Introduction
*In order to access the charging port, refer to steps 1 - 6 in the Microsoft Surface Pro Teardown Guide to remove the screen.
Use a heated iOpener or a heat gun to heat the edges of the display and soften its adhesive.
Apply a suction cup as close as possible to the edge of the display.
Use the suction cup to lift the edge of the display enough to insert an opening pick under the edge.
Slide the opening pick all the way around the edges of the display to cut through the adhesive on the bezel.
Starting from the top edge, lift the display slightly. If you feel any resistance, use heat and an opening pick to slice through any remaining adhesive.
Before completely removing the display, disconnect the three display cables.
Using a T5 Torx screwdriver, unscrew a total number of 23 screws located on the outside panel of the Surface Pro.
Use the T5 torx screw driver to unscrew the 6 T5 screws in the left and right outside metal panels
Use the T2 torx screw driver to unscrew the 23 T2 screws on the left and right outside metal panels
