Introduction
You have to replace the heater if the coffee is too cold or the flow is - mostly disturbed by limescale.
Remove the water tank and drainage tray.
Remove the side cover and remove the brewing unit.
Remove all coffee beans.
Press carefully into the slits on the sides using a minus screwdriver or a flat metal spatula, to release the clasps on the upper surface. These may be well tight and you have to use some force.
You should have created a separation between the upper surface and side panels. Now lever the upper covering away using a plastic tool. This may be quite stuck and you may apply some force.
Repeat the steps in reverse order to reassemble your device.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
2 Comments
Sehr schöne Anleitung! Stehe gerade vor der selben Maschine und prüfe gerade warum kein Wasser herauskommt.
Schläuche wurden geprüft, Flowmeter geprüft, ist alles freigängig. Pumpe drückt Wasser bis zum Erhitzer. Ich denke dieser ist verkalkt.
Schöne Anleitung, enthält alles was man braucht!
Zum Prüfen einfach reinblasen. Muss ziemlich leicht gehen.
VauWeh -
