Moto C Daughterboard Replacement
  1. Moto C Daughterboard Replacement, Back Cover: step 1, image 1 of 3 Moto C Daughterboard Replacement, Back Cover: step 1, image 2 of 3 Moto C Daughterboard Replacement, Back Cover: step 1, image 3 of 3
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or spudger, into the notch on the bottom right corner to start separating the phone unit from the back cover.
    • Move it to the bottom left corner and pry the phone unit out of the back cover until you can get a good grip.
  2. Moto C Daughterboard Replacement: step 2, image 1 of 2 Moto C Daughterboard Replacement: step 2, image 2 of 2
    • Lift the phone out of the back cover.
  3. Moto C Daughterboard Replacement, Battery: step 3, image 1 of 3 Moto C Daughterboard Replacement, Battery: step 3, image 2 of 3 Moto C Daughterboard Replacement, Battery: step 3, image 3 of 3
    • Use a finger or spudger to lever the battery out of its recess and remove it.
  4. Moto C Daughterboard Replacement, Daughterboard Cover: step 4, image 1 of 1
    • Remove the four 3.5 mm long Torx T5 screws.
    • Some screws might be covered with stickers.
  5. Moto C Daughterboard Replacement: step 5, image 1 of 3 Moto C Daughterboard Replacement: step 5, image 2 of 3 Moto C Daughterboard Replacement: step 5, image 3 of 3
    • Apply the edge of an opening pick to the bottom right corner under the daughterboard cover.
    • Twist the opening pick to open the plastic clamps of the daughterboard cover.
    • Slide the opening pick to the left and pry it upwards until you can get a good grip on the daughterboard cover.
  6. Moto C Daughterboard Replacement: step 6, image 1 of 1
    • Remove the daughterboard cover.
  7. Moto C Daughterboard Replacement, Daughterboard: step 7, image 1 of 2 Moto C Daughterboard Replacement, Daughterboard: step 7, image 2 of 2
    • Use a pair of tweezers to disconnect the antenna cable on the left of the daughterboard.
  8. Moto C Daughterboard Replacement: step 8, image 1 of 2 Moto C Daughterboard Replacement: step 8, image 2 of 2
    • Use a spudger to disconnect the digitizer flex cable on the upper left of the daughterboard.
  9. Moto C Daughterboard Replacement: step 9, image 1 of 2 Moto C Daughterboard Replacement: step 9, image 2 of 2
    • Use a pair of tweezers to remove the rubber gasket that covers the microphone on the bottom right of the daughterboard.
  10. Moto C Daughterboard Replacement: step 10, image 1 of 1
    • Prepare an iOpener and apply it to the bottom part of the display for at least two minutes to loosen the adhesive beneath the daughterboard.
  11. Moto C Daughterboard Replacement: step 11, image 1 of 3 Moto C Daughterboard Replacement: step 11, image 2 of 3 Moto C Daughterboard Replacement: step 11, image 3 of 3
    • Apply an opening pick to the bottom right corner of the daughterboard.
    • Carefully slide the opening pick under the daughterboard to cut the adhesive underneath.
    • Slide the opening pick from right to left to cut all the adhesive.
  12. Moto C Daughterboard Replacement: step 12, image 1 of 2 Moto C Daughterboard Replacement: step 12, image 2 of 2
    • Twist the opening pick to lift the daughterboard until you can get a good grip.
    • Remove the daughterboard.
Dominik Schnabelrauch
204,929 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,420 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 401
