Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓Follow this guide to replace a worn-out or dead battery in your Logitech MX Mechanical wireless keyboard.
It’s natural for batteries to lose capacity as they age. If your keyboard dies quickly and doesn't hold a charge, it may be time to replace the battery.
For safety, perform this repair when your battery is below 15% charge. Any charged lithium-ion battery can be hazardous if punctured or damaged. If your battery looks puffy or swollen, take appropriate precautions.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Unplug any cables from the keyboard.
Slide the power switch on the top edge of the keyboard to the OFF (right) position.
Lay the keyboard upside down on a clean work surface.
Heat an iOpener and lay it on the top edge of the sticker for one minute.
Use a Phillips screwdriver to remove the two 5.5 mm‑long screws securing the battery cover.
Insert the tips of a pair of angled tweezers into the small recesses on the top of the battery connector, between the battery connector and its socket.
Gently push the battery connector out of its socket. Use a side-to-side rocking motion if it feels stuck.
Insert the flat end of a spudger under the right edge of the battery, near the top.
Gently pry the battery up until the adhesive releases and remove the battery.
Prop up the right edge of the keyboard and apply a few drops of high-concentration (>90%) isopropyl alcohol under the right edge of the battery.
Wait a few minutes and try to pry up the battery again.
If the battery is still stuck, apply more alcohol around the edges of the battery and prop up different edges of the keyboard so the alcohol can dissolve the adhesive all around the battery.
Apply a few drops of high-concentration (>90%) isopropyl alcohol to a microfiber or lint-free cloth.
Use the cloth to clean any adhesive residue out of the battery well.
Tool used on this step:Tesa 61395 Tape$2.95
Apply a wide strip of double-sided tape, like Tesa tape, near the top edge of the battery well.
Leave the liner on the back of the tape and use your finger to press the tape to the keyboard.
Repeat this process to apply another strip of double-sided tape near the bottom edge of the battery well.
Place the tips of a pair of angled tweezers on either side of the wires on the battery connector.
Use gentle, steady pressure to pull the battery connector into its socket.
Insert the tabs on the top edge of the battery cover into their cutouts on the top edge of the battery well.
Lay the cover down into its recess. It should lay flush with the keyboard.
Carefully align the sticker with its recess in the keyboard.
Use your fingers to firmly press the sticker onto the keyboard.
Congratulations on completing your repair!
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
