Logitech RS50 Base Slip Ring Replacement
    1. Logitech RS50 Base Slip Ring Replacement, Safety precautions: step 1, image 1 of 2 Logitech RS50 Base Slip Ring Replacement, Safety precautions: step 1, image 2 of 2
      • Disconnect all cables from the base.
      • Unmount the base from your setup and remove any accessories so you're left with just the base.
      Ask FixBot
    2. Logitech RS50 Base Slip Ring Replacement, Remove the QR adapter screws: step 2, image 1 of 1
      • Use a 2.5 mm hex driver to remove the two 23 mm‑long screws securing the QR (Quick Release) adapter.
      Ask FixBot
    3. Logitech RS50 Base Slip Ring Replacement, Pull out the QR adapter: step 3, image 1 of 3 Logitech RS50 Base Slip Ring Replacement, Pull out the QR adapter: step 3, image 2 of 3 Logitech RS50 Base Slip Ring Replacement, Pull out the QR adapter: step 3, image 3 of 3
      • Don't try to remove the QR adapter—it's still connected by a cable.
      • Carefully pull the adapter out of the shaft as far as possible.
      • Use your fingers to separate the spring from the adapter.
      Ask FixBot
    4. Logitech RS50 Base Slip Ring Replacement, Disconnect the QR adapter: step 4, image 1 of 2 Logitech RS50 Base Slip Ring Replacement, Disconnect the QR adapter: step 4, image 2 of 2
      • Use tweezers to squeeze the base of the slip ring connector and gently pull it out of its socket.
      Ask FixBot
    5. Logitech RS50 Base Slip Ring Replacement: step 5, image 1 of 2 Logitech RS50 Base Slip Ring Replacement: step 5, image 2 of 2
      • Remove the QR adapter and store it for reassembly.
      • Remove the spring and store it for reassembly.
      Ask FixBot
    6. Logitech RS50 Base Slip Ring Replacement, Tuck the slip ring connector: step 6, image 1 of 1
      • Tuck the slip ring connector into the shaft to keep it out of the way.
      Ask FixBot
    7. Logitech RS50 Base Slip Ring Replacement, Remove the back cover: step 7, image 1 of 1
      • Use a 5 mm hex driver to remove the four 28 mm‑long bolts securing the back cover.
      Ask FixBot
    8. Logitech RS50 Base Slip Ring Replacement: step 8, image 1 of 2 Logitech RS50 Base Slip Ring Replacement: step 8, image 2 of 2
      • Remove the back cover.
      Ask FixBot
    9. Logitech RS50 Base Slip Ring Replacement, Tilt the base: step 9, image 1 of 2 Logitech RS50 Base Slip Ring Replacement, Tilt the base: step 9, image 2 of 2
      • Tilt the base forward so it rests squarely on the shaft.
      Ask FixBot
    10. Logitech RS50 Base Slip Ring Replacement, Disconnect the encoder: step 10, image 1 of 3 Logitech RS50 Base Slip Ring Replacement, Disconnect the encoder: step 10, image 2 of 3 Logitech RS50 Base Slip Ring Replacement, Disconnect the encoder: step 10, image 3 of 3
      • Use the tip of a spudger or your fingernail to flip up the small, hinged locking flap on the encoder ZIF connector.
      Ask FixBot
    11. Logitech RS50 Base Slip Ring Replacement: step 11, image 1 of 2 Logitech RS50 Base Slip Ring Replacement: step 11, image 2 of 2
      • Slide the encoder cable out of the socket.
      Ask FixBot
    12. Logitech RS50 Base Slip Ring Replacement, Disconnect the case temperature sensor: step 12, image 1 of 3 Logitech RS50 Base Slip Ring Replacement, Disconnect the case temperature sensor: step 12, image 2 of 3 Logitech RS50 Base Slip Ring Replacement, Disconnect the case temperature sensor: step 12, image 3 of 3
      • Use your finger to press the tab at the base of the case temperature connector and gently slide it out of its socket.
      Ask FixBot
    13. Logitech RS50 Base Slip Ring Replacement, Disconnect the slip ring: step 13, image 1 of 3 Logitech RS50 Base Slip Ring Replacement, Disconnect the slip ring: step 13, image 2 of 3 Logitech RS50 Base Slip Ring Replacement, Disconnect the slip ring: step 13, image 3 of 3
      • Use tweezers to squeeze the tab at the base of the slip ring connector and gently pull it out of its socket.
      Ask FixBot
    14. Logitech RS50 Base Slip Ring Replacement, Disconnect the ballast: step 14, image 1 of 3 Logitech RS50 Base Slip Ring Replacement, Disconnect the ballast: step 14, image 2 of 3 Logitech RS50 Base Slip Ring Replacement, Disconnect the ballast: step 14, image 3 of 3
      • With one hand, hold the ballast connector socket with your fingers to keep it from breaking off.
      • With your other hand, squeeze the top of the ballast connector to unlock it and slide it out of its socket.
      Ask FixBot
    15. Logitech RS50 Base Slip Ring Replacement: step 15, image 1 of 2 Logitech RS50 Base Slip Ring Replacement: step 15, image 2 of 2
      • Use tweezers to squeeze the tab at the base of the ballast temperature connector and slide it out of its socket.
      Ask FixBot
    16. Logitech RS50 Base Slip Ring Replacement, Remove the circuit board screws: step 16, image 1 of 1
      • Use a Torx T8 driver to remove the four screws securing the circuit board:
      • Three 7.6 mm‑long screws
      • One 12 mm‑long silver screw
      Ask FixBot
    17. Logitech RS50 Base Slip Ring Replacement, Flip the circuit board up: step 17, image 1 of 3 Logitech RS50 Base Slip Ring Replacement, Flip the circuit board up: step 17, image 2 of 3 Logitech RS50 Base Slip Ring Replacement, Flip the circuit board up: step 17, image 3 of 3
      • The circuit board is still connected along the top edge by various cables. Make sure not to strain these cables as you follow this step.
      • Slowly lift the bottom edge to flip the board up, threading the slip ring cable through its cutout, until the board sits perpendicular to the base.
      Ask FixBot
    18. Logitech RS50 Base Slip Ring Replacement, Align the slip ring adapter: step 18, image 1 of 3 Logitech RS50 Base Slip Ring Replacement, Align the slip ring adapter: step 18, image 2 of 3 Logitech RS50 Base Slip Ring Replacement, Align the slip ring adapter: step 18, image 3 of 3
      • Rotate the base to align the slip ring adapter so that its flange can slide past the sensor board.
      Ask FixBot
    19. Logitech RS50 Base Slip Ring Replacement, Remove the slip ring adapter screws: step 19, image 1 of 1
      • Use a 1.5 mm hex driver to remove the three 7 mm‑long screws securing the slip ring adapter.
      Ask FixBot
    20. Logitech RS50 Base Slip Ring Replacement, Remove the slip ring: step 20, image 1 of 3 Logitech RS50 Base Slip Ring Replacement, Remove the slip ring: step 20, image 2 of 3 Logitech RS50 Base Slip Ring Replacement, Remove the slip ring: step 20, image 3 of 3
      • Pull the slip ring adapter out of the shaft and remove it.
      • The slip ring is adhered inside the plastic adapter and will come out with it.
      Ask FixBot
    21. Logitech RS50 Base Slip Ring Replacement, Identify the adhesive: step 21, image 1 of 2 Logitech RS50 Base Slip Ring Replacement, Identify the adhesive: step 21, image 2 of 2
      • If the slip ring adhesive is white and thin, proceed to the next step to remove it.
      • If the slip ring adhesive is black and feels like foam, skip down one step.
      Ask FixBot
    22. Logitech RS50 Base Slip Ring Replacement, Remove the white adhesive strip: step 22, image 1 of 1
      • Use tweezers to pull the white adhesive strip out between the slip ring adapter and the slip ring.
      • Skip the next step.
      Ask FixBot
    23. Logitech RS50 Base Slip Ring Replacement, Remove the black adhesive strip: step 23, image 1 of 3 Logitech RS50 Base Slip Ring Replacement, Remove the black adhesive strip: step 23, image 2 of 3 Logitech RS50 Base Slip Ring Replacement, Remove the black adhesive strip: step 23, image 3 of 3
      • Use an opening pick to gently slice between the adapter arms to separate the black adhesive strip from them.
      • Be careful not to apply too much force, or you may damage the adapter arms.
      Ask FixBot
    24. Logitech RS50 Base Slip Ring Replacement, Remove the slip ring adapter: step 24, image 1 of 3 Logitech RS50 Base Slip Ring Replacement, Remove the slip ring adapter: step 24, image 2 of 3 Logitech RS50 Base Slip Ring Replacement, Remove the slip ring adapter: step 24, image 3 of 3
      • Use the flat end of a spudger to push the top of the slip ring (the end with the shorter cable) until it slides out of the adapter.
      Ask FixBot
    25. Logitech RS50 Base Slip Ring Replacement, Clean the slip ring adapter: step 25, image 1 of 1
      • Use the point of a spudger to scrape away any remaining adhesive from the inside of the adapter.
      Ask FixBot
    1. Logitech RS50 Base Slip Ring Replacement, Disassembly complete: step 26, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your device.
      Ask FixBot
    2. Logitech RS50 Base Slip Ring Replacement, Install the slip ring adhesive: step 27, image 1 of 1
      • Peel the opaque yellow liner from the slip ring adhesive strip.
      Ask FixBot
    3. Logitech RS50 Base Slip Ring Replacement: step 28, image 1 of 2 Logitech RS50 Base Slip Ring Replacement: step 28, image 2 of 2
      • Press the exposed adhesive onto the side of the replacement slip ring and wrap it around the body.
      Ask FixBot
    4. Logitech RS50 Base Slip Ring Replacement: step 29, image 1 of 2 Logitech RS50 Base Slip Ring Replacement: step 29, image 2 of 2
      • Use your fingers to squeeze the adhesive for ten seconds to help adhere it to the slip ring.
      • Peel away the outer liner to expose the adhesive.
      Ask FixBot
    5. Logitech RS50 Base Slip Ring Replacement, Install the slip ring into the adapter: step 30, image 1 of 3 Logitech RS50 Base Slip Ring Replacement, Install the slip ring into the adapter: step 30, image 2 of 3 Logitech RS50 Base Slip Ring Replacement, Install the slip ring into the adapter: step 30, image 3 of 3
      • Thread the slip ring's short cable through the back of the slip ring adapter (the end with the arms).
      • Push the slip ring into the adapter until it's fully seated with no room to move.
      Ask FixBot
    6. Logitech RS50 Base Slip Ring Replacement: step 31, image 1 of 1
      • Use your fingers to squeeze the adapter arms against the slip ring for 10 seconds to adhere it in place.
      Ask FixBot
    7. Logitech RS50 Base Slip Ring Replacement, Install the slip ring adapter: step 32, image 1 of 1
      • Insert the slip ring's long cable into the back of the shaft and guide it through to the front.
      Ask FixBot
    8. Logitech RS50 Base Slip Ring Replacement: step 33, image 1 of 3 Logitech RS50 Base Slip Ring Replacement: step 33, image 2 of 3 Logitech RS50 Base Slip Ring Replacement: step 33, image 3 of 3
      • Align the slip ring adapter to the base using the alignment pin and slide the adapter into the shaft.
      • Make sure the pin isn't aligning with a screw hole, or the adapter won't sit flush.
      • When it's properly aligned, the adapter should sit flush against the base, and the three screw holes will be visible.
      Ask FixBot
    9. Logitech RS50 Base Slip Ring Replacement: step 34, image 1 of 2 Logitech RS50 Base Slip Ring Replacement: step 34, image 2 of 2
      • Use a 1.5 mm hex driver to install the three 7 mm‑long slip ring adapter screws.
      • If you have trouble reaching the screws, rotate the base to get better access.
      Ask FixBot
    10. Logitech RS50 Base Slip Ring Replacement, Install the circuit board: step 35, image 1 of 3 Logitech RS50 Base Slip Ring Replacement, Install the circuit board: step 35, image 2 of 3 Logitech RS50 Base Slip Ring Replacement, Install the circuit board: step 35, image 3 of 3
      Ask FixBot
    11. Logitech RS50 Base Slip Ring Replacement: step 36, image 1 of 2 Logitech RS50 Base Slip Ring Replacement: step 36, image 2 of 2
      • Move the cable tie into position over its circuit board screw hole.
      Ask FixBot
    12. Logitech RS50 Base Slip Ring Replacement: step 37, image 1 of 1
      • Use a Torx T8 driver to install the four circuit board screws:
      Ask FixBot
    13. Logitech RS50 Base Slip Ring Replacement, Connect the circuit board: step 38, image 1 of 3 Logitech RS50 Base Slip Ring Replacement, Connect the circuit board: step 38, image 2 of 3 Logitech RS50 Base Slip Ring Replacement, Connect the circuit board: step 38, image 3 of 3
      • Use your fingers to slide the ballast temperature connector fully into its socket to connect it.
      • Repeat for the ballast connector above it.
      Ask FixBot
    14. Logitech RS50 Base Slip Ring Replacement: step 39, image 1 of 2 Logitech RS50 Base Slip Ring Replacement: step 39, image 2 of 2
      • Insert the slip ring connector into its socket to connect it.
      Ask FixBot
    15. Logitech RS50 Base Slip Ring Replacement: step 40, image 1 of 2 Logitech RS50 Base Slip Ring Replacement: step 40, image 2 of 2
      • Insert the base temperature connector into its socket to connect it.
      Ask FixBot
    16. Logitech RS50 Base Slip Ring Replacement: step 41, image 1 of 2 Logitech RS50 Base Slip Ring Replacement: step 41, image 2 of 2
      • Slide the encoder cable fully into its ZIF socket.
      Ask FixBot
    17. Logitech RS50 Base Slip Ring Replacement: step 42, image 1 of 2 Logitech RS50 Base Slip Ring Replacement: step 42, image 2 of 2
      • While holding the cable in place, use your finger to flip down the locking flap to secure the encoder cable.
      Ask FixBot
    18. Logitech RS50 Base Slip Ring Replacement, Install the back cover: step 43, image 1 of 2 Logitech RS50 Base Slip Ring Replacement, Install the back cover: step 43, image 2 of 2
      • Place the back cover over the back of the base.
      Ask FixBot
    19. Logitech RS50 Base Slip Ring Replacement: step 44, image 1 of 1
      • Use a 5 mm hex driver to install the four 28 mm‑long back cover bolts.
      Ask FixBot
    20. Logitech RS50 Base Slip Ring Replacement, Install the spring: step 45, image 1 of 1
      • Insert the spring into the front of the shaft.
      Ask FixBot
    21. Logitech RS50 Base Slip Ring Replacement, Install the QR adapter: step 46, image 1 of 2 Logitech RS50 Base Slip Ring Replacement, Install the QR adapter: step 46, image 2 of 2
      • Use tweezers to hold the slip ring connector near the base and connect it to the QR adapter socket.
      Ask FixBot
    22. Logitech RS50 Base Slip Ring Replacement: step 47, image 1 of 1
      • Insert the QR adapter into the front of the shaft.
      Ask FixBot
    23. Logitech RS50 Base Slip Ring Replacement: step 48, image 1 of 1
      • Use a 2.5 mm hex driver to install the two 23 mm‑long QR adapter screws.
      • Even though it looks symmetrical, the QR adapter screw holes align to the shaft in only one way. If the screws don't seem to align, try rotating the adapter.
      Ask FixBot
Arthur Shi
350,754 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 30
Past 30 Days: 119
All Time: 290
