Introduction
Through this guide, you will be able to remove the Chromebook's keyboard from the back casing and expose the battery and motherboard underneath. The keyboard may need to be replaced if several keys are unresponsive, the keyboard as a whole is unresponsive, or the mouse/touchpad is unresponsive.
Flip the Chromebook so that the bottom is facing up.
Use a Phillips #1 screwdriver to remove the six 6.6 mm screws on the bottom.
Use a spudger to remove each of the 4 rubber feet.
Use a Phillips #1 screwdriver to remove the four additional screws under the rubber feet.
Flip the Chromebook back over and open the screen.
Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook.
Run the plastic opening tool along the seam between the keyboard and the bottom of the Chromebook until the keyboard moves freely. Several tabs will pop out.
Once the keyboard is released, grab the two top corners closest to the screen and slowly lift the keyboard up.
Disconnect the cables by lifting up the retaining flaps on the black ZIF connectors.
Slowly pull the cables up and out of the connectors.
