Introduction
このガイドに従って、お使いのMacBook Prop 13インチ 2010のハードドライブを交換またはアップグレードしてください。
必要に応じて、古いハードディスクドライブから新しいハードディスクドライブにすべてのデータをコピーすることを忘れないでください。
MacBook Pro 13インチ Unibodyに留められた底ケースから次のネジを10本外します。
3 mmプラスネジー7本
13.5 mmプラスネジー3本
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
526 other people completed this guide.
Special thanks to these translators:
100%
Midori Doi is helping us fix the world! Want to contribute?
Start translating ›
15 Guide Comments
THANK YOU! I'm still on a high from repairing my husband's Macbook. It feels so nice to have two computers up and running again. You saved me nearly a grand, and made me realize how much I really did learn as a kid building PC towers with my dad.
Hi, I got the 1TB SSD Hybrid you have listed above. Regardless of what I try, my computer does not recognize it. It sees the 32GB flash drive I used for an install disk and it sees my USB external drive where I have the time machine backup. But it just can't see this drive. Is there any troubleshooting for this product? Thanks!
Hi Robbyglasco, Have you been able to fix the issue? I'm having the same problem :-)
lkaravis -
I know this is a long time after the event for both of you, but for others Im pretty sure that this will be that you haven't yet formatted the SSD in Disk Utility. Before you can reinstall from Time Machine you have to go into Disk Utility and format the SSD. You get to Disk Utility from the option screen after you have booted the computer with "Command and R" (cmd-R).
Thank you very much. This made the job much easier than it would have been if I had to figure it out for myself.
I replaced a 5 year old 320GB hard drive with a new 1TB hard drive. I first cloned the drive by attaching the new one via a USB dongle and running Carbon Copy Cloner. Then I booted the new drive via USB to confirm that it was properly cloned.
Then I followed the directions here. It took all of 15 minutes to do, because I knew exactly what to expect and had all the necessary tools on-hand. Your web site is an incredibly valuable resource. Thanks again.
