Mac mini Late 2018 Logic Board Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Mac mini Late 2018 Logic Board Assembly Replacement, Logic Board Assembly: step 1, image 1 of 1
    • Grasp the power supply cable and lift to disconnect it from the logic board, wiggling as needed to loosen it up.
  2. Mac mini Late 2018 Logic Board Assembly Replacement: step 2, image 1 of 2 Mac mini Late 2018 Logic Board Assembly Replacement: step 2, image 2 of 2
    • Carefully lift the connector for the LED indicator light straight up to disconnect it from its socket on the logic board.
  3. Mac mini Late 2018 Logic Board Assembly Replacement: step 3, image 1 of 2 Mac mini Late 2018 Logic Board Assembly Replacement: step 3, image 2 of 2
    • Use a T10 Torx driver to remove the two 7.5 mm screws securing the logic board.
  4. Mac mini Late 2018 Logic Board Assembly Replacement: step 4, image 1 of 3 Mac mini Late 2018 Logic Board Assembly Replacement: step 4, image 2 of 3 Mac mini Late 2018 Logic Board Assembly Replacement: step 4, image 3 of 3
    • In this step you will be pushing the logic board free from clips holding it to the frame. Push only where directed or you may damage the fragile cooling fins.
    • Place a thumb at each end of the exhaust vent, over the fan screw holes.
    • Push firmly in the direction of the ports until the logic board unclips and begins to slide out of the Mac mini.
Jeff Suovanen
429,556 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,524 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 166
