Lenovo ThinkPad T470 SSD Assembly Replacement
  1. Lenovo ThinkPad T470 SSD Assembly Replacement, External Battery: step 1, image 1 of 3 Lenovo ThinkPad T470 SSD Assembly Replacement, External Battery: step 1, image 2 of 3 Lenovo ThinkPad T470 SSD Assembly Replacement, External Battery: step 1, image 3 of 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 SSD Assembly Replacement: step 2, image 1 of 3 Lenovo ThinkPad T470 SSD Assembly Replacement: step 2, image 2 of 3 Lenovo ThinkPad T470 SSD Assembly Replacement: step 2, image 3 of 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 SSD Assembly Replacement, Bottom Cover: step 3, image 1 of 2 Lenovo ThinkPad T470 SSD Assembly Replacement, Bottom Cover: step 3, image 2 of 2
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 SSD Assembly Replacement: step 4, image 1 of 3 Lenovo ThinkPad T470 SSD Assembly Replacement: step 4, image 2 of 3 Lenovo ThinkPad T470 SSD Assembly Replacement: step 4, image 3 of 3
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  5. Lenovo ThinkPad T470 SSD Assembly Replacement: step 5, image 1 of 1
    • Remove the bottom cover from the laptop.
    • Disconnect the battery from the board before continuing.
  6. Lenovo ThinkPad T470 SSD Assembly Replacement, SSD Assembly: step 6, image 1 of 2 Lenovo ThinkPad T470 SSD Assembly Replacement, SSD Assembly: step 6, image 2 of 2
    • Use the flat end of a spudger to flip up the metal clip securing the SSD connector to the motherboard.
  7. Lenovo ThinkPad T470 SSD Assembly Replacement: step 7, image 1 of 2 Lenovo ThinkPad T470 SSD Assembly Replacement: step 7, image 2 of 2
    • Use the flat end of a spudger to separate the connector from its socket.
  8. Lenovo ThinkPad T470 SSD Assembly Replacement: step 8, image 1 of 3 Lenovo ThinkPad T470 SSD Assembly Replacement: step 8, image 2 of 3 Lenovo ThinkPad T470 SSD Assembly Replacement: step 8, image 3 of 3
    • Grab the tab on the left side of the SSD assembly, and pull up to remove it from the laptop.
3 other people completed this guide.
Kristen Gismondi
100,432 Reputation
258 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,788 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 55
All Time: 2,087
