enough space to disconnect the display flex cable.
  18. Screen Assembly Replacement: step 18, image 1 of 2 Screen Assembly Replacement: step 18, image 2 of 2
    • Use the edge of a spudger to pry up and disconnect the display flex cable from the motherboard.
  19. Screen Assembly Replacement: step 19, image 1 of 1
    • Remove the motherboard.
  20. Screen Assembly Replacement, Daughterboard: step 20, image 1 of 2 Screen Assembly Replacement, Daughterboard: step 20, image 2 of 2
    • Disconnect the antenna cable and fold it out of the way.
  21. Screen Assembly Replacement: step 21, image 1 of 2 Screen Assembly Replacement: step 21, image 2 of 2
    • Use the tip of a spudger to open the brown flap of the ZIF connector that holds the interconnect cable in its place.
  22. Screen Assembly Replacement: step 22, image 1 of 2 Screen Assembly Replacement: step 22, image 2 of 2
  23. Screen Assembly Replacement: step 23, image 1 of 1
    • Prepare an iOpener and apply it to the bottom part of the display for at least two minutes to loosen the adhesive beneath the daughterboard.
  24. Screen Assembly Replacement: step 24, image 1 of 3 Screen Assembly Replacement: step 24, image 2 of 3 Screen Assembly Replacement: step 24, image 3 of 3
    • Apply an opening pick to the bottom edge of the daughterboard.
    • Carefully slide the opening pick under the daughterboard to cut the adhesive underneath.
    • Take care to cut the adhesive underneath the vibration motor.
    • Slide the opening pick from right to left to cut all the adhesive.
  25. Screen Assembly Replacement: step 25, image 1 of 1
    • Remove the daughterboard including the soldered-on vibration motor.
  26. Screen Assembly Replacement, Earpiece Speaker: step 26, image 1 of 1
    • Use an iOpener and apply it to the top edge of the display to loosen the adhesive beneath the earpiece speaker.
  27. Screen Assembly Replacement: step 27, image 1 of 2 Screen Assembly Replacement: step 27, image 2 of 2
    • Use a pair of tweezers to carefully grab and remove the earpiece speaker.
  28. Screen Assembly Replacement, Screen Assembly: step 28, image 1 of 2 Screen Assembly Replacement, Screen Assembly: step 28, image 2 of 2
    • Use a pair of tweezers to remove the rubber headphone jack gasket in the corner of the display assembly.
  29. Screen Assembly Replacement: step 29, image 1 of 2 Screen Assembly Replacement: step 29, image 2 of 2
    • Use a pair of tweezers to remove the rubber charging port gasket.
  30. Screen Assembly Replacement: step 30, image 1 of 2 Screen Assembly Replacement: step 30, image 2 of 2
    • Use a pair of tweezers to grab and remove the microphone rubber gasket at the bottom right end of your phone.
  31. Screen Assembly Replacement: step 31, image 1 of 1
    • Use an iOpener to loosen the adhesive tape that sits on top of the interconnect and display flex cable. Apply the iOpener on the tape for at least two minutes.
  32. Screen Assembly Replacement: step 32, image 1 of 3 Screen Assembly Replacement: step 32, image 2 of 3 Screen Assembly Replacement: step 32, image 3 of 3
    • Use a pair of tweezers to gently peel the adhesive tape off the flex cables and fold it out of the way.
  33. Screen Assembly Replacement: step 33, image 1 of 2 Screen Assembly Replacement: step 33, image 2 of 2
    • Use a pair of tweezers to gently peel the product sticker off the interconnect cable.
    • In case you can't remove the sticker or it starts to rip apart you can re-apply an iOpener to loosen the adhesive.
  34. Screen Assembly Replacement: step 34, image 1 of 2 Screen Assembly Replacement: step 34, image 2 of 2
    • Use a pair of tweezers to grab and carefully peel up the interconnect flex cable.
    • Remove the interconnect flex cable.
  35. Screen Assembly Replacement: step 35, image 1 of 2 Screen Assembly Replacement: step 35, image 2 of 2
    • Use a pair of tweezers to remove the antenna cable.
  36. Screen Assembly Replacement: step 36, image 1 of 1
    • Check your replacement part for any other components that need to be transferred before reassembly.
Dominik Schnabelrauch
204,050 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,198 Guides authored
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 21
All Time: 2,116
