Replacing Coffee Spout Manifold on Melitta Caffeo Solo
  1. Replacing Coffee Spout Manifold on Melitta Caffeo Solo, Coffee Spout Manifold: step 1, image 1 of 1
    • The glossy cover over the coffee spout is only snapped into place.
    • At the cover bottom you will find a tab in the middle above a catch. Lift the tab a little with a flat screwdriver and detach it from the catch.
    • Lift up the cover.
  2. Replacing Coffee Spout Manifold on Melitta Caffeo Solo: step 2, image 1 of 2 Replacing Coffee Spout Manifold on Melitta Caffeo Solo: step 2, image 2 of 2
    • The coffee spout distributor is only snapped into place. Use your fingers to grab it from the top and lift it away from the machine. The first time it may stick pretty tight.
  3. Replacing Coffee Spout Manifold on Melitta Caffeo Solo: step 3, image 1 of 2 Replacing Coffee Spout Manifold on Melitta Caffeo Solo: step 3, image 2 of 2
    • Remove the chrome trim from the outlet nozzles.
    • Slide off the inlet hose.
Repeat the steps in reverse order to reassemble the device.
18 other people completed this guide.
Special thanks to these translators:
de en
100%
VauWeh is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
202,633 Reputation
246 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
25 Members
1,107 Guides authored
10 Comments
Hallo, besten Dank für die Tipps, damit habe ich es geschafft. Bei Schritt 2 würde ich eher sagen den Kaffeeauslaufverteiler nach => vorne rausziehen. Spülen geht auch, man muss nicht unbedingt ein Ersatzteil bestellen. Ist aber sicher irgendwann hygienischer und der Kaffee wird von den festsitzenden Resten im Verteiler ja auch nicht besser!
Thomas Bousonville - Reply
Very useful, thanks for the explanation. Getting the cover off was most difficult, the rest was easy. Cleaning the manifold with soda works perfectly, no need to replace.
Pieter Hooijmans - Reply
Der Ausbau war in der Ausbauanleitung sehr gut beschrieben. Ein Neukauf des Verteilers war nicht notwendig. Ich habe durch die beiden Ablaufdüsen mit einem feinen Wasserstrahl den Verteilerbehälter mehrfach ausgespült bis kein Kaffeesatz mehr rauslief. Die beiden Kaffeeablaufdüsen laufen wieder gleichmäßig.
karl.lucas - Reply
Ich habe es nach dem Spülen noch in einer Schüssel Wasser mit einer Reinigungstablette liegen lassen. Kam sehr viel Dreck noch heraus.
Maximilian Huber -
Vielen Dank, der Auslauf lässt sich mit ein wenig Geduld spülen. Die Anleitung zum Ausbau von ist sehr hilfreich.
Nedra - Reply
Past 24 Hours: 17
Past 7 Days: 201
Past 30 Days: 874
All Time: 29,727
