Introduction
Use this guide to replace the charging port in a Microsoft Surface Pro.
Use a heated iOpener or a heat gun to heat the edges of the display and soften its adhesive.
Apply a suction cup as close as possible to the edge of the display.
Use the suction cup to lift the edge of the display enough to insert an opening pick under the edge.
Slide the opening pick all the way around the edges of the display to cut through the adhesive on the bezel.
Ribbon cables and a circuit board are approx. 0.6 cm from the edge of the glass.
Starting from the top edge, lift the display slightly.
Before completely removing the display:
Disconnect the three display cables.
Gently peel from the frame 2 orange ribbon cables that are glued to it, as those should stay with the display. (e.g. use a thin plastic card to separate them)
Using a T5 Torx screwdriver, unscrew a total number of 23 screws located on the outside panel of the Surface Pro.
Use the T5 torx screw driver to unscrew the 6 T5 screws in the left and right outside metal panels
Use the T2 torx screw driver to unscrew the 23 T2 screws on the left and right outside metal panels
