Mac mini Late 2018 Logic Board Assembly Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Mac mini Late 2018 Logic Board Assembly Replacement, Logic Board Assembly: step 1, image 1 of 1
      • Grasp the power supply cable and lift to disconnect it from the logic board, wiggling as needed to loosen it up.
      Ask FixBot
    2. Mac mini Late 2018 Logic Board Assembly Replacement: step 2, image 1 of 2 Mac mini Late 2018 Logic Board Assembly Replacement: step 2, image 2 of 2
      • Carefully lift the connector for the LED indicator light straight up to disconnect it from its socket on the logic board.
      • Take care not to pry under the socket, or you may break it off the board.
      Ask FixBot
    3. Mac mini Late 2018 Logic Board Assembly Replacement: step 3, image 1 of 2 Mac mini Late 2018 Logic Board Assembly Replacement: step 3, image 2 of 2
      • Use a T10 Torx driver to remove the two 7.5 mm screws securing the logic board.
      Ask FixBot
    4. Mac mini Late 2018 Logic Board Assembly Replacement: step 4, image 1 of 3 Mac mini Late 2018 Logic Board Assembly Replacement: step 4, image 2 of 3 Mac mini Late 2018 Logic Board Assembly Replacement: step 4, image 3 of 3
      • In this step, you'll push the logic board free from the clips holding it to the frame. Push only where directed or you may damage the fragile cooling fins.
      • Place a thumb at each end of the exhaust vent, over the fan screw holes.
      • Push firmly in the direction of the ports until the logic board unclips and begins to slide out of the Mac mini.
      Ask FixBot
    5. Mac mini Late 2018 Logic Board Assembly Replacement: step 5, image 1 of 2 Mac mini Late 2018 Logic Board Assembly Replacement: step 5, image 2 of 2
      • Slide the logic board out of the case.
      • When reinstalling the logic board, make sure to hold the thin LED indicator light cable out of the way so it doesn't get damaged.
      Ask FixBot
Jeff Suovanen
454,994 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 28
All Time: 580
