Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement
Views: 36K
View statistics:
Past 24 Hours:
13
Past 7 Days:
80
Past 30 Days:
301
All Time:
36,179
Comments: 18
9 comments on steps, 9 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the USB-C charging port and daughterboard on your Samsung Galaxy S21 Ultra.
Note: Retaining water resistance after the repair will depend on how well you reapply the adhesive, but your device will lose its IP (Ingress Protection) rating.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Remove the SIM card tray: step 1, image 1 of 3 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Remove the SIM card tray: step 1, image 2 of 3 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Remove the SIM card tray: step 1, image 3 of 3
      • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the top edge of the phone.
      • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
      • Remove the SIM card tray.
      • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
      Ask FixBot
    1. Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Heat the back cover: step 2, image 1 of 1
      • Unplug and power off your phone before you begin.
      • Prepare an iOpener and apply it to the back cover for at least three minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Insert an opening pick: step 3, image 1 of 3 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Insert an opening pick: step 3, image 2 of 3 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Insert an opening pick: step 3, image 3 of 3
      • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
      • If the back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
      • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
      • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap you created.
      • Slide the opening pick to the bottom left corner to slice the adhesive.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Ask FixBot
    3. Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Slice the adhesive: step 4, image 1 of 2 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Slice the adhesive: step 4, image 2 of 2
      • Insert a second opening pick at the bottom edge of your phone.
      • Slide the opening pick to the bottom right corner to slice the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    4. Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement: step 5, image 1 of 3 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement: step 5, image 2 of 3 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement: step 5, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
      • Insert a third opening pick at the bottom right corner of your phone.
      • Slide the opening pick along the right edge of your phone to slice the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement: step 6, image 1 of 3 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement: step 6, image 2 of 3 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement: step 6, image 3 of 3
      • When you slice near the camera assembly, insert only the tip of the opening pick (~ 4-5 mm) to avoid damaging or smearing the camera.
      • Insert a fourth opening pick underneath the top right corner of your phone.
      • Slide the opening pick along the top edge to slice the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement: step 7, image 1 of 3 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement: step 7, image 2 of 3 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement: step 7, image 3 of 3
      • Insert a fifth opening pick underneath the top left corner.
      • Slide the opening pick along the left edge of the back cover to slice the remaining adhesive.
      • When you slice near the power button, insert only the tip of the opening pick (~ 3-4 mm) to avoid damaging the power and volume button flex cable.
      Ask FixBot
    7. Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Remove the back cover: step 8, image 1 of 2 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Remove the back cover: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the back cover.
      • During reassembly:
      • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
      • If you're using custom-cut adhesives, follow this guide.
      • If you're using double-sided tape, follow this guide.
      Ask FixBot
    1. Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Slice the adhesive: step 9, image 1 of 2 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Slice the adhesive: step 9, image 2 of 2
      • Insert an opening pick underneath the left bottom end of the NFC antenna and charging coil assembly.
      • Carefully slide the opening pick along the bottom left edge of the assembly to separate it from the battery.
      Ask FixBot
    2. Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Disconnect the charging coil: step 10, image 1 of 2 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Disconnect the charging coil: step 10, image 2 of 2
      • Use a spudger to disconnect the charging coil by prying the connector straight up from its socket.
      Ask FixBot
    3. Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Disconnect the NFC antenna: step 11, image 1 of 2 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Disconnect the NFC antenna: step 11, image 2 of 2
      • Use a spudger to disconnect the NFC antenna by prying the connector straight up from its socket.
      Ask FixBot
    4. Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Unfasten the NFC antenna & charging coil assembly: step 12, image 1 of 2 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Unfasten the NFC antenna & charging coil assembly: step 12, image 2 of 2
      • Use a Phillips screwdriver to remove the five 3.9 mm-long screws securing the NFC antenna and charging coil assembly.
      Ask FixBot
    5. Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Unfasten the loudspeaker: step 13, image 1 of 2 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Unfasten the loudspeaker: step 13, image 2 of 2
      • Use a Phillips screwdriver to remove the four 3.9 mm-long screws securing the loudspeaker assembly.
      Ask FixBot
    6. Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Disconnect the loudspeaker: step 14, image 1 of 2 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Disconnect the loudspeaker: step 14, image 2 of 2
      • Insert the tip of a spudger between the frame and the upper-left notch in the loudspeaker.
      • Pry up with the spudger to release the loudspeaker from its plastic clips.
      Ask FixBot
    7. Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Remove the NFC antenna & charging coil assembly: step 15, image 1 of 2 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Remove the NFC antenna & charging coil assembly: step 15, image 2 of 2
      Buy
      • Use a pair of tweezers or your fingers to carefully remove the NFC antenna, charging coil, and loudspeaker assembly.
      • Set the assembly aside. You'll reuse it during reassembly.
      Ask FixBot
    1. Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Disconnect the interconnect cables: step 16, image 1 of 3 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Disconnect the interconnect cables: step 16, image 2 of 3 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Disconnect the interconnect cables: step 16, image 3 of 3
      • Use a spudger to pry up and disconnect the primary and secondary interconnect cables' press connectors on the motherboard.
      Ask FixBot
    2. Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Remove the secondary interconnect cable: step 17, image 1 of 3 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Remove the secondary interconnect cable: step 17, image 2 of 3 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Remove the secondary interconnect cable: step 17, image 3 of 3
      Buy
      • Use a spudger to disconnect the secondary interconnect cable from the daughterboard by prying its bottom connector straight up from its socket.
      • Use your fingers or a pair of tweezers to carefully remove the secondary interconnect cable.
      • Set the cable aside. You'll reuse it during reassembly.
      Ask FixBot
    3. Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Remove the primary interconnect cable: step 18, image 1 of 3 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Remove the primary interconnect cable: step 18, image 2 of 3 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Remove the primary interconnect cable: step 18, image 3 of 3
      • Use a spudger to disconnect the primary interconnect cable from the daughterboard by prying its bottom connector straight up from its socket.
      • Use your fingers or a pair of tweezers to carefully remove the primary interconnect cable.
      Ask FixBot
    1. Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Unfasten the charging board: step 19, image 1 of 2 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Unfasten the charging board: step 19, image 2 of 2
      • Use a Phillips screwdriver to remove the three 3.4 mm-long screws securing the charging board.
      Ask FixBot
    2. Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Pry up the charging board: step 20, image 1 of 2 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Pry up the charging board: step 20, image 2 of 2
      • Insert the pointed end of a spudger underneath the left edge of the charging board next to the main flex cable connector.
      • Use your spudger to pry up the charging board.
      Ask FixBot
    3. Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Remove the charging board: step 21, image 1 of 3 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Remove the charging board: step 21, image 2 of 3 Samsung Galaxy S21 Ultra USB-C Charging Port and Daughterboard Replacement, Remove the charging board: step 21, image 3 of 3
      Buy
      • Use a pair of blunt tweezers or your fingers to remove the charging board. Start by lifting its top edge up and then carefully slide the USB-C connector out of its recess.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
9 other people completed this guide.
Alex Diaz-Kokaisl
250,935 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,132 Guides authored
9 Guide Comments
Hi,
One month ago I dropped my phone in pool and I took it to the service center where they have dried out the phone. Everything was working fine but later only I was able to find out that the primary microphone is not working and also sim doesn't get detect. So couple of times I did resetting the phone pressing the volume down and power button and that fixed the SIM related issue. After couple of weeks again there was an error saying SIM can't be detected and I tried the same solution , after several attempts it detected again. Then again after two days the issue pops up once again. So I was able to find out that primary microphone and SIM card slot is in the same daughter board and thought of replacing it by myself. I got the new board and replaced it yesterday and still my microphone is not working. What would be the solution ? Is there anything I need to check/replace further like flex cables and all ? Please advise. Appreciate your help.
Thanks
Rahul Manayath - Reply Share
Hi Rahul!
If your speaker still isn't working after you replaced your daughterboard, then I would suggest replacing the loudspeaker itself. Unfortunately, we don't sell the loudspeaker currently, so you would have to find it from a different source. I wish you the best of luck in your repair!
Alex Diaz-Kokaisl - Reply Share
Hi
Everytime i put my phone on charge sometimes it works fine but if i take it out and put it back in again it keeps coming up with the moisture detected but theres no water inside there i dried it out and left it alone but before i didnt realise my lead was a little wet would that cause i massive problem charging
shexi_rudeboi_jmz - Reply Share
The tools kit for this job is inadequate you're better off saving your money and getting the correct one's. The gel heat pad doesn't produce enough heat to loosen the adhesive. The suction cup is worthless as it just pulls right off pretty easily. And the included picks are just not thin enough to slide in. I tried setting the gel heat pad on just the bottom edge to try and put as much heat as possible and then tried to get the pick into there but all that happened was the back glass started to shatter. So now I've got to buy a new back glass piece. You'll need to use a heat gun or hair dryer, find a strong suction cup and some kind of thin enough blade/tool to get in there. I'd make future purchases from IFIXIT if they'd just say hey get and use these tools instead of selling a kit that doesn't work just wasting their customers money.
Blaze Long - Reply Share
Thanks for the guide. The only suggestion I have is to make sure to separate the camera glass from the back cover while the glue is still warm. I tried to separate them when putting things back together and needed to add the new glue tape and broke the back cover. ifixit shows they are out of stock but luckily "A" online retailer had them in-stock, awesome price, and next day delivery.
Chris K - Reply Share
Past 24 Hours: 13
Past 7 Days: 80
Past 30 Days: 301
All Time: 36,179
