Logitech UE Megaboom 4 Battery Replacement
    1. Logitech UE Megaboom 4 Battery Replacement, Position your speaker: step 1, image 1 of 1
      • Flip your speaker upside down so the charging port side is faced upwards.
      Ask FixBot
    2. Logitech UE Megaboom 4 Battery Replacement, Insert an opening pick: step 2, image 1 of 3 Logitech UE Megaboom 4 Battery Replacement, Insert an opening pick: step 2, image 2 of 3 Logitech UE Megaboom 4 Battery Replacement, Insert an opening pick: step 2, image 3 of 3
      • Insert an opening pick between the mesh case and bottom cover.
      Ask FixBot
    3. Logitech UE Megaboom 4 Battery Replacement, Create a gap: step 3, image 1 of 3 Logitech UE Megaboom 4 Battery Replacement, Create a gap: step 3, image 2 of 3 Logitech UE Megaboom 4 Battery Replacement, Create a gap: step 3, image 3 of 3
      Ask FixBot
    4. Logitech UE Megaboom 4 Battery Replacement, Insert the opening tool into the gap: step 4, image 1 of 2 Logitech UE Megaboom 4 Battery Replacement, Insert the opening tool into the gap: step 4, image 2 of 2
      • Insert a metal spudger into the gap between the rubber bottom and the mesh case.
      • Use the metal spudger carefully. Improper use may damage your device or lead to injury.
      Ask FixBot
    5. Logitech UE Megaboom 4 Battery Replacement, Separate the bottom cover from the case: step 5, image 1 of 3 Logitech UE Megaboom 4 Battery Replacement, Separate the bottom cover from the case: step 5, image 2 of 3 Logitech UE Megaboom 4 Battery Replacement, Separate the bottom cover from the case: step 5, image 3 of 3
      • Pry the cover to release the clips that secure the cover to the mesh case.
      • This may take some force.
      Ask FixBot
    6. Logitech UE Megaboom 4 Battery Replacement: step 6, image 1 of 3 Logitech UE Megaboom 4 Battery Replacement: step 6, image 2 of 3 Logitech UE Megaboom 4 Battery Replacement: step 6, image 3 of 3
      • Work your way around the base of the speaker until the lid separates from the case of the speaker.
      Ask FixBot
    7. Logitech UE Megaboom 4 Battery Replacement: step 7, image 1 of 1
      • Remove the bottom of the speaker and place it off to the side.
      • Once the glued seal is broken you will be able to pull it off with your hands.
      Ask FixBot
    8. Logitech UE Megaboom 4 Battery Replacement: step 8, image 1 of 3 Logitech UE Megaboom 4 Battery Replacement: step 8, image 2 of 3 Logitech UE Megaboom 4 Battery Replacement: step 8, image 3 of 3
      • Push with your thumbs on the two plastic pieces on the inside of your speaker.
      • The inside components will begin to slide out of the top from the mesh casing.
      Ask FixBot
    9. Logitech UE Megaboom 4 Battery Replacement: step 9, image 1 of 1
      • The case and internal components of your speaker should now be separated.
      Ask FixBot
    10. Logitech UE Megaboom 4 Battery Replacement: step 10, image 1 of 3 Logitech UE Megaboom 4 Battery Replacement: step 10, image 2 of 3 Logitech UE Megaboom 4 Battery Replacement: step 10, image 3 of 3
      • Pull the battery out with your fingers.
      • When pulling the battery out, you may need to wiggle it a little bit or use a rubber grip on your fingers.
      Ask FixBot
    11. Logitech UE Megaboom 4 Battery Replacement: step 11, image 1 of 1
      • When installing the new battery, ensure that the battery connector aligns with the connector on the speaker so they don't get damaged.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 other people completed this guide.
2 Guide Comments
ifixt it doesn't have the battery replacement version for the Ultimate Ears - MEGABOOM 4 and only show replacement battery for older model and I think this get confuse for new users in the repair world
Gio Ortegini - Reply Share
Hi Gio,
Thanks for pointing this out! We’ve removed the link to the incorrect battery and appreciate your help keeping the guide accurate.
Sarah Westberg - Reply Share
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 128
All Time: 1,293
